2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...
Discussion in 'Motorcycles' started by OmegaQuest, Apr 2, 2013.
  1. Apr 2, 2013 at 11:11 AM
    OmegaQuest
    OmegaQuest [OP] Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    Here are some photos of my 2009 Yamaha R1 Track/street bike with 2013 electronics (Factory Traction Control) and a ton of other modifications I have done.
    ------ 2013 R1 OEM Traction Control Conversion ------
    2013 R1 Complete Engine Wire Harness (OEM)
    2013 R1 Left Handle Bar Switch with Traction Control Switch (OEM)
    2013 R1 Front Wheel Speed Sensor – Traction Control (OEM)
    2013 R1 Front Rotor Sensor – Traction Control (OEM)
    2013 R1 Speedometer / Cluster (MPH) (OEM)
    2013 R1 ECU (OEM)
    2013 R1 Starter Relay
    White Headlight Assembly Mod
    All Balls Tapered Steering Stem Bearings
    Annitori Racing Quickshifter
    Antigravity Li-Ion Battery
    Ariete 90 degree valve stems (Gold)
    Brembo RCS 19 Master Cylinder
    Brembo RCS Foldable Brake Lever
    Brembo RCS Foldable Clutch Lever
    Brembo RCS Reservoir Kit
    Bridgestone Battlax BT003 Tires
    CNC Front Fork Sliders (Red)
    CNC Rear Axle Sliders (Red)
    Custom Race Number Plates
    Driven D-Axis Fuel Base
    Driven D-Axis Fuel Cap (Red)
    Ek ZZZ 520 Chain (Gold)
    Euro Airbox Mod
    Flash-Tune Interface (2012 Version)
    Galfer Stainless Steel Front Brake Lines
    GB Racing Clutch Cover
    GB Racing Engine Cover
    GB Racing Pulse Cover
    GP Shift Modification
    GPR V4 Steering Stabilizer
    Graves Billet Aluminum Bar Ends
    Graves Carbon Fiber Slip-ons
    Graves Carbon Heat Shield
    Graves Cat-Eliminator Y-Pipe
    Grave Frame Sliders
    Graves Smog Block-off Plates
    Graves Swingarm Spools
    Graves Rear Brake Return Spring
    Hotbodies Racing Smoked Headlight Covers
    Integrated Sequential LED Tail Lights (Clear)
    K&N Air Filter
    K&N Oil Filter
    MotoDynamic’s Flush mount LED Turn Signals
    Motul 300V Motor Oil
    Motul RBF 600 Brake Fluid
    Ohlin’s FGRT 206 Front Forks (2013 Version with Wheel Speed Sensor Hole)
    Ohlin’s YA-931 Rear Shock
    Power Commander AutoTune
    Power Commander V
    Zero Gravity Double Bubble Racing Windscreen (Red)
    Rear Brake Reservoir Bracket
    Rear Seat Cowl (White)
    Renthal’s 50mm Clip-ons
    Rizoma Oil Cap (Red)
    Speed Bleeders
    Supersprox Stealth 520 Rear Sprocket – 47 Teeth (Gold)
    Supersprox 520 Front Sprocket - 17 Teeth
    T-Rex Motorcycle Stands (Red)
    Vesrah RJL Brake Pads
    Vortex Mirror Block-Off Plates
    Vortex V2 Adjustable Rearset
    Yoshimura - Axle Adjuster Blocks
    Yoshimura - Steering Stem Nut
  2. Apr 2, 2013 at 11:19 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Price?
  3. Apr 2, 2013 at 11:20 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    It's not a for sale thread.
  4. Apr 2, 2013 at 12:25 PM
    OmegaQuest
    Maryland
    Price = Not for sale. The mods alone cost more than the bike would alone LOL
  5. Apr 2, 2013 at 12:27 PM
    Large
    Large Red
    Damn nice bike..
  6. Apr 2, 2013 at 6:05 PM
    dually
    dually Low and slow
    Thats what I get for browsing on my phone, whoooooops!:eek:
  7. Apr 2, 2013 at 6:11 PM
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    Anymore pics of the bike, it looks super clean
  8. Apr 3, 2013 at 4:04 AM
    OmegaQuest
    Maryland
    Track Bike ;)
    I will post more up later
  9. May 3, 2013 at 11:36 PM
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Sweet bike. I had the Yellow '09 til someone backed into it while parked and literally rolled over it. SMDH:mad:
  10. Jul 1, 2013 at 9:38 PM
    fastguy95
    fastguy95 A man knows nothing
    SF Bay Area
    02 DC 4wd
    All Pro front/rear bumpers, OME 883's with Bilstein 5100 all around, Deaver J59 springs, TRD E locker, E locker Guard, Red Line hood struts, Weathertech floor mats, SS brake lines, EBC Rotors and green pads, Debadged, Line X, BAMF brake relocator bracket, Beefed Taco cb drop, Magnaflow muffler, Scuba Mod, live power outlet mod, disable door buzzer mod, tinted windows, light blinker conversion, Alpine HU, Infinity Kappa 600w amp, JL Audio 1000w amp for sub, JL Audio W3V4 12" sub, JL Audio 6x9's, Retrofit projectors bixenon 55w, Dynamat on all doors, and light bar.
    I love the white/red color schemes for the R1's/R6's! Great looking bike man.
    And, I absolutely love the fact that you list all your mods in alphabetical order! Reading that in order made my ocd skip a beat.
    Any moar pics?
  11. Jul 2, 2013 at 3:03 AM
    OmegaQuest
    Maryland
    I just posted some more pics on the first post above.
  12. Jan 10, 2017 at 7:10 PM
    richardddddddddd
    richardddddddddd New Member
    richard
    2013 r1
    hi, how did you mount the speed sensor?
  13. Jan 11, 2017 at 7:06 AM
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    That is interesting. Pretty cool that you did all of that. The bike is set-up nicely. As far as the electronics, I assume the bike is much easier to ride now? I know some people do not like the addition of all of these electronic assists. I bet the '15 is even crazier with the different modes that thing has.
    I know the '17 R6 is now getting some of the electronics. I'd be interested to try it out, but I'm pretty happy with my 3rd-gen w/o all of the traction stuff. Maybe 1 day I'll buy something with all of that (likely an R1).
  14. Jan 11, 2017 at 7:09 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
