2010 Toyota Tacoma Smokes Heavy climbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyota_Built_Kauai, Jun 19, 2017.
  1. Jun 19, 2017 at 10:09 PM
    Toyota_Built_Kauai
    Toyota_Built_Kauai [OP] Member
    I've just recently ran into this issue where my Tacoma would smoke heavily from the exhaust when climbing a steep hill even at 25 mph+
    So what's the problem?
    Im thinking it could be my head gasket but im not 100% sure.
    Truck has always been serviced from the Toyota Dealership here in Hawaii, and I recently had the transmission oil changed at 80K miles
  2. Jun 19, 2017 at 10:20 PM
    verminator
    verminator New Member
    Verent
    SLO, CA
    2014 4x4 V6 DC
    What color is the smoke? If it's white, it's likely a gasket leak. Is it coming out the tail pipe?
  3. Jun 19, 2017 at 10:36 PM
    Toyota_Built_Kauai
    Yeah its a thick white/greyish smoke coming out of the tail
  4. Jun 19, 2017 at 10:36 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Oil leaks, like the transmission or something else, that get on the exhaust will cause this. It smokes going up hill because of the extra load and therefor the exhaust gets hotter. The result is it burns off the oil that has leaked on there. It doesn't smoke as much or at all, or not noticeably any other time because loafing down the road at a lower rpm doesn't heat up the exhaust as much. That could be what you're seeing.
  5. Jun 19, 2017 at 10:37 PM
    TxFireman
    San Antonio, Texas
    Check to see if you have any oil film on the tailgate or rear bumper.
  6. Jun 19, 2017 at 10:42 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Sounds like possibly a head gasket, with coolant entering the cylinders. Crankcase pressure changes and does weird things, especially on an older engine with more blow-by. Increased crankcase pressure under load, and or, greater water pump pressure at higher RPMs. could be a factor.
    I'd have the cooling system properly pressure tested to rule that out.
  7. Jun 19, 2017 at 11:41 PM
    Toyota_Built_Kauai
    Checked under the hood it's the gasket there's an oil leak so already scheduled an appointment to have it repaired.
    Just curious though because the dealership here couldnt even tell me. How often are the gaskets changed? I mean for a 2010 with only 80.5K miles on it you'd think the gasket would be like new...
  8. Jun 20, 2017 at 10:26 AM
    Stocklocker
    17TRDORDCSBAT
    Some things like gaskets, age regardless of the number of miles. There are certain types of gaskets that dry out if the engine is not run regularly, and some that are simply attacked by chemicals is the air or oil etc
    For certain, they could make a gasket that would be good for 50 years, but that's not the plan.
  9. Jun 20, 2017 at 10:37 AM
    NM Lance
    NM Lance Well-Known Member
    Dumb question... Are you sure you aren't way overfilled?
