2010 sport bolt pattern?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Detective_Dan, Dec 21, 2010.
  1. Dec 21, 2010 at 5:08 AM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
  2. Dec 21, 2010 at 5:10 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Dec 21, 2010 at 5:38 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x2 275 might be cutting it too close. Try to find some rims with 5 or 4.5" backspacing and you should be able to run 32's in a 275 width no problem.
  4. Dec 21, 2010 at 6:30 AM
    Detective_Dan
    Colorado Springs
    i appreciate the quick responses. i just think personally a 285 is too big and not practical as i do not offroad frequently. do you think a 3" 5100 lift will look good with 265's?
    pics anybody with bilstein 5100's with 265's? :D
  5. Dec 21, 2010 at 6:33 AM
    TexasTacoma37
  6. Dec 21, 2010 at 7:48 AM
    Detective_Dan
    Colorado Springs
    thanks KPT.
    what size 265's could i run with the wheels in my first post? i dont completely understand the whole tire size thing. i looked it up but still dont get the difference. so what size 265's could i run with the wheels in my first post?
  7. Dec 21, 2010 at 7:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    265-70-17
  8. Dec 21, 2010 at 7:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can run a 275 safely on that wheel if you'd like. It's got 4.5" of BS.
  9. Dec 21, 2010 at 7:56 AM
    Detective_Dan
    Colorado Springs
    thanks 98
    i understand the 265 and the 17 part of the tire size but what does the 70 mean?
  10. Dec 21, 2010 at 8:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    The 70 is the aspect ratio. It means that the sidewall is 70% of the width. In this case, the side wall is 185.5mm tall. Times that by 2 (=371mm) and add you rim diameter (17"=431.8mm) to get the total height of the tire (371 + 431.8 = 802.8mm or 31.8")
  11. Dec 21, 2010 at 8:04 AM
    98tacoma27
    Ben
    Not Beech Creek
  12. Dec 21, 2010 at 8:05 AM
    TexasTacoma37
    The sidewall height is 70% of the width of the tire.
    Ahh, beaten.
  13. Dec 21, 2010 at 3:11 PM
    Detective_Dan
    Colorado Springs
    thanks for all the help ben. if my tax return is as good as i am hoping for, i will be ordering these wheels and some MT tires to go with
  14. Dec 21, 2010 at 9:19 PM
    Detective_Dan
    Colorado Springs
    so your saying on bilstien 5100s up front set at 2.5 and rear tsb i could run a 275/70/17 on the above wheel with no rubbing issues?
  15. Dec 21, 2010 at 9:22 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Yea you can run that
  16. Dec 21, 2010 at 9:24 PM
    Detective_Dan
    Colorado Springs
    those wheels have a 4.5 backspacing
  17. Dec 21, 2010 at 9:26 PM
    Detective_Dan
    Colorado Springs
  18. Dec 22, 2010 at 6:19 AM
    TexasTacoma37
    Wheels in the original post show to have a 5.47" backspacing.
  19. Dec 22, 2010 at 10:19 AM
    Detective_Dan
    Colorado Springs
    this is pulled from the link in original post:
    Backspacing (in)4.500 in.
    open the link and click overview underneath the pic of the wheel
    its conflicting though, cause at the top i see it says 5.47 and in the overview it says 4.5 so idk. a couple of posts up i found these wheels on a taco but it looks like he is running 265's but i know the wheels will fit
    i would say it has 4.5 in backspacing because i would believe the full specs over the brief ones in the title. what do you all think?
  20. Dec 22, 2010 at 10:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Put it this way, if you can get them in 4.5" BS then get those if you want to run the 275.
