2009 Going North
Discussion in 'Suspension' started by Ranger08, Aug 12, 2008.
  1. Aug 12, 2008 at 4:15 PM
    Ranger08
    Ranger08 [OP] Well-Known Member
    North Carolina
    2009 4x4 Double Cab
    Stock
    OK I read a lot of the threads talking about lifts. I want the 3" Toytec coilovers for the front. What else will I need? Should I replace the UCA's and is the AAL my best option for the back? I am going for looks not serious off roading. I would like to run 285's with a set of 17" Moto Metal rims. My Taco is a 4x4 DC. :rolleyes:
  2. Aug 12, 2008 at 4:22 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    If you can afford it, definitly get the UCAs.
    AAL is the best option for the rear if your not gonna be really off roading. The only thing you need now is a set of rear shocks. Get some 5100s for the rear and you should be set.
    To run 285s on your truck, you will need to do some trimming on the inner fender and maybe remove the front mud flaps.
    Post pics when its all said and done.
  3. Aug 12, 2008 at 5:48 PM
    Ranger08
    North Carolina
    2009 4x4 Double Cab
    Stock
    Thanks for the information. Should I look into running smaller tires? The 285's seemed the way to go. Toytec told me I might be able to use my existing shocks but need to add a 1" spacer? Sounds like the 5100's on the rear might be the best way to go.
  4. Aug 12, 2008 at 6:00 PM
    Pat
    Pat Well-Known Member
    San Diego
    05 PreRunner Access Cab
    King Coilvers, 285 BFG A/T's, Moto Metal 951b's 17"
    285's will work fine with some trimming like what 05TacoTRD said. Alot of people run 285's with their 3" lifts. They look good.
  5. Aug 12, 2008 at 6:04 PM
    rick
    rick `
    ^^^ what they said. some will say you need to replace your shocks. its a good idea but not necessary.
  6. Aug 12, 2008 at 6:13 PM
    rick
    rick `
    oops nm. i see you want the coilovers. there is a group buy on TN. it ends the 15th
  7. Aug 12, 2008 at 6:32 PM
    Ranger08
    North Carolina
    2009 4x4 Double Cab
    Stock
    I tried to PM but no answer. Not sure what kind of price break they are giving. I might call Toytec and ask for "Doug" he seems to be the man with the prices.
  8. Aug 12, 2008 at 6:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WHAT!? Dont EVEN try to tell me Blocks are better for off raoding.
  9. Aug 12, 2008 at 6:52 PM
    Ranger08
    North Carolina
    2009 4x4 Double Cab
    Stock
    Pat What back spacing do you have on your Moto Metal wheels?
  10. Aug 12, 2008 at 6:56 PM
    Pat
    San Diego
    4.5". I think they look great.
