2009 Tacoma Prerunner Diff Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattsyota529, Jan 27, 2022.
  1. Jan 27, 2022 at 1:21 PM
    Mattsyota529
    Mattsyota529 [OP] Active Member
    Hey all, planning on draining and filling the diff fluid in my Taco. I'm not sure if my truck has a lsd. Whenever I press and hold traction control off it'll pop up the auto lsd on the dash if that helps. Any specific fluid to use? I was going to use the Valvoline 75-90 full synthetic with the limited slip additive. What do you guys recommend? Do I still need to add a friction modifier? Thanks in advance.
  2. Jan 27, 2022 at 1:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mattsyota529[OP] likes this.
  3. Jan 27, 2022 at 1:48 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have the auto LSD then you don't have a mechanical LSD in the rear diff so you don't need an LSD additive, it's not gona hurt anything if you do put the additive in but id doesn't need it.
    Mattsyota529[OP] and TnShooter like this.
  4. Jan 27, 2022 at 1:53 PM
    Mattsyota529
    Okay sounds good. So just pick one and send it. Thanks!
    TnShooter likes this.
  5. Jan 27, 2022 at 4:08 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Prices on full synthetic 75w90 are kind of interesting. I have been running Mobil Delvac 75W90 and this post made me curious if Supertech is any cheaper, but really when you compare it's only about a buck or two difference per gallon.
    https://www.summitracing.com/parts/mob-122035-1 = $35.99/gal or $8.99/qt
    https://www.walmart.com/ip/Super-Tech-Full-Synthetic-Gear-Lubricant-SAE-75W-90-1-Quart/309470123 = $8.54/qt
    If WM sold their stuff by the gallon it would probably be cheaper but it looks like Supertech only comes in quart bottles.
