2010 spring TSB before / after (1.75")
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MIL_SPEC, Apr 18, 2010.
  1. Apr 18, 2010 at 8:41 PM
    MIL_SPEC
    MIL_SPEC [OP] Member
    Derek
    Boise
    Barcelona Red Toyota Tacoma TRD Off Road
    Hey guys,
    I'm new here and I bought a 2010 TRD OR DC back in January and have had no complaints about the Tacoma minus the rear spring TSB that many members have mentioned in other posts. I finally had it done at 1800 miles thanks to some helpful threads and also installed 5100's up front at 1.75" with 265/75/16 BFG AT's. No vibrations, no alignment issues, and most importantly, no bottoming out :)
    Before:
    After:
    The Post TSB pictures have no Husky in the back because the dude couldn't jump in after the lift! I'll have to condition him a bit because it's going to be his home for a long time. Thanks TW, the truck rides rock solid and I couldn't be happier. :D
  2. Apr 18, 2010 at 8:45 PM
    91Toyotabogger
    91Toyotabogger "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    nice truck
  3. Apr 18, 2010 at 8:52 PM
    richfish68
    richfish68 Well-Known Member
    HOLLOMAN AFB
    2010 DC 4x4 Trd Sport SWB
    5100's @1.75" 18" Rockstars, 265/65/18 BFG AT's, N Fab Nerf Bars, 20% Tint All around, Viper 5901 Remote Start, Black Badges, Fog Light Mod w/ Luminics Pure Blue bulbs, Flowmaster, BHLM w/ D2S Retrofit projectors, Weathertech's, Alpine swr-t10
    looks solid.. my billies are goin on in a cpl weeks..
  4. Apr 18, 2010 at 9:04 PM
    ROADHOG
    ROADHOG Well-Known Member
    Valley of the sun
    2010 Dbl cab 4x4 TRD Offroad fully loaded
    Big block Chevy engine(just kidding)
    Did mine 2 weeks ago.TSB leafs,5100"s@1.75 and 265/75/16 BFG AT's+rims.No rubs,vibes,etc.Totally blows the stock setup out of the water!I love it!
  5. Apr 18, 2010 at 11:14 PM
    MIL_SPEC
    Derek
    Boise
    Nice truck Hog, I've always liked the Magnetic Gray color.
  6. Apr 19, 2010 at 7:39 AM
    richfish68
    HOLLOMAN AFB
    both looking good, love the white lettering on the bfg's....
  7. Apr 19, 2010 at 8:10 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I want to do this to my 06 double cab, but am on the fence about putting the 5100's at the 1.75 setting due to reported rough ride from pre-loading of the stock coil. My wife and I like the stock ride, and wouldn't mind a little stiffer...how would you compare the two ride wise? I am considering the 5100's with a lift coil, and set at 0.85 to reduce the amount of pre-load...
  8. Apr 19, 2010 at 10:05 AM
    MIL_SPEC
    Derek
    Boise
    Great thing about the 5100's is that they are adjustable. If you dont like the 1.75" then you can always move up or down depending on your own comfort levels. I think the 1.75" with the TSB is the way the truck should have came from the manufacturer; whether that's aesthetically, bed functionality and stiffness of ride.
  9. Apr 19, 2010 at 10:41 AM
    Fabulous
    Fabian
    Calgary, AB
    My truck is an 06, so the TSB is a no go for me...thinking of 1.5, or 2 inch AAL. Don't think I want to go to 2.5 on the 5100's...just want it to sit right afterwards with a bit of rake like it has now, and a nice ride.
  10. Apr 19, 2010 at 11:08 AM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    I have the 5100s at 1.75 and the rear tsb. sometimes i think about dropping it to .85 to soften the ride a little. i love my taco with the little extra lift.
    glad to see some pics of this setup with KOs. i'm gettin KOs after i get full use out of my rugged fails.
  11. Apr 19, 2010 at 12:01 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    How much was the lift?
  12. Apr 19, 2010 at 12:09 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I think you'd be surprised dropping it to .85. I ran it at 1.75 for a week but had to drop it to .85 to help with eliminating the front diff bearing vibe. I wish I could take it back up to 1.75 because the ride was so much softer. At .85, you get more feel of the road and bumps but the handling is tighter. At 1.75, it handles bumps much smoother but feels looser on the freeway and in the turns.
  13. Apr 19, 2010 at 2:13 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    It is a softer ride set at 1.75" than it is at .85"? That doesn't make sense to me because at 1.75" the spring is compressed more and the shocks are preloaded more which reduce the amount of travel. If this is the case then I absolutely will set mine at 1.75", just worried about it being too stiff.
  14. Apr 19, 2010 at 2:33 PM
    MIL_SPEC
    Derek
    Boise
    TSB was free from Toyota, but took a bit of time to get it done.
    173 for Front 5100's courtesy of Downsouth Motorsports
    55 for labor
    55 for Alignment at Les Schwab
    =283.00
  15. Apr 19, 2010 at 2:33 PM
    NJ92783
    NJ92783 Well-Known Member
    NJ
    (sold) 2010 Super White DC TRD Sport
    Both trucks look sweet in the pics. I have 5100's on order from DSM and will be doing the TSB at the same time. Cant wait!
  16. Apr 19, 2010 at 3:08 PM
    05Moose
    Jim
    I know. That's what I read about before. But in that week I tested them out on both the freeway (hilly freeway up here) and on rough back roads (windy, bumpy 2-laners).
    Prior to the 5100's, the harsh bumps on the freeway were just that...very harsh and bouncy (due to worn out shocks). Back roads were very bumpy.
    At 1.75, almost didn't notice the major harsh bump on the freeway. Before, my wife would have to plug the hole on her mocha cup to keep it from splashing out. At 1.75, hardly even noticed that bump (actually, it's sinking pavement where the truck drops down on a turn then hits the higher pavement). No need to worry about spilling the drink. It seemed like the suspension had more room to absorb the shock (due to the truck sitting higher would be my guess). On the back roads, I could hardly feel any of the bumps. The ride was so smooth...but not as tight in the steering/handling. Overall, you feel less bumps/potholes which leads to a smoother ride.
    Now at .85, she has to watch the spilling of the mocha on that bump again on the freeway. Still nowhere near as much as before the new shocks. But a definite harsher bump than at 1.75. Back roads are a little more bumpy again. You definitely "feel" more of the road at this setting than at 1.75. Thus, it's not as smooth of a ride.
    I am curious if those other people who claim it is harsher at the higher settings actually drove their truck for awhile at both settings. I know they said it would be rougher at 2.5, but 1.75 compared to .85? I just don't remember specifically. But I now know from personal experience. I'm still debating going back to 1.75 and dealing with the grind/vibe because I still can't believe the difference in the two settings.
    If you change them yourself, give it a try and drive it awhile (BTW, I had an alignment done at both settings, so you can't discount it for that). I really would like to hear others' opinions and see if they agree.
