2009 rear locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 96tacoma, Jan 2, 2010.
  1. Jan 2, 2010 at 6:33 PM
    96tacoma
    96tacoma [OP] Well-Known Member
    aj
    folsom, ca
    2009 4x4 Trd Off Road
    Pioneer z-110, tint, leveling kit
    so i was searching and couldnt find anything about it so i thought i would just ask real quick. i have a 09 trd off road with the locker but i was wondering if i could have the locker on without having the 4wd on?
    thanks for the help
  2. Jan 2, 2010 at 6:37 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i think so. doesnt the locker just lock the rear? front stays open?
  3. Jan 2, 2010 at 6:38 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    no you must be in 4 low
  4. Jan 2, 2010 at 6:38 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Look up the grey wire mod. I think it's a little different in 09s though. Something to do with the ATRAC. I didn't bother cause I like 4 Lo just fine.
  5. Jan 2, 2010 at 6:42 PM
    08pretaco
    Oliver
    az
    thats what happens when a prerunner answers a 4x4's question haha :eek:
  6. Jan 2, 2010 at 6:42 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    If you're stuck enough or doing something burly enough that you'll want the locker on, then you'll probably want to be in 4Lo anyway...
  7. Jan 2, 2010 at 6:44 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Just use the LSD if needed in 2wd... press the vsc button once...
  8. Jan 2, 2010 at 6:51 PM
    96tacoma
    aj
    folsom, ca
    thats odd that i can only have the locker when in 4lo. almost seems pointless to have a locker. i will be using the lsd so much more.
  9. Jan 2, 2010 at 6:52 PM
    08pretaco
    Oliver
    az
    why would you need a locker in 4 hi? i dont have a 4x4 but anything at that speed, wouldnt momentum just get you through it?
  10. Jan 2, 2010 at 6:56 PM
    96tacoma
    aj
    folsom, ca
    ya i just would like to lock the back but have the front open. i think a lot of people would
  11. Jan 2, 2010 at 6:57 PM
    TL697
    Jacksonville, FL
    I've only needed the locker while offroad in 4LO...
    Pointless to have a locker until you need it... ;)
    I use the LSD when needed or just flip the switch to 4HI...
    The locker combined with ATRAC has taken me places I couldn't have gone otherwise...
    I love all the options on my '09 TRD OR 4x4, and I've used/needed them quite often here in the CO mountains...
  12. Jan 2, 2010 at 8:19 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    You're a bad man. My truck is on jack stands in the driveway and hasn't seen a dirt road since before Thanksgiving :(
  13. Jan 2, 2010 at 8:32 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I believe an ARB Locker would be a nice addition to my prerunner. I have had mostly 4x4 trucks in my past, and with a locked rear in my 2WD I feel I could most of the stuff I needed 4x4 with. :D
  14. Jan 2, 2010 at 8:36 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    The off-roads have limited slip AND the locker?
  15. Jan 2, 2010 at 8:39 PM
    Brunes
    Brunes abides.
    Rotorhead
    Auto Limitied Slip- Uses brake controlling to mimic a mechanical LSD...Just the 09/10 models.
  16. Jan 2, 2010 at 8:41 PM
    Brunes
    Brunes abides.
    Rotorhead
    Why?? If you are locked in the rear your turning radius is limited by that- so what does it matter if the front is engaged or not?? (I think that diff is always open unless you put an aftermarket locker in it....)
  17. Jan 2, 2010 at 9:02 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    TRD Off Road/ rear locker
    TRD Sport/ LSD rear
    09-10's have computered controlled "LSD" rear ends, which is the same as all trucks without a locked rear. So you get both options with the off road
  18. Jan 2, 2010 at 10:16 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I'd like to see the locker active in 4hi. My dad's silverado tears the mud with his Z71 package. I'd also like to see the locker available in the sport DC long beds...
  19. Jan 3, 2010 at 3:00 AM
    96tacoma
    aj
    folsom, ca
    i guess i just assumed that you could lock up the rear without putting it in 4wd like the frontier. all well still a good truck over all..
  20. Jan 3, 2010 at 4:21 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
