2009 srs light on after steering column replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hazard2600, Jul 5, 2020.
  1. Jul 5, 2020 at 1:07 PM
    hazard2600
    hazard2600 [OP] Well-Known Member
    Ted
    Watertown, TN
    2009 White 4x4 SR5 TRD Sport LBDC V6
    3" ProComp sus lift 2" Roger Brown body lift 33" BFGs ko2s 1.25" spidertrax wheel spacers Custom rock sliders Seat covers USB ports OBD2 computer monitor
    Hey guys I had to replace my steering column and now my srs and limited slip lights are active on my dash. Limited slip seems to go on and off randomly. Like a loose wire. Not sure what happened. I didn’t do anything with the wiring. I’m going to pull the battery as soon as the rain lets up.
    grasping at straws on this one.
  2. Jul 5, 2020 at 1:22 PM
    Muddinfun
    Muddinfun Well-Known Member
    You broke the spiral cable. (Clock spring)
  3. Jul 5, 2020 at 2:10 PM
    hazard2600
    Ted
    Watertown, TN
    The only thing I could think that would cause it would be if my kid was in the truck and spun the steering wheel a bunch when the lower steering arm was disconnected. Could that have done it?
  4. Jul 5, 2020 at 2:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you replace the whole column or just the u-joint?
  5. Jul 5, 2020 at 2:51 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Yes, that would do it
  6. Jul 5, 2020 at 4:07 PM
    hazard2600
    Ted
    Watertown, TN
    I replaced the entire lower steering shaft. It came loose on me while I was driving down the road. Fortunately it was a straightish road and I was able to come to a stop safely. The lower bolt that connects the lower steering column to the steering box somehow became stripped so bad that the lower spindle popped off.
  7. Jul 5, 2020 at 4:09 PM
    Muddinfun
    I'm thinking you're calling the intermediate shaft the steering column. The steering column is everything between the intermediate shaft and the steering wheel.
    hazard2600[OP] likes this.
  8. Jul 5, 2020 at 4:10 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It's exactly what did it.
  9. Jul 5, 2020 at 4:14 PM
    hazard2600
    Ted
    Watertown, TN
    Thanks for the clarification, that sounds right.
  10. Jul 5, 2020 at 4:17 PM
    Muddinfun
    You mentioned that the intermediate shaft came loose from the rack. When that happened, the rack turned or you turned the steering wheel or both. Don't blame it on your kid. It was an unfortunate side effect of the failure. All it takes is 1 turn off to wind the spiral cable too tight or bunch it up and break it.
