2009 4x4 (T-SB-0373-09) & VSC disable issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Nov 27, 2009.
  1. Nov 27, 2009 at 1:24 PM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I recently had my ECM recalibrated / reflashed using T-SB-0373-09 (Transmission TSB dated Nov 3 rd.)
    Well now it's not possible to disable VSC in 4WD-HI. :eek:
    I used to be able to hold in the "VSC diable button" for 3 seconds while in park--now it does not work!
    I think this may be an unintended side affect of the ECM reflash. Can some of you guys with the 2009 4x4's confirm this for me?
    UPDATE: 12/23/2009 My problem has been solved.
    I confirm that my problem existed... Took my tuck to the dealer for diagnostics... My truck sat for a day... The SA said the tech did nothing. When I picked up my truck the problem was gone. I have tested the VSC disable switch while in 4WD-HI and the problem is indeed gone. Chalk one up to PFM.
  2. Nov 27, 2009 at 1:34 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I just went out to my truck and started it up and put it into 4HI. Then I pressed and held in the VSC button. The light came on in the dash saying that it was off. Then I put it into drive without issue. I had the reflash done last monday.
  3. Nov 27, 2009 at 1:41 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you for doing that! I can't imagine why mine would be any different if they did the same exact reflash. I had the service advisor print the TSB so I know they had the right one. I am very concerned about this.
  4. Nov 27, 2009 at 5:36 PM
    trd taco guy
    trd taco guy Well-Known Member
    Rob
    09 tacoma trd sport
    Did the reflash make a difference in the shifting issue or not?
  5. Nov 27, 2009 at 7:47 PM
    dexterdog
    Oly WA
    2012 F150
    As far as I can tell yes. I still think mine downshifts prematurely at times but I don't have that hesitation where it's searching for gears anymore.
  6. Nov 27, 2009 at 10:30 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    I tried it out as well and had the same experience as dexterdog. Doesn't seem to be a problem for me.
  7. Nov 27, 2009 at 10:32 PM
    Crom
    Nick
    San Diego, CA
    Millions
    After the reflash I noticed an immediate improvement during the 2-1 downshift. i.e. Slowing down to roll over speed bumps and then accelerating is much improved. My truck never had an issue with hunting for gears that others have reported, only the harsh 2-1 downshift.
    I was messing around on some trails six days ago when I noticed I couldn't disable the VSC in 4WD-HI. I was in the extreme backcountry, and I had nobody to communicate with to test this until now.
  8. Nov 27, 2009 at 10:34 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks for testing this and reporting it here +Reps sent.
  9. Nov 28, 2009 at 2:07 AM
    ToyFanatic
    ToyFanatic Well-Known Member
    Aaron
    Germany
    09 Tacoma TRD OR, Grey
    Weathertech's, Ipod Adptr, PIAA Fogs, AFE Stage 2 Si intake, DT Long Header, URD Y pipe, Wet Okole seat covers, Rockford Fosgate sound, and soon the URD 3" Exhaust
    So the Auto trannys are having problems as well for 09? whats the deal? manuals with revs hanging and autos shift hesitation/problems? My father has a 09 with the auto and hasn't said anything, maybe he is just getting too old to notice..lol
  10. Nov 28, 2009 at 11:17 AM
    Crom
    Nick
    San Diego, CA
    Millions
    My truck appears to be having a unique problem. I'll make an appointment to have it examined and report back here what happened.
    Thanks again to Dexterdog and NMG for testing and reporting.
