2009 Wireless Door Lock Customize Parameters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Aug 17, 2008.
  1. Jan 10, 2019 at 4:18 PM
    CF43-8E
    CF43-8E Member
    Maher
    Houston, TX
    2008 tacoma sr5
    I need help this methods not working Or I’m not doing it right
  2. Jan 9, 2021 at 9:49 AM
    blur
    blur Well-Known Member
    I just did this on my 12 and it worked the first try. From the OP
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
