2010 v6 alternator died
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skiergd011013, Sep 28, 2019.
  1. Oct 1, 2019 at 5:23 AM
    #41
    JohnT43
    JohnT43 Well-Known Member
    2007 Tacoma
    Radio
    Just for grins what's the difference on a 3rd gen alternator?
  2. Oct 1, 2019 at 7:51 AM
    #42
    Muddinfun
    Muddinfun Well-Known Member
    Voltage regulation is controlled by the ECU on the 3rd gen.
    TireFire likes this.
  3. Oct 1, 2019 at 8:13 AM
    #43
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Good price summary.
    I've replaced three alternators (two were on Camrys) using all new units from Advance and AZ and have had no issues with them. I'm sure they're not Denso quality, but so far so good. When an alternator dies at 7PM, and the local store has it in stock, you go that route.
    The last alternator I had rebuilt was 20 yrs ago, bearings and brushes, and it failed about a year later- the voltage regulator stayed open and it about blew up the battery :) The local starter and alternator rebuilders have about all disappeared.
  4. Oct 1, 2019 at 8:44 AM
    #44
    chubbydude
    chubbydude Active Member
    TheDevilYouLove likes this.
  5. Oct 1, 2019 at 9:41 AM
    #45
    Steve_P
    TN
    I haven't done a Denso/Toyota, but I've replaced bearings and brushes in older alternators and it's not difficult if you have a small press, or a puller, and the splitter plates for the bearings. Sometimes the cases are hard to get apart.
  6. Oct 1, 2019 at 9:57 AM
    #46
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    While warranties are nice they don’t help you when you’re out in the boonies.
    My OEM alternator on my 07 shit the bed at 175k miles at night at about 20 degrees and in an area with no cellphone service. Luckily for me I only had to walk maybe five miles to find a farm and called a tow.
    OEM for me and I consider taking a spare on remote trips.
  7. Oct 1, 2019 at 4:28 PM
    #47
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    All good points and that is why when I go on a trip off road I carry a second battery already charged. Never know and this will get me started and out. Now That I have a boat and have seen the battery switches in them I will be adding a second battery tray under the hood and a Blue Sea M series Battery switch #6007 a 4 position. That allows me to select battery 1 or 2 or both and you wire them in parallel so 12VDC still. This model protects the ignition and alternator circuits good up to 900 Amps. Anyone that wants a second battery this works well and allows full isolation so you only drain/kill 1 battery when you are playing the audio, using lights, or another accessories. And in extreme cold allows you to use both batteries when the cranking amps are reduced. You can charge each battery separately or together. Just an additional safety consideration for you if you get way out there and alone! I do.
  8. Oct 1, 2019 at 4:34 PM
    #48
    TireFire
    Olympic Peninsula
    If I were to build an overland rig maybe but I don’t want a dual battery setup. Battery jump pack and spare alternator works better for me.
  9. Oct 1, 2019 at 7:17 PM
    #49
    Narutaki
    Narutaki Well-Known Member
    Brian
    2007 Blue Toyota Tacoma
    None
    Thanks for all the information on this post. I ordered a denso, Funny thing is that I was able to order it from Walmart! There's no core charge return though, for $205.40, $222.35 with tax. I guess I can get my OEM alternator rebuilt as a backup then?
  10. Oct 1, 2019 at 7:27 PM
    #50
    JohnT43
    2007 Tacoma
    Radio
    Good price, didn't know Walmart sold auto parts.
  11. Oct 1, 2019 at 7:33 PM
    #51
    Narutaki
    Brian
    None
  12. Oct 1, 2019 at 7:44 PM
    #52
    Muddinfun
    Walmart sells everything. You can even get a 55 gallon drum of personal lubricant.
    TacoBreaker and TireFire like this.
  13. Oct 1, 2019 at 7:50 PM
    #53
    JohnT43
    2007 Tacoma
    Radio
    Is the walmart 130 amp?
  14. Oct 1, 2019 at 8:07 PM
    #54
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  15. Oct 2, 2019 at 5:30 AM
    #55
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  16. Oct 3, 2019 at 8:55 AM
    #56
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
  17. Oct 3, 2019 at 10:18 AM
    #57
    TireFire
    Olympic Peninsula
    Muddinfun likes this.
  18. Oct 3, 2019 at 11:10 AM
    #58
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I didn't see if you guys posted this: Alternator Rebuild
    I was off-roading with @Sandman614 and my alternator gave up. After swapping batteries we got me back to an auto parts store that didn't have any in stock.
    We were able to get it off the truck, disassemble it , and discovered mud/rock mix that kept the brushes from extending. Put it back together and I've got another 50k on it.
    (knock on wood)
    Shortly after this incident @Sandman614 had to rebuild his own, so he posted the thread above which may help someone out.
    Cheers
    TheDevilYouLove and Sandman614 like this.
  19. Oct 3, 2019 at 12:51 PM
    #59
    Hawk373
    2012 TRD Sport DCLB
    I don’t have the short answer for that with an OEM replacement, but I followed @tacozord ‘s big 3 install personally.
    http://www.bodenzord.com/archives/477
    Would I be correct in saying a 240 amp alternator is rarely pushing 240 amps at driving RPMs, and an accessory would have to draw that amperage for that much current to flow?
    Dragons Taco likes this.
  20. Oct 5, 2019 at 12:44 PM
    #60
    skiergd011013
    skiergd011013 [OP] Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    did you get it yet? I just swapped out my autozone one for the denso today.
