2010 Taco leaving oil spots on floor
Discussion in 'Technical Chat' started by Toyo_Jet, Jan 17, 2010.
  1. Jan 17, 2010 at 5:09 AM
    Toyo_Jet
    Toyo_Jet [OP] Well-Known Member
    Shane
    Flatlands of Indiana
    10 4X4 V6 SR5 access Cab
    2.7L 4wd Std Cab, about 2600 miles. Oil dripping off of left front lower control arm bushing / mount. Near as I can tell, its coming from the steering rack. PS fluid is a hair low. Anybody else?
    Kinda blows my reason for buying a Toyota outa the water. Off to the dealer we go.
  2. Jan 17, 2010 at 5:42 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I've never bought a new vehicle that I didn't have to take back for at least one thing.
  3. Jan 18, 2010 at 2:58 PM
    Toyo_Jet
    Shane
    I dropped the front skid plate so I could see what is leaking. It's the steering input shaft seal, where it goes into the rack. I see a new rack in my future. Goes in tomorrow.
  4. Jan 19, 2010 at 9:42 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Mine has 2,400 miles and see tranny oil on the garage floor (first time in 3 Tacomas ('01, '05, '10) to see any leak... 245,000 miles between them... Just back from the dealer and reports that an O-ring where the speedometer cable connects to the tranny needs to be replaced... no biggy, but they have to order it.
  5. Jan 19, 2010 at 9:58 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    It may sound crazy but I actually like when shit breaks under warranty. You have the hassle of dropping it off in the morning but getting new parts for free is cool.
  6. Jan 20, 2010 at 4:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Honestly- Who cares?? Shit breaks sometimes- and your warranty should cover that- costing you 0 dollars. It's a non issue really.
  7. Jan 20, 2010 at 5:01 PM
    Toyo_Jet
    Shane
    After hearing about legendary Toyota quality for 30 years, I care. I also care about the three trips to my Jag-off dealer to get this fixed. The purpose of posting was to see if anybody else had the problem, not whether anybody gave a $hit.
  8. Jan 20, 2010 at 7:24 PM
    David K
    O ring replaced, in 1/2 day... still had a free use of a new Toyota to do stuff today while they replaced the o-ring.
  9. Jan 20, 2010 at 7:35 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    have you jumped your truck in the past? the oil pan (on the V6's) can ram into the steering rack if the truck encounters hard vertical impacts.
  10. Jan 20, 2010 at 8:33 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I understand your upset, but every vehicle will have some sort of poblems, some start early and some start late. Just depends on your luck I guess. And to have a truck with very few miles already haveing problems (especially a Toyota) ;) is obviously not vehicle error but parts error from the factory. There are ALOT of people on here who have had none to very few problems with there 2 gens including me with none. ;)
  11. Jan 23, 2010 at 8:26 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    +1
    hundreds of thousands and vehicles produced with so many different parts, not everything is always perfect but its nice to know they fix it if its not :)
  12. Mar 25, 2014 at 3:00 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Old post revival.
    Just under 40k on my 2010, and it seems my input shaft seal is leaking also.
    Anyone else, and did you fix it yourself by installing the seal kit?, or replace the entire rack by bringing it somewhere.
    PK
