2010 Taco aftermarket wheels
Discussion in 'Wheels & Tires' started by TacoLover13, May 16, 2011.
  1. May 16, 2011 at 1:02 PM
    TacoLover13
    TacoLover13 [OP] Member
    EvilTaco
    Orange County, CA.
    2010 Tacoma 5 lug
    3" lift kit, limo tint back & access cab windows medium tint driver, passenger sides, limo tint sun strip
    Hello all,
    I recently just got 3" lift installed on my 2010 Toyota Tacoma Xtra cab w/ Bilstein shocks F&B, LOVE the way it rides already.
    I have my 31" BFG A/T's & aftermarket steel wheels all ready, however the wheels do not fit due to the brake caliper being thicker than yrs. past. (rubs inner wheel.) What size / dimensions of a wheel would I need?
    Are there any options? Ideally I would LOVE to stay w/ BLK wheels? Any info you can provide is greatly appreciated.
  2. May 16, 2011 at 1:03 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    www.4wheelparts.com has a lot of wheel options. You can narrow it down by size, color, etc.
    4-4.5" backspacing is what u should get for best fitment/least rubbing. They need to be atleast 16" in diameter and 8-9" wide is generally prefered
    Most aluminum wheels will fit fine. I dont know of any steel wheels that fit our trucks
  3. May 16, 2011 at 4:17 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not on a 5-lug.
    He can fit 15's fine. and stock backspacing on 5-lugs is 3.75", so you would need something in the 3.25-3.75" range.
    Stock 5-lug rims are 6" wide I believe....
    Op what are the specs of the wheels you are running now....?
  4. May 16, 2011 at 4:34 PM
    TacoLover13
    EvilTaco
    Orange County, CA.
    2010 Tacoma 5 lug
    Thanks for any and all info....Have stock wheels / tires that came with the truck.
    Going w/ 31" BFG A/T's, problem being w/ wheels due to brake caliper being bigger on 2010's. Was told wheel spacer would break and do not want to grind down to calipers.
    Would proper amt. of back spacing fix the problem so wheels can fit?
  5. May 16, 2011 at 4:35 PM
    KPT
    09 Prerunner
    I'm confused.....you have the 31's on the stock wheels, and the stock wheels are hitting the brake caliper now? :confused:
  6. May 16, 2011 at 4:47 PM
    TacoLover13
    EvilTaco
    Orange County, CA.
    2010 Tacoma 5 lug
    No sorry, still have original stock wheels & tires on it from factory, only lift has been installed.. Waiting to see what wheel options are so we can get the tires & proper wheels installed.
    Wheels we ordered were hitting brake calipers.
  7. May 16, 2011 at 4:49 PM
    KPT
    09 Prerunner
    And what was the specs of the wheels that were hitting the caliper?
    diamter, width, backspacing, offset...
  8. May 16, 2011 at 5:00 PM
    especk
    Erik
    Redding, CA
    my bad - I didnt even see that he was 5 lug. I'll shut up now :frusty:
