2009 And Ticking Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrtomphan, Sep 28, 2008.
  1. Jul 15, 2009 at 4:06 PM
    #61
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    If you hadn't owned a Toyota before and you think the 'ticking' is new, you obviously didn't do your homework.
    Every Toyota truck i have had chattered, or 'ticked' as you say, and the others stood the test of time and i expect no different from this one. I keep buying em' and they keep lasting.
    It is a common characteristic of the truck and has been for many years.
  2. Feb 21, 2011 at 11:33 PM
    #62
    Stinka88
    Stinka88 New Member
    Christina
    Bremerton, WA
    09 Taco 4x4 2.7L
    09 2.7l . Slight ticking from top of engine. Took it to the dealership the next day, they said it was normal for the fuel injectors to do it... I didn't like that answer much so I went and bought some Lucas injector cleaner and I run a bottle through the tank every 8k miles or so and the noise hasn't come back since.
  3. Feb 22, 2011 at 2:12 PM
    #63
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    i just tell people its all the pony's :D
  4. Mar 18, 2011 at 8:09 PM
    #64
    TacomaTim
    TacomaTim Well-Known Member
    Tim
    Meadville, PA
    2015 TRD Pro Tacoma
    The only cure is something loud enough to mask the ticking noise as others have said. I opted for a louder exhaust. That cured it and it sounds awesome. That ticking noise is still there when I lift the hood but can't hear it over the exhaust like I used to.
    The ticking blows and drove me nuts before I masked it. Apparently the reason is related to fuel efficiency.
  5. Mar 18, 2011 at 8:21 PM
    #65
    TPAP
    TPAP Member
    SoCal
    09 prerunner sport
    My 09 has the tick as well, a friend of mine is a Toyota Tech, he says it's normal. Just turn up the radio, and it will go away.
  6. Apr 6, 2012 at 3:56 PM
    #66
    Steiny17
    Steiny17 Member
    Kailua
    2017 Sport 4x4 6MT
    i have an 06 and suffer from this ticking noise as well, mine is most noticable between 1500-2500rpm and then sounds like a champ. I tried the rubber gasket thing w/ no change...i just changed my oil pan gasket yesterday due to a leak(believe it or not i was actually successful) and while i was under checking for leaks after i was done i noticed the noise was extra loud. With the catalytic converter 6 inches from my face it seemed to be coming from there, i moved all around under the engine and the noise was most prominent right by the cats. Im not much of a mechanic and dont know shit about engines but was wondering if this could be along the lines of the exhaust manifold tsb???
  7. May 16, 2012 at 6:46 PM
    #67
    ncfirefighter764
    ncfirefighter764 Member
    Jeff
    NC
    2009 Double Cab TRD Sport
    TRD seat covers, TRD bed mat, Tool box, Red strobe emergeny lights - front window.
    I had the same buzzing noise and after 3 trips to the Toyota dealership it was discovered to be the plastic covering that is wrapped around the wiring from under the dash.
  8. May 16, 2012 at 6:49 PM
    #68
    ncfirefighter764
    Jeff
    NC
    Every Toyota truck has that ticking noise its the sound of quality!!
  9. Jun 12, 2012 at 10:42 PM
    #69
    JT RAM
    JT RAM Member
    Joe
    SaTx
    08 4x4
    My 2008 had the ticking noise when I bought it in October 2007, still has it now @ 104k mi. Has never bothered me. I havn't come across a Tacoma without it.
