2009 A/C
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLC, Jul 23, 2017.
  1. Jul 23, 2017 at 4:57 PM
    FLC
    FLC [OP] Member
    Fletcher
    Aurora, Colorado
    2009 Tacoma 4door, Barcelona Red
    I noticed my A/C wasn't cooling as I thought it should. I bought a can of refrigerant and added it to the system. Once the can had been added, it seemed to cool better so prior to putting the cap back onto the pressure line, I did the ol put a little spit on the port to make sure no leaks. Well, I have very small bubbles! My question is , Can the little "bicycle tube" looking valve in the port be replaced OR am I in store for a visit to the Toyota Dealer for an A/C service?
    Thanks to anyone who an offer a solution.
  2. Jul 23, 2017 at 5:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well it depends how large a leak it is. Sometimes if the leak is miniscule enough all you have to do is reapply the service port cover and tighten it good since it has a seal integrated into it and it'll be fine. Otherwise if the leak bubbles are larger then it would be wise to replace it. There are different types of Schraeder valves based on the pressure it will be sealing. If you want to replace it, go ahead but do understand that you will need an AC service done CORRECTLY to properly use your system and ensure long service life and functionality afterwards.
    Next time, do not use those cans. Those things should be outlawed for sale as they do more harm than good.
    Rambo54, Bebop, Jeffs68 and 1 other person like this.
  3. Jul 23, 2017 at 6:07 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    There is a tool you can by for about $16.00 that will allow you to change out the schrader without loosing your charge. 12TRD is correct in saying don't use those cans, if you change it out yourself you should put a set of gauges on the system and make sure your pressures are ok.
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/04600210.pdf
    You can get gauges at harbor freight cheap if you don't have them.
    Rambo54 and Tex-Tac like this.
  4. Jul 23, 2017 at 7:08 PM
    Tcomaboy
    Tcomaboy Well-Known Member
    Texas
    2010 DCLB TRD Sport Prerunner
    Are you sure the little bubbles aren't from the spit itself. I know when I spit, there are little bubbles.
  5. Jul 23, 2017 at 7:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do you have a link to one of these tools?
    I have never seen a way to replace a schrader valve without dumping the charge.
    12TRDTacoma likes this.
  6. Jul 23, 2017 at 8:29 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Jimmyh likes this.
  7. Jul 23, 2017 at 11:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    retirementtoy, 12TRDTacoma and jmaack like this.
  8. Jul 24, 2017 at 3:59 PM
    Drivesector
    TRD sport
    You can usually get them cheaper at a supply house. They work well.
  9. Jul 24, 2017 at 6:19 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd........:popcorn:
  10. Jul 24, 2017 at 8:37 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    You are so welcome. You have supplied myself and so many others with good advice. :thumbsup:
  11. Jul 25, 2017 at 9:58 AM
    FLC
    FLC [OP] Member
    Fletcher
    Aurora, Colorado
    After going on line to NAPA, Their Schrader valves all said "Not Vehicle specific" , does that sound correct? Plus they ran price wise the entire spectrum, from around $5.00 to $40.00.
  12. Jul 25, 2017 at 2:39 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Different vehicles have different Schaefer valves. Best to evac the system and take the shrader valve out if you have no idea which one replaces it. A low side shrader for a Tacoma is not a universal part. And a few bubbles after you take the can tap off is normal. And btw using those cans is a sin.
  13. Jul 25, 2017 at 3:49 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    They do? I did not know that.
  14. Jul 25, 2017 at 4:19 PM
    Bebop
    Nick
    Not sure if your being serious or sarcastic?
  15. Jul 25, 2017 at 6:38 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Serious. I'm mostly retired and I did not know that there are different valve cores for vehicles.
  16. Jul 27, 2017 at 1:37 PM
    FLC
    FLC [OP] Member
    Fletcher
    Aurora, Colorado
    Thanks for all of the answers and responses to My A/C question. Almost everyone who responded, did so with the added note that using the small cans of the 134 refrigerant is a major sin. What do you use if not the little cans?
  17. Jul 28, 2017 at 11:20 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    What they mean is if you do not know what you are doing and do not have a complete proper gauge set you can cause more harm than good. Take it to a reputable AC shop.
