2010-2011 Oil Viscosity Applicability and Change Interval Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Feb 14, 2011.
  1. Feb 14, 2011 at 6:16 AM
    BeefTaco
    BeefTaco [OP] WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
  2. Feb 14, 2011 at 9:27 AM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    the last bullet point on the first page addresses that.
    the second page is confusing though...
    i don't see a 1GR for 2011 Tacoma, but i see one for 2011 Tundra, and it says 0/20 and 10k miles. My 2011 Tacoma came with 5/30...so they are saying that the engine that came in my Tacoma has different clearances or operating parameters than the one in the Tundra, ones that allow it to run lighter oil and go longer on the intervals, even though it is the same engine and same year? according to the first page that is what you are left to infer. strange.
  3. Feb 25, 2011 at 4:30 PM
    gyro
    gyro New Member
    2001 tacoma 4 cyl sr5
    From Toyota motor co. 2011Toyota tacoma oil change interval changed to 10,000 miles. Use 0w20 Mobile1 synthetic oil. Advanced fuel economy green label. 4 cyl engine.
  4. Feb 25, 2011 at 4:33 PM
    jandrews
    '09 FourDubDee TRD OR
    Essentially, this doc says if you use your truck as a truck to stay with 5w-30 and 5k OCIs. If you use your truck as a car, go for 0w-20 and better mileage.
    DaveInDenver likes this.
  5. Feb 25, 2011 at 5:40 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I am about to hit 1k miles on my V6 4x4 access cab and going to change it then to 5w-30 castrol GTX with a NAPA 3148 filter...I always like doing the first oil change early to help get all the chips out of the engine. I normally run engines way past the 200k mark without issues.
    Howard
  6. Feb 25, 2011 at 5:45 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    amsoil 0-30 once a year..what.
    Norton likes this.
  7. Feb 25, 2011 at 5:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Whoa! :eek: Man you didn't read it carefully enough. That's NOT what it says!
  8. Feb 25, 2011 at 6:10 PM
    Gray Tacoma
    Gray Tacoma Well-Known Member
    northern West va
    11 Access cab-TRD Sport Package Mag.Gray
    Does the Dealership use full Synthetic oil? I plan on changing mine at a 1,000 miles too..
  9. Apr 27, 2013 at 4:05 AM
    pjs42
    pjs42 Well-Known Member
    Penna
    Red,off road,4x4,auto
    Wonder if this chart is good for a 2012 4.0
  10. Apr 9, 2016 at 4:13 PM
    Rickhead
    Rickhead Active Member
    SW Washington
    2011 Tacoma TRD Sport
    I am puzzled by that also..if you have a 2011 tundra, forerunner or FJ Cruiser with a 1GR engine, you can run 0/20 synthetic for 10k. But if you have a 2011 Tacoma with the same engine you have to change every 5000 with 5/30? Did they forget they made 2011 tacomas with that engine?
  11. Apr 10, 2016 at 3:31 PM
    Rickhead
    SW Washington
    Maybe it is simply the amount of oil capacity? Man, I really want to try it, though, just to see the difference in fuel usage.
  12. Dec 4, 2016 at 6:11 AM
    Awsome57
    Awsome57 Well-Known Member
    Kevin
    Is it bad to switch from conventional oil to synthetic and back to conventional oil
  13. Dec 4, 2016 at 6:16 AM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    Old thread rival.
    No......switching between conventional and synthetic will hurt nothing
    Norton likes this.
  14. Dec 4, 2016 at 6:18 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Shouldn't be a problem. You probably want to stick with the same brand of oil if you can, just to minimize the chance of different additive packages reacting (which is small anyway). Some oils are blended conventional and synthetic so the manufacturers don't think it's a problem.
  15. Dec 4, 2016 at 6:20 AM
    Plain Jane Taco
    USA
  16. Dec 4, 2016 at 6:21 AM
    Awsome57
    Kevin
    Thanks for the advise and what weight should I use if I like to race the truck a lot or just a fast driver 5-30 or something thicker
  17. Dec 4, 2016 at 6:25 AM
    Plain Jane Taco
    USA
    Race? o_O
    Anyway....what engine do you have?
  18. Dec 4, 2016 at 6:30 AM
    Awsome57
    Kevin
    4.0 with a 6 speed and u know bring the rpms up high every so often
  19. Dec 4, 2016 at 6:34 AM
    Plain Jane Taco
    USA
    Just stick with a 5w-30 and filter of your choice....synthetic or conventional and you'll be fine. Personally I change mine at 5k intervals.
    Odds are this thread will turn into this :argue: like all oil threads do. That's why I posted the link to bobistheoilguy site. Lots of great info.
    Sig45 and DaveInDenver like this.
  20. Dec 4, 2016 at 6:37 AM
    Awsome57
    Kevin
    Thanks I'll look at it and I like the emojis
