2010 4x4 sr5 problem at 2000 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by electricworktaco, Nov 27, 2010.
  1. Nov 27, 2010 at 12:16 PM
    electricworktaco
    electricworktaco [OP] Member
    Ontario, Canada
    2010 sr5 4x4
    got my 2010 4x4 sr5 2 months ago.Discovered this shortly after.
    around 2000 rpm when i turn right or just move the wheel slightly to the right
    there is "feedback" or grabbing on the wheel.no noise or vibration.doesn't matter what speed i'm at, road surface does, seem worst going uphill.
    went back to dealer 3 times, first technician test drove it, he sad yes its there.
    took it back for a full day so they can investigate it, the changed my warped rotors [wtf ??]
    no change, but how come my rotors warped after a month.
    then we test drove a new 11, it did the same thing not as bad as mine.
    they opened a case # or something like that.
    i like the truck everything else is great so far.But i am not happy, brand new truck and have this problem already.
    found the tsb 0119-10-2 but i have no rattle noise.
    Manager was checking tsbs but he did not find this one or did not show it to me.I think i should get it done see if that helps.
    Anyone had similar problem?
    Could my rotor warp due to washing the truck right after driving an hour?
    thank you guys
  2. Nov 27, 2010 at 12:30 PM
    electricworktaco
    Ontario, Canada
    2010 sr5 4x4
  3. Nov 27, 2010 at 12:32 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Weird... Never noticed it in my 2010. I will be looking for it now tho.
  4. Nov 27, 2010 at 12:39 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    a caliper may be hanging up a lil bit causing heat, hence the warping.
  5. Nov 27, 2010 at 1:14 PM
    electricworktaco
    Ontario, Canada
    2010 sr5 4x4
    bump
    anyone had 01119 tsb done?
  6. Nov 27, 2010 at 1:17 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    What is the tsb 0119-10-2? I have a few noises around 2000 rpm that no one has yet to explain.
  7. Nov 27, 2010 at 1:30 PM
    electricworktaco
    Ontario, Canada
    2010 sr5 4x4
    01119 for steering rattle noise, i dont have a noise on bumps, but thought maybe that is a side effect.
  8. Nov 27, 2010 at 1:40 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    I just read up on it. I know I have that issue for sure. Too bad I'm way out of warranty.
    I know the feeling in the steering wheel. I would love to have that gone. It does bother me how loose the steering can feel on a rough road. I tend to believe the other noise is the brakes. When I even lightly step on the brakes the noise goes away.
    That doesn't bother me so much, I would rather have them built loose so when they pack up with mud they still work... Kinda like the 1911 and AK47 philosophy.
  9. Nov 29, 2010 at 4:00 PM
    electricworktaco
    Ontario, Canada
    2010 sr5 4x4
    bump
    please let me know if you have any feedback or grubbing on your sterring wheel at 2000 rpm.Mine is only if i turn it to left.
    thanks
  10. Nov 29, 2010 at 4:01 PM
    jandrews
    '09 FourDubDee TRD OR
    I believe this is why it comes with a warranty...
