2010 TPM tire sensors
Discussion in 'Wheels & Tires' started by rotate, Feb 11, 2010.
  1. Feb 11, 2010 at 10:23 PM
    rotate
    rotate [OP] Member
    Rick
    Georgia
    prerunner SR5
    In a dillema.Want to change out stock wheels and tire on my 2010 prerunner.Info on tire rack state I cant use my metal wheel TPM on alloy and their alloy replacement TPM will not work on 2010.Any one out there encounter same problem? Any solution Thanx
  2. Feb 11, 2010 at 10:26 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    they should work on any kind of rim. there is a little rubber seal on the top lip of the TPM. just make sure the rims are TPM compatible. meaning the TPM wont interfere with mounting a tire on the rim or you'll risk busting them off.
  3. Feb 12, 2010 at 3:24 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Hi Rick, welcome! There are some ingenious ways a few members here have worked around the tpms. You can break down your current steel wheel setup and put them in a wheelbarrow tire. One TW user actually added a cool mount near his spare. There are kits that let you use your sensors in your new alloys or if you turn it a certain way & have your installer carefully put on & break down yours tires (to avoid breaking them) is another. Bottom line, there are ways around them. If you search tpms you will get lots of hits for other ideas. Good luck! :)
  4. Feb 12, 2010 at 3:46 AM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    I asked this question last month. The answer is toyota has two different tpms ... aaccording to the dealership. The angles on the TPMS are what you need to know. I went from TRD sport rims to FJ trd SE rims and they work no problem I was told that the steelies and the alooy rims have different angle TPMS valve stems. I just took my stuff to toyota and had them do it. My dealership is pretty cool here in GA
  5. Feb 12, 2010 at 5:02 AM
    rotate
    rotate [OP] Member
    Rick
    Georgia
    prerunner SR5
    Thanx for responses.Dont feel as discouraged.Josh I live in Waycross but bought my truck in Augusta.Best deal around for me.Maybe I,ll call these guys.What conscern me is the warnigs specifically state 2010 truck TPM can,t be even changed out with their after market sensor. I just dont want to open up an expensive can of worm by attempting this unless I know I can make it work
  6. Feb 12, 2010 at 5:08 AM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    Black Tape Mod - best money saving item I did.
