2009 "safety" options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mojo22, Sep 2, 2008.
  1. Sep 2, 2008 at 10:42 PM
    mojo22
    mojo22 [OP] New Member
    Rochester, Minnesota
    09 Double Cab TRD Off Road
    I just upgraded my 07 TRD Off Road to an 09 for the side curtain air bags and stability control--it's my understanding that not onlyis ESC going to be mandatory in the next few years it is a life saver, based on statistics. This truck will be used for transport, work, light off-road, towing and in sun, rain, muds, snow, ice and everything Minnesota can throw at us.
    But I got a lot more. ABS, brake assist, VSC, ATRAC, hill-start assist, DAC, locking rear differential, auto LSD ... lots of terms. My main confusion is between ATRAC, auto LSD, locking diff and what all the buttons do and when each one should be used. There is also a section in the manual that talks about TRAC and VSC. My inventory report states that I have VSC+ATRAC in place of "standard VSC+TRAC."
    I think I've got the following:
    1) ATRAC: Keeps all 4 wheels from spinning in 4wd (uses brakes). "Put into L4, press ATRAC button." Can be used with locked rear diff.
    2) AUTO LSD: Keeps from having one rear wheel spinning in 2wd (uses brakes). "Press VSC OFF (AUTO LSD light turns on)." Swtiches between VSC and AUTO LSD based on speed.
    3) Rear diff lock: keeps both wheels rear wheels turning together. "Put into L4, engage lock." With lock, VSC and ATRAC are off.
    Why use ATRAC and a locked rear diff?
    When AUTO LSD vs. locked rear diff?
    Do you have to be in L4 to use lock? Can you be in 2wd?
    What is the difference between ATRAC and TRAC?
    And from a practical point of view ... which mode or combination of modes are best in the following situations? (i.e. when should I take it out of the standard mode). Assume that I want to take advantage of the electronics and not depend on 4wd and skill.
    1) Driving in snow in the hills, sliding around.
    2) Slowly driving on city streets in ice/snow/crud. Stop signs, turns, etc.
    3) Driving on highway at faster speeds in snow and ice.
    4) Stuck in a ditch.
    5) Pulling out someone stuck in snow when the roads are bad too.
    6) Bogged down in mud.
    7) Pulling boat up steep slippery ramp.
    Thank you in advance for your help.
    TC
    __________________
    2009 Tacoma TRD Off Road. Automatic with towing package. Stock.
  2. Sep 3, 2008 at 8:04 AM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    haha i was reading my manual the other day and wondering all the same stuff...
  3. Sep 3, 2008 at 8:35 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Damn good questions. I didn't get much help from the salesman in terms of any of this, not that I expected it. I was hoping to have the mechanic at the dealership explain some of these features when I take it in for my complimentary oil change.
    A slightly off topic question for you other '09 guys... Are your intermittent wiper controls wired backwards? Mine has a short delay when it's on the fat (top) white line, and a long delay on the skinny (bottom) white line... I'm pretty sure it's supposed to be the other way around.
  4. Sep 3, 2008 at 8:42 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I turned that mess off the other day when I was stop and go in heavy rain and the auto lsd light came on along with the other one thats yellow then when I was up to speed the yellow light went off and the auto lsd remained but both rear wheels were engaged when I would take off at the lights. I figure when in 4x4 that mess should be turned off so you have as much power and traction as possible?
  5. Sep 3, 2008 at 9:23 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ur correct....its that way on my 09 and it was the opposite (right) way on my 07
  6. Sep 3, 2008 at 10:23 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    so u got a 09 off-rd edition too?
  7. Sep 3, 2008 at 10:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    So - do they make an 09 TRD SPORT?
    All the 09's come with an Auto LSD - then where did the mechanical LSD go?
    Or don't they come with that anymore?
  8. Sep 3, 2008 at 11:10 AM
    The_Hodge
    SC
    mine is an 09 sport....they still make them, but now that the auto lsd is standard, the sport is cheaper than the offroad for once. the mech lsd is gone
  9. Sep 3, 2008 at 11:15 AM
    Janster
    Jandy
    Lancaster, PA
    That sucks.... they're taking away all the mechanical goodies and making it all electronic.
    What's next? AWD & no low-range? :eek:
  10. Sep 3, 2008 at 11:17 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Mojo22, welcome. Despite the fact the 09 Off-Road has more traction combos than a Land rover, dont think much changes vs your 07.
    You'll use 2wd, 4hi, 4l0 & locker like you always did, theres just more buttons to toggle thru whether you want stablity or traction control on or off.
    You 09 Off-road guys should do a good off-road test and break down real world difference of each setting.
    Janster, the 09 Sport vs SR5 has usual upgrades, but no more traction upgrade. Mech LSD and VSC/TRAC, guess a no for Toyota.
  11. Sep 3, 2008 at 11:22 AM
    The_Hodge
    SC
    i can highly stress that you do turn off the rsca's when offroading....dont want those blowing their loads when u dont need them
  12. Sep 3, 2008 at 2:28 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    I was told my 09 had LSD, but it's just accomplished by the stability control & ABS working together.
  13. Sep 3, 2008 at 2:55 PM
    The_Hodge
    SC
    exactly...its the auto lsd...not the mechanical one thats in the rear diff like the 05-08 sports
  14. Sep 4, 2008 at 9:18 AM
    Hoofhearted
    Hoofhearted C5 Meter Minder
    2017 TRD SPORT ACB 4V6
    +1
  15. Sep 8, 2008 at 11:56 AM
    mojo22
    My variable wipers are reversed too. I'm going in tonight for something else--I'll ask.
  16. Sep 8, 2008 at 12:09 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I'll return to this thread later to answer the diff lock question.
  17. Sep 8, 2008 at 2:22 PM
    The_Hodge
    SC
    lemme know what they say. might have to go have them fix it. its just annoying
  18. Sep 8, 2008 at 2:30 PM
    TacoCo
    Colorado
    Yeah, I'm curious about that one too. I was planning on asking them to fix it when I drop mine off for it's 3k service.
  19. Sep 8, 2008 at 4:05 PM
    flyinn
    flyinn Active Member
    P-Town
    09' Tacoma 4X4 TRD off Road
    Magnaflow exhaust
    My wipers are backward too!!
  20. Sep 8, 2008 at 4:35 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    If it ever rains here again, I suppose I'll try the wipers and find out if they're backwards. Oh, I guess I could wash the truck and turn them on to see, but we're trying to conserve water due to the drought.
