2009 tacoma trd wheel upgrade question
Discussion in 'Wheels & Tires' started by surrycotaco, Dec 5, 2014.
  1. Dec 5, 2014 at 9:28 PM
    surrycotaco
    surrycotaco [OP] New Member
    Caleb
    Mount Airy, NC
    TRD off-road Tacoma
    light bar, camper shell, N-FAB light bar
    I have recently purchased a 2009 tacoma trd access cab. I was wanting to upgrade my wheels, my truck also came with TPMS and I wasn't sure how switching rims went. Also the truck has brand new 16'' Michelin's and i would rather just buy a set of 16'' rims and use the tires on it. I had read some where that you can't put after market 16'' rims due to rubbing on the brake calipers? Has anyone had that problem or know what my best option is.
  2. Dec 5, 2014 at 10:12 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Also check to make sure your TPMS will work with the new wheels.....Toyota has a couple different ones depending on if you have Steel or Alloy wheels / rim size etc. If you need to get new ones figure $100-$125 for the set.
