2010 4WD Crew cab Wheel Selection?
Discussion in 'Wheels & Tires' started by Area22, Nov 25, 2010.
  1. Nov 25, 2010 at 10:38 AM
    Area22
    Area22 [OP] Member
    I just purchased a 2010 4wd crew cab and the first thing I want to do is upgrade the wheels and tires. In looking into this it seems it's not as easy as I thought it would be. I found some nice looking 17" Moto Metal 957's but I don't kmow if I need to get a lift kit so they'll fit right and if I don't lift the truck will they stick out too much with 275 70/17 tires. The guy at 1-Stop Rim Shop said it's hard finding after market wheels to fit this truck.
    If anybody has some pics with this truck with after market wheels I would ove to see them.
    Thanks!
    My head is spinning.
  2. Nov 25, 2010 at 10:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    My advice would be for you to get rims with 4.5" backspacing. With this setup, you can run 265/70/17's on stock suspension or 285/70/17's with a 3" lift.
    I have no idea what the guy means by it being hard to find wheels that fit these trucks.
  3. Nov 25, 2010 at 11:44 AM
    Area22
    Area22 [OP] Member
    Keith-Thanks for the advice.
  4. Nov 25, 2010 at 11:44 AM
    zonataco
    zonataco Well-Known Member
    Is he talking about clearing the calipers?
  5. Nov 25, 2010 at 11:48 AM
    KPT
    09 Prerunner
    ^ maybe, but that's only an issue with 16" wheels.
  6. Nov 25, 2010 at 1:10 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    you came to the right place for info. I believe you may have some rubbing issues with that size tire on stock suspension.
  7. Nov 25, 2010 at 4:27 PM
    Area22
    Area22 [OP] Member
    looks like I should start with a lift kit. Any suggestions?
  8. Nov 25, 2010 at 4:51 PM
    KPT
    09 Prerunner
    Check out the suspension forum. There is a stickied thread with all sorts of info.
    Two good quality lifts that are relatively inexpensive are bilstein 5100 shocks, or OME shocks and springs.
