2010 Insturment Lights Issue
Discussion in 'Technical Chat' started by woode87, Mar 3, 2013.
  1. Mar 3, 2013 at 11:10 AM
    woode87
    woode87 [OP] Well-Known Member
    Eric
    Maryland, USA
    2017 Toyota Tacoma TRD Off Road DCSB Inferno 4x4 AT P&T
    Leather, Debadged, LEDs, Tonneau, Pop & Lock, WeatherTech
    My truck randomly has these lights click on, and I can hear a *click* from the glove box area. They flick on and off (and my speedo drops to 0) as if something is loose but I don't know what it could be? Is there one fuse that controls all of these?
    Uploaded with ImageShack.us
    It is worth noting that I was in 2WD, "D", going about 10mph when I took this photo
  2. Mar 3, 2013 at 12:43 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    What wiring mods have you done to the truck?
  3. Mar 3, 2013 at 12:49 PM
    woode87
    Eric
    Maryland, USA
    Yellow wire mod (i double checked and it's still good) and an aftermarket stereo/amps.
  4. Mar 4, 2013 at 10:22 AM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Im getting the same problem with my 05 Reg Cab
    my speedo makes a clicking sounds sometimes my tach if off or don't work sometimes my speedo will be at 15 at a complete stop
    whats the yellow wire mod?
    Im thinking the previous owner wired something wrong on my truck
  5. Mar 4, 2013 at 10:39 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    It would most likely be a loose connection, or perhaps a bad relay. All of those warning lights get their power from the same source, and since they are on, it looks like you are having something telling the cluster to turn on those lights. Looking at the wiring diagram for the control of those warning lights, it appears that they are all from different modules. Since they are from so many different controls, you may have a main relay that powers those units, failing intermittently, or perhaps a major ground that is loose. Another option is a bad harness connection. I would look behind the glove box (Since you mentioned hearing a noise there) and start looking around.
  6. Mar 6, 2013 at 9:39 AM
    woode87
    Eric
    Maryland, USA
    I narrowed the problem down, however now I am more confused.
    I just happened to adjust my steering wheel so I could try to figure out why this problem is happening (look at fuse box) and noticed that when I move my steering column - it triggers it (or fixes it).
    What in there would cause all the above to happen (as well as lock out my gear selector and not allow me to start)?
