2010 4Runner Mirrors Worked!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blacked Out TRD, May 12, 2010.
  1. Oct 8, 2014 at 3:50 PM
    #441
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    ah ok, and from looking it seems the oem switch has a 15 minute timer built into it, I could be wrong though.
  2. Oct 8, 2014 at 4:07 PM
    #442
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    Your right, it has a timer if you forget to push the switch to turn them off. I agree with you on the new style mirrors, they look similar to the ones on my IS250.
  3. Oct 8, 2014 at 4:23 PM
    #443
    nad
    nad mmmm tacos!
    Jordan
    Canada
  4. Oct 11, 2014 at 10:55 PM
    #444
    BigE
    BigE Well-Known Member
    Eddie
    PNW
    14 MGM DCLB TRD sport
    check out my build page
    Ok a little help here.. So I have a 14' Trd Sport Tacoma that has the side mirrors with the turn indicators in the front, that's the only thing that it has, and they are electronically adjustable.. So theoretically what parts would I need to make them heated? Living in the PNW calls for a needed heated mirrors. I know that the 2010 4runner mirrors look identical in size and shape, but what would I need to do electrically speaking to allow them to mount to my truck? Like could I use my wiring harness? would I need to run extra wires for the heat to work? I know I'll need a switch from a Highlander to fit into the slot right next to the fog light switch to the left of the steering column. Thanks in advance and sorry for the essay..
  5. Oct 12, 2014 at 5:41 AM
    #445
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Did you check out this thread?
    http://www.tacomaworld.com/forum/2n...em-heated-mirrors-diy-mod-19.html#post9294187
    Shawn.
  6. Oct 12, 2014 at 10:25 AM
    #446
    toyotaman29
    Darrell
    North Carolina
    The 4runner mirrors will bolt on your mounts and your wiring harness should work for the power movement of the mirrors and you will need 2 or 3 wires for each side for heat and foot lamps. I had a friend of mine at a car audio shop wire mine, all wires can be installed in the wire loom through the door hinge area, so it looks factory installed with the Highlander switch.
  7. Oct 14, 2014 at 9:55 PM
    #447
    BigE
    Eddie
    PNW
    I did, but I noticed that they were using the mirror itself from the sienna.. Is there a difference between using the 4runner mirror and the sienna? Like is one more compatible than the other? That's what I would like to know. Personally, I'd rather not mess with the internals of the mirror but rather add a few wires to the loom and have a better fit and finish. But I just want to be informed before I start dropping money into this project and then half way through, realize that I should've gone the other route.
  8. Oct 14, 2014 at 10:10 PM
    #448
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Well the 4Runner is the whole housing...when the sienna is just the mirror insert itself
  9. Oct 16, 2014 at 5:53 PM
    #449
    BigE
    Eddie
    PNW
    So pretty much, the 4Runner is a simple plug and play + add a few wires and you're good to go?
  10. Oct 16, 2014 at 5:55 PM
    #450
    Jerez
    Rod
    Ontario Ranch
    Estock
    nope.
    it bolts up perfect with your stock "L" mirror brackets on the doors but its not plug and play at all...need to either cut and wires and solder them together or make youre own plugs etc.
  11. Oct 23, 2014 at 9:48 PM
    #451
    Rockdwg
    Rockdwg Well-Known Member
    Rapid City, South Dakota
    2008 Tacoma DCSB trd off road
    so this will fit a 2008 Tacoma DCSB right? the 2010 4runner mirrors that is? with the L bracket and all the wiring. and the highlander switch?
  12. Oct 23, 2014 at 10:32 PM
    #452
    Jerez
    Rod
    Ontario Ranch
    Estock
    yes but you have to you your stock L brackets (4runners are different) and run your own new wiring into both doors
  13. Oct 24, 2014 at 11:03 AM
    #453
    nad
    nad mmmm tacos!
    Jordan
    Canada
    Blais03 likes this.
  14. Oct 24, 2014 at 11:28 AM
    #454
    Jerez
    Rod
    Ontario Ranch
    Estock
  15. Oct 24, 2014 at 11:42 AM
    #455
    nad
    nad mmmm tacos!
    Jordan
    Canada
    I dont quiet understand what you mean, Im referring to the metal bracket inside with the three screw holes. Are you referring to the L arm?
  16. Oct 24, 2014 at 11:46 AM
    #456
    nad
    nad mmmm tacos!
    Jordan
    Canada
    Both my 4runner mirrors and my tacoma mirrors look like the first picture
  17. Oct 24, 2014 at 12:18 PM
    #457
    Jerez
    Rod
    Ontario Ranch
    Estock
    Oh my bad...i mis understood lol
    They're where different with mine. Had to use the Tacomas because something about the 4runners doesn't line up straight iirc
  18. Oct 24, 2014 at 12:24 PM
    #458
    nad
    nad mmmm tacos!
    Jordan
    Canada
    I could still run into that, I just took a quick look at the brackets, I've got my fingers crossed that this install goes smooth. Thanks everyone for all the info posted so far. Considering those mirrors only cost $135 Its not too much of a risk.
  19. Oct 24, 2014 at 1:03 PM
    #459
    Jerez
    Rod
    Ontario Ranch
    Estock
    They're ok mirrors...
    My problem was that they shook way too much on the hwy. could t tell what cars where behind me lol
  20. Oct 24, 2014 at 6:41 PM
    #460
    nad
    nad mmmm tacos!
    Jordan
    Canada
    Just finished installing, they matched up perfectly. Must not be the exact same as the pair you had. No shaking either. Only thing I notice is the passenger mirror has warped affect to it. May be a cheaper quality mirror.
