2009 Wireless Door Lock Customize Parameters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Aug 17, 2008.
  1. Aug 17, 2008 at 12:46 PM
    BeefTaco
    BeefTaco [OP] WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Instructions to trun off off alarm chirp on 2008.5-2009 :cool:
    Last Modified: 5-14-20085.1 DFrom: 200805Model Year: 2009Model: TacomaDoc ID: RM000000XXC01SXTitle: DOOR LOCK: WIRELESS DOOR LOCK CONTROL SYSTEM: CUSTOMIZE PARAMETERS (2009 Tacoma)
    1. CUSTOMIZING FUNCTION
    The following items can be customized.
    NOTICE:
    • When the customer requests a change in a function, first make sure that the function can be customized.
    • Record the current settings before customizing.
    • When troubleshooting a function, first make sure that the function is set to the default setting.
    • If the battery is disconnected, the wireless answer-back buzzer will be returned to the default setting.
    Item
    Function
    Default Setting
    Customized Setting
    Wireless remote control
    Operation signal (Buzzer)
    ON
    OFF
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    • The driver side door is closed.
    • The ignition switch is turned off.
    • The key is removed from the ignition cylinder.
    • A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    • The transmitter is operated but the second button pressed is different from the first.
    • Answer-back starts.
    [​IMG] [​IMG]
    SR-71A likes this.
  2. Aug 18, 2008 at 8:21 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Anybody get this to work?
    I just dont get it, not working for me.
    My Scion had a few easter eggs like this. They are all a challenge and timing counts.
  3. Nov 1, 2009 at 11:49 AM
    Inabluecoma
    Inabluecoma New Member
    West of Austin
    2010 Dblcb Pre
    Worked nicely on my 2010.....
  4. Jan 24, 2010 at 1:02 PM
    astral
    astral On my second taco now....
    Arizona
    2011 TX PRO
    Bump.
    So I just bought my truck and I discovered something REALLY annoying. When you unlock the doors (with key or remote) the vehicle HONKS twice and BEEPS twice. Once of each on lock. Why on earth would you want honking and beeping at the same time?
    So the above instructions worked for disabling the beep, but it is really the honk that I want disabled. A couple of other threads I saw had instructions on how to program new remotes, but I haven't seen how to program honks. Thanks!
  5. Jun 21, 2010 at 2:56 PM
    Rbohno
    Rbohno Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    I searched and found 2 other threads on how to program factory remotes and those two didnt work.
    I am trying to set the truck (2010) up to automatically lock the doors when the key is on, I would prefer a setting that didnt lock the doors till the vehicle reaches a certain speed like my F-250 did.
    Does anyone have any idea how to do this?
  6. Jun 21, 2010 at 3:42 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    do you know how to make all the doors unlock with a single push of the unlock button?
  7. Sep 28, 2010 at 2:47 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    x2
  8. Sep 28, 2010 at 3:21 PM
    xxaarraa
    xxaarraa Well-Known Member
    X3
  9. Oct 2, 2010 at 7:07 AM
    CtTaco
    Eric
    Connecticut
    i suppose you could clip the passenger door unlock wire and connect it to the drivers door unlock wire with a couple diodes to isolate it if you were really industrious, but I just put in a DEI system instead :)
  10. Jan 5, 2011 at 6:32 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    F'in awesome!!!! I just did this on my 09 AC SR5 Option #2. It was super easy.
    Right after I got the truck I had the dealer do this for me. One night at work I let the battery die and pop-started it. Since then It has been beeping again. I went back to the dealer and they told me they couldn't do it. I've been back several times since and they still can't figure it out. Now I guess I will have to teach them.
    Nice work TacomaWorld! I think some dealers need to spend more time on here!
  11. Apr 6, 2011 at 9:15 AM
    dwilliams
    dwilliams New Member
    Ontario, Canada
    2011 Double Cab TRD
    Just tried this on a 2011 Double Cab TRD. Took all of 1 minute to correct an issue that service manager just today told me could not be done.
    Thanks!
  12. Aug 25, 2011 at 8:18 AM
    steph10m
    steph10m New Member
    Stephanie
    Akron, Ohio
    Thanks, worked great on my 2011 just as described! So did turning off the seatbelt chime too!
  13. Aug 20, 2012 at 11:05 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    hey! this also works on the 2012 tacoma- leave the driver door open!
  14. Nov 8, 2013 at 5:53 PM
    rosco
    rosco New Member
    Tacoma TRD 2013
    i'm lost following these directions and hints:
    HINT:
    Are the hints modifications for a different year? they don't jive with what i read in the steps of the instruction.
    • is the transmitter referred to in step (d) the wireless thing on the key chain?
    • the second hint makes no sense following the directions. when is the ignition switch (i'll guess key in key chamber) turned off?
    • how do i know "answer back mode" is activated? is it just assumed.
    • the fifth hint states the exact opposite of step (d).
  15. Dec 3, 2013 at 7:06 PM
    fir3fox
    fir3fox New Member
    As Info: Confirmed this works on the 2014 Tacoma.
  16. Jan 11, 2015 at 7:08 PM
    ptwob311
    ptwob311 Curios Noob
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    Worked great for me!
    Thanks for the post!
  17. Sep 12, 2015 at 2:03 PM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Worked on my 15 as well...
    Took a few tries to get it right, and learned that you need to push the 'lock' button on the key fob to deactivate the chimes.
  18. Sep 24, 2015 at 6:36 AM
    csmith15SR5
    csmith15SR5 Well-Known Member
    Raleigh, NC
    2015 White Tacoma SR5 PreRunner
    haha I called the dealer to find out how much it would cost to do this... $54..... Thanks TacomaWorld!!! u saved me $54 today!!
  19. May 4, 2018 at 2:53 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    This place is great!
    The dealer shut it off when I bought the truck in '12.
    I changed out my original 2012 battery today and got the annoying beep.
    Did a search and found this old thread.
    Took two tries and I got it.:thumbsup:
  20. Jun 10, 2018 at 3:32 PM
    Skypearson
    Skypearson New Member
    Douglas
    Hilton Head Island, South Carolina
    2011 Tacoma TRD Sport
    This worked like a charm, my battery was replaced and the beeping started again. This trick stopped the beep on my 2011 and now I can leave in the mornings without waking the wife.
