2010 Tacoma, first oil change, what kind?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eric Hodges, Dec 21, 2009.
  1. Dec 21, 2009 at 7:00 AM
    Eric Hodges
    Eric Hodges [OP] Member
    Eric
    Hurlock Md
    4x4,DC LongBed,TRD Sport
    BFG AT's 265/70/17
    Hi all, its time for my first oil change in my Tacoma, I have always used Mobil 1 synthetic in my past 3 4Runners (86,95,and 2001).
    Always had good luck, I have someone wanting me to try Amsoil?
    Any Suggestions?
    I was thinking to stick with the Mobil 1.
    Thanks,
    Eric
  2. Dec 21, 2009 at 7:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Do what you want. Either oil is good in my book.
  3. Dec 21, 2009 at 7:12 AM
    NeoMoose
    NeoMoose Possibly Batman
    Houston, TX
    2010 PreRunner DC TRD O.R.
    Kenwood eXcelon X993, Kenwood KFC-1693PS (Front), Kenwood KFC-G1620 (Rear), Luverne Black Nerf Bars, OEM Brush Guard, AFE Pro Dry S Drop-In, Some kickass wheel locks, Removed front mud flaps, All windows tinted, Anti-theft tailgate mod
    why would you want an "oversized" oil filter?
  4. Dec 21, 2009 at 7:14 AM
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    Mobil one oil + mobil 1 filter size m1-209
  5. Dec 21, 2009 at 7:20 AM
    Eric Hodges
    Eric
    Hurlock Md
    BFG AT's 265/70/17
    Damn you guys rock and are fast! I am going with Mobil and Mobil filter.Thanks all.
    Yes I use the extended performance fully synthetic.
  6. Dec 21, 2009 at 8:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 Same diameter, it's just longer.
  7. Dec 21, 2009 at 8:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    :anonymous:
  8. Dec 21, 2009 at 9:51 AM
    invisionz111
    invisionz111 Well-Known Member
    2010 DC BSP
    5100 Bilstein’s (.85) w/ Eibach Springs | ¼ inch Taco Lean Spacer | 2” Add A Leaf Springs | 5100 Bilstein Rear Shocks| Light Racing UCAs | 955 B MotoMetal Wheels | Nitto Terra Grappler All Terrain 285/75/17 | ToyTec Diff Drop | AFE Pro-Dry S Air Filter | Tint | Westin Bull Bar | Raptor Side Steps | UWS Toolbox | Weathertech Floor Mats | Weathertech Side Vents |
    Damn. I wish I had this info before getting my oil changed this morning. I will do this on my next 5000 mile change.
  9. Dec 21, 2009 at 10:00 AM
    mordicai
    mordicai New Member
    san diego
    You should do your initial 10,000 mile break-in with petroleum based oil, then switch to synthetic. Just my 2 cents.
  10. Dec 21, 2009 at 10:10 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    As far as oversized filters go, obviously more filter capacity is a good thing, but make sure you pay attention to quality first. I would rather use a normal sized K&N or Mobil 1 filter that filters down to 10 microns, than some oversized store brand that might filter down to 40 microns. If you can find a quality oversized filter then you get the best of both worlds. JMO.
  11. Dec 21, 2009 at 10:17 AM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    I would wait until at least 10K miles before switching to Synthetic, I personally think 15K is good seeing that some folks in here clain gas mileage improves up to that point.
    You want the engine to break in before going to sythetic, because some experts think that you will never give the rings a chance to seat once you use synthetic.
    I am not an expert, so I am not sure if this is true. But being a technician myself, I do understand what a break-in period is, and in my opinion, waiting a little bit is the best route to take.
    Also, 5w-30 is not recommended in my truck. I have a 4cy and factory recommends 0-20w or 5-20w. Using a thicker oil will reduce gas mileage.
  12. Dec 21, 2009 at 10:35 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    IMO, this was true years ago, but modern engines do not seem to need the break-in that the old engines needed. In fact, there are quite a few vehicles that come with synthetic from the factory. I switched my Tacoma over to Mobil 1 at the first oil change with no ill effects. Having said that, it doesn't hurt to wait until 15,000 miles to switch either. JMO. Good post.
  13. Dec 21, 2009 at 10:40 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i use castrol dino 5w30
  14. Dec 21, 2009 at 11:20 AM
    mordicai
    mordicai New Member
    san diego
    Machining is far superior today then it was a few years ago and we certainly don't see the kind of metal in the oil that we used to but I still think those rings have to seat in the cylinders and I like to break im in hard with regular oil. Most of that however is being done in the first hundred miles or less.
  15. Dec 21, 2009 at 11:23 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    +1 and welcome to TW.
  16. Aug 26, 2011 at 4:25 PM
    kungfupanda
    kungfupanda Well-Known Member
    So Cal, Cerritos
    2010 4x2 Taco TRD SPORT
    HID - Low, LED interior lights, LED license plate light, HID Yellow fog lights, Access Limited Roll Cover, Hitch/Tow Package, Ceramic Tint, Wet Okole's, Magnaflow Exhaust, DFab Bars, Bully Bar Back, HID Yellow Fog Lights
    What weight is recommended for 2010 six banger? 5w-30 for full synthetic?
  17. Sep 5, 2011 at 5:16 PM
    Allen102
    Allen102 Active Member
    If you use an oversize oil filter, won't that screw up the oil pump and flow rate?
  18. Sep 5, 2011 at 5:20 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    get a filter from Toyota
  19. Sep 6, 2011 at 2:09 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    I did my first oil change at 2k miles and put in Napa (Valvoline) Synthetic 5w-30. I'd rather run cheaper synthetic and run a shorter OCI (3k) than run a hella expensive synthetic for 10k+ miles.
  20. Sep 6, 2011 at 6:15 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Dos'nt the 2.7 four cly. require full synthetic or did that not start until the 2011s?
