2009 V6 auto - first real problem - trans
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raylo, Jul 7, 2020.
  1. Jul 7, 2020 at 12:43 PM
    Raylo
    Raylo [OP] Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Finally coming up on 100k miles and I have a trans issue. Trans is actually fine 90% of the time and shifts normally and solidly. But coming out of low speed turns like at intersections sometimes when I give it gas the engine revs like it is in neutral and then bang, it shifts to second chirping the tires if I leave my foot in it. This is not "slipping", it seems like it is getting confused releasing one gear and not engaging the next. I am thinking I might have a balky solenoid or somesuch. I know it is "due" for a fluid change at 100k miles but I don't believe it needs that. Anyone encounter similar?
    Lucifer1 likes this.
  2. Jul 7, 2020 at 12:44 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    #1 fluid change if never done
    #2 if that don't work let a professional Trans. repairman look at it
    #3 still may have a warranty on the Drivetrain?
    Junkhead and Lucifer1 like this.
  3. Jul 7, 2020 at 1:12 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
  4. Jul 7, 2020 at 1:23 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Any input @gearcruncher ? Failing solenoid?
    gearcruncher likes this.
  5. Jul 7, 2020 at 2:30 PM
    Raylo
    MD, USA
    I haven't found a schematic yet but there have to be at least a couple of shift solenoids and a TCC solenoid. If I can find their locations I can pull them and put a meter on them and give them an op test. But if the problem is intermittent that might not be definitive.
  6. Jul 7, 2020 at 2:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Find out what is wrong BEFORE you start fixing stuff that might not be broke. It sounds electrical to me. I've not had any issues with my Tacoma, but our 2009 Honda's transmission was throwing codes and shifting funny like that. I was quoted $2K to rebuild the transmission. Thirty minutes after dropping it off at the shop I got a call telling me it was ready.
    The mechanic did some poking around before pulling the transmission and found some electrical wires that mice had chewed through the insulation causing a short against the housing. They put some shrink wrap over the exposed wires and charged me $50.
  7. Jul 7, 2020 at 2:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You can try these?
    https://atracom.blob.core.windows.net/webinars/import/toyotaa750_a761_introduction.pdf
    https://www.sonnax.com/tech_resources/375-toyota-lexus-a750e-f-solenoid-identification
  8. Jul 7, 2020 at 3:02 PM
    Raylo
    MD, USA
    That info helps. Super useful post! it sure sounds like it might be the S2 solenoid that controls the 1-2 and 3-4 shifts. I see this behavior mostly on 1-2 but also on the 3-4. Now I need to go back those links or elsewhere to see if I can find the S2 location. If it is externally accessible like on many vehicles that will be a quick thing to pull and test. Also could be the clutch apply solenoid hanging up and then switching. They are all in the same place so if/when I open it I'll test them all.
    Edit: oh I see from the second link that these are in the valve body under the pan on our Tacomas. A bit more work, then. Hmmm... Darn. On many cars they can be pulled from outside the case with one bolt.
  9. Jul 7, 2020 at 3:18 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Something has to plug into those externally from the trans. Try to find a pinout and test it at the ECU/ BCM. Or get a cracked version of techstream for data logging or special functions / bi-directional control. Maybe @caribe makaira can point u in the right direction on the pin location.
  10. Jul 7, 2020 at 3:22 PM
    Raylo
    MD, USA
    That might work to ohm them out, but not to observe plunger stickiness. But it would be a good first step if I can find the pinouts.
  11. Jul 7, 2020 at 3:25 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    For sure just measuring resistance. Throw a bottle of brake clean in your trans, it'll get rid of the stickiness REAL quick
  12. Jul 7, 2020 at 3:37 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Brake kleen....
  13. Jul 7, 2020 at 4:12 PM
    Raylo
    MD, USA
    LOL... or the all purpose, fixes-everything Sea Foam, right?? ;-)
  14. Jul 7, 2020 at 4:14 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Exactly :rofl:
  15. Jul 7, 2020 at 5:03 PM
    gearcruncher
    Canadain bumper technician
    The symptom you are explaining sounds like low on trans fluid . For what its worth I would check that first .
    Not sure about sea foam for transmissions ? Lubeguard is good
    Trans fluid should be changed every 30k under normal driving operation
    Are you running a scanner of any sorts ? got any codes ?
    Next thing that comes to mind is the SLT solenoid
    http://bluegrasstoday.com/wp-content/uploads/2012/07/a750e_shudder.pdf
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
  16. Jul 7, 2020 at 5:18 PM
    Raylo
    MD, USA
    No codes, no leaks. If only we had a dipstick. But any fluid loss would have to be magical with these sealed trannies in the absence of a leak. And it doesn't do the usual things with low fluid like not going into D or R immediately. That is usually the first sign of that.
    I was kidding about the Sea Foam. I prefer my transmission fluid straight, thank you very much. You'd be a fool to put that stuff in there.
  17. Jul 7, 2020 at 5:25 PM
    gearcruncher
    Transmissions are not sealed as stated by the Tacoma dealer hehehehe
    Your trans fluid can drain into the transfer case , can drain out the overheat vent , and in a worst case scenario , it can drain into your cooling system causing the dreaded strawberry milkshake .
    When turning corners , all your fluid moves to one side of the pan causing the transmission pump to starve for fluid . Once the transmission gets very low , you will notice delays to first gear and reverse
  18. Jul 7, 2020 at 5:31 PM
    Raylo
    MD, USA
    Interesting... I definitely don't have the milkshake and none in the TC at the last oil change... and I have never towed anything to overheat it. But I guess I could pull the plug and have a look. But I need to go look at that procedure. I remember looking at the fill procedure years ago and it involved getting the tranny to a specific temp and filling to the fill plug IIRC. I have no idea what temp, however, and no way to measure it regardless. I curse Toyota for omitting a simple dipstick.
  19. Jul 7, 2020 at 5:31 PM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Nudging 200k, did a flush and fill early at 70K at the stealership. Now she asks for a 1/4 quart about every 30K. Funny how being a smidge low hurts so much..
  20. Jul 7, 2020 at 5:34 PM
    TnShooter
    Deogee
    STOCK
    The steps to get into Temp Check Mode are here
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
