2010 2wd Tacoma bigger tire size?
Discussion in 'Wheels & Tires' started by dkessinger, Aug 25, 2010.
  1. Aug 25, 2010 at 5:53 PM
    dkessinger
    dkessinger [OP] Member
    Oregon
    2010 Tacoma
    I have a 2010 Tacoma Access 2wd truck and want to get bigger tires/rims. Can I do 16 inch with out any modifications? What would be a bigger 15" size? The stock 15" tires look small compared to the rest of the vehicle. Thanks
  2. Aug 25, 2010 at 6:09 PM
    smithrw
    smithrw Well-Known Member
    wichita, kansas
    09 tacoma sr5
    I just put some 16" eagle alloys with 235/60/16 tires. Made a huge difference on looks as well as handling.
  3. Aug 25, 2010 at 6:13 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    235/75/15
  4. Aug 27, 2010 at 8:43 AM
    selkins
    selkins Member
    Dayton, OH
    2013 Tacoma Double Cab 4x4 SR5 V6
    Would this cause the speedomter/odometer to be off?
  5. Aug 27, 2010 at 8:48 AM
    smithrw
    wichita, kansas
    09 tacoma sr5
    very slightly off since they are 60 series and the stock tires were 70's. You can check the tire fitment thread.
  6. Aug 27, 2010 at 9:14 AM
    selkins
    selkins Member
    Dayton, OH
    That's what I was thinking. I just got my new Tacoma, and the only thing I don't like is the ugly 15" steel rims that came on it. There was no upgrade option available which sux. I may look to see if there are any reasonably priced 15" rims that will fit the tires that are on it...
  7. Aug 27, 2010 at 10:56 AM
    smithrw
    wichita, kansas
    09 tacoma sr5
    There are a few but none of them will be very cheap unless you sacrifice quality.
  8. Aug 27, 2010 at 6:59 PM
    Archangel
    Charlotte, NC
    13 Malibu LT
    go to tires.com and put in your vehicle information. You'll see what pulls up and you can go from there. You can also find a wheel online and take it to Discount Tire, and as long as it's in current production or not an exclusive wheel, they can get it. Hope this helps, and good hunting. Be sure to post pics of what you decide!!
  9. Mar 2, 2012 at 8:48 AM
    franken 831
    franken 831 Member
    frank
    ontario
    stock 2.7 litre
    new 16inch wheels and p235/70r16 goodyear wrangler silent armor
    You can fit a 16 inch rim on this former 15 inch 5 bolt hub. It is from toyota and was used on their 2000 to 2005 highlander suv. It is 5 bolt and clears the front brake calibers by about 1 inch. It is part #42611--48010
    I am fitting 235/75r16 tires----but have not tested it yet as i pick it up today. It adds a lot to this truck. the speedo will be out a bit, reading slower than you are actually going
    FRANK
  10. Mar 2, 2012 at 11:05 AM
    franken 831
    franken 831 Member
    frank
    ontario
    stock 2.7 litre
    TRY THIS 16 INCH RIM FROM TOYOTA---PART #42611-48010
    IT FITS THE 5 BOLT HUB OF THE 2WD TACOMA. IT WILL TAKE A BIGGER TIRE BUT THE 245/75916 TIRE IS A TIGHT FIT AND A 225 OR 235 MIGHT BE BETTER. SHOULD COST ABOUT 75.00 PER RIM.
    THIS RIM WAS ON THE HIGHLANDER SUV AND LOOKS GOOD.
    FRANK
  11. Mar 5, 2012 at 12:57 PM
    franken 831
    franken 831 Member
    frank
    ontario
    stock 2.7 litre
    I JUST TESTED MY 2010 TACOMA 2.7L 2WD, FITTED WITH THE 16 INCH RIM I MENTIONED FROM TOYOTA
    I ENDED UP WITH GOODYEAR WRANGLER SILENT ARMOUR TIRES IN 235/70R16. I HAD WANTED 75R SIZE WHICH WOULD ADD ABOUT ONE HALF MORE HEIGHT, BUT COULD NOT GET THEM. THE 70R SIZE HAS LOTS OF ROOM IN THE WHEEL WELL, AND GIVES THE TRUCK OVER AN INCH MORE GROUND CLEARANCE---ALMOST THE CLEARACE OF THE 4WD.
    iT HANDLES VERY GOOD, BUT REQUIRES A BIT MORE 3RD GEAR FOR PASSING, AND THE SPEEDO READS ABOUT 7% SLOWER THAN IT IS ACTUALLY GOING. IT ADDS A LOT OVER RUTTED BUSH ROADS AND AND LOOKS TERRIFIC COMPARED TO THE WIMPY STOCK 15 INCH 215/70R15 TIRES.
  12. Mar 17, 2012 at 7:22 PM
    franken 831
    franken 831 Member
    frank
    ontario
    stock 2.7 litre
    just sold the 15 inch wheels fom my 2010 tacoma for a good cash price thru kajiji with no photo.
    The new 16 inch rims and 235/70r16 wrangler silent armor tires are excellent and give more than one inch more ground clearance, the truck now looks like the 4wd version, the new wheels beef it up a lot. very pleased with the larger wheel gambit.
    The 16 inch rims are from the the 2003 toyota highlnder and cost me $80.00 each at my ontario dealership. the look very good with the big tires.
  13. Mar 17, 2012 at 7:29 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    http://www.toyotapartszone.com/oem/toyota~wheel~disc~42611-48010.html
    Your part #s are off.
  14. Mar 18, 2012 at 5:34 PM
    franken 831
    franken 831 Member
    frank
    ontario
    stock 2.7 litre
    NO the part number of the wheel discs (rims) is correct here in Ontario. I am running them on my 2010 2wd tacoma . formerly 15 inch.
    The part number is on my march 1 parts invoice, in my hand. The part # is 42611-48010 . The parts department said they were formerly on the highlander suv years 2000 to about 2004.
    they fit the tacoma as indicated in 16 inch.
    Frank
