2011 2.7l occasional backfire on startup??
Discussion in '4 Cylinder' started by TacomaBuzz, May 15, 2011.
  1. May 16, 2011 at 4:16 PM
    Black08Taco
    Black08Taco Well-Known Member
    Baltimore,OH
    09 Super White Double Cab long bed
    Stock....For now
    I have an 08. I used to get the pop on cooler mornings after sitting for a wile. I think it is unburt fuel in the cat. I let mine sit and idle for a few seconds before shutting it off. Hasen't done it in 20k miles ever since. it fixed it for me.
    I also have a K&N cold air intake. Did it before and after that was installed...
  2. May 17, 2011 at 12:49 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    when my truck was completley stock, it backfired on startup. when i took out the stock filter, it still backfired. and when i took out the secondary filter, it backfired on startup. and then i put a new muffler on, and it backfires even louder now :D
    most of the people i know with the 2TRs have this problem. seems normal i guess.
  3. May 17, 2011 at 7:42 AM
    911-3.2
    911-3.2 Well-Known Member
    CT
    Sold - 2010 Access Cab 4x4 I4 SR5
    Curt Receiver Hitch, Access Literider Tonneau
    Mine does it sometimes as well. I could be wrong, but it seems to happen if I shut the truck down immediately upon parking vs waiting a few seconds for it to idle down. Especially if I had just had to rev it a bit to inch into a spot. Either way I doubt it is anything to worry about. Just seems like a bit of leftover fuel burning off.
  4. May 28, 2011 at 7:49 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Mine only does it when its been sitting out in the cold and on a slant that makes the nose of the truck lower than the rear
  5. May 28, 2011 at 7:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    We've got two 09 2.7s at work. I drive one of them. It always runs perfect, but has the noise you describe as well. I've heard the other one start up and make the same sound. Both trucks have almost 50K on them with no drama. Just the nature of the beast I think. Sounds like crap but doesn't seem to be hurting anything.
  6. May 29, 2011 at 7:08 PM
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    I have a Tacoma 4 cylinder with 10,000 miles on it and it sometimes gives a very light pop on start up. It may seem to occur when it does not start immediately.
    Has anyone spoken to the dealer
  7. May 29, 2011 at 7:52 PM
    frog13
    frog13 Well-Known Member
    I had a dual sport bike that would do similiar things....until I rejetted to a richer mix.....all vehicles come from the factory as lean as they can make them(run)...EPA emission standards.
  8. Jun 1, 2011 at 2:18 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    No backfire or other popping sound on cold start here.
  9. Jun 2, 2011 at 9:43 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    same here my reg cab has about 8,000 miles and it does it sometimes. although its not very common nor something i believe i could reproduce for the dealer to check out or even for me to video.
  10. Jun 2, 2011 at 9:44 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i actually thought it was due to the muffler i had installed i have a flowmaster 40 and i know i lost a significant amount of back pressure doing so.
  11. Jun 30, 2012 at 10:16 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    just bought the 2009 truck with 24k. So far I enjoy running around in it.
    The backfire occurs on some cold starts and some afternoons as well leaving work.
    I'm gonna try the idle for a few seconds before cutting the ignition off after pulling into work and see if it helps.
  12. Jul 1, 2012 at 5:12 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I've never noticed mine doing this. I removed my secondary filter 30k miles ago and I always let the truck idle for about 10 seconds before shutting it down.
  13. Jul 1, 2012 at 7:34 PM
    cbass8u
    cbass8u Well-Known Member
    Pittsburgh, PA
    10 SR5 4-Banger Hand Shaker
    TRD Rims, Pioneer Touch Screen and speakers
    I've got a 2010 with about 25k on it. Mine does it all the time, and I haven't had any issues with it. It actually sounds kinda badass.
  14. Jul 2, 2012 at 5:01 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Remember these are Taco's we are talking about, sure they will pass a bit of gas.
    n2xaos likes this.
  15. May 27, 2013 at 6:24 PM
    #35
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Mine does it also, and has the secondary air filter removed. It only does it when the day I park it is warm ( for here ) 70's-80 maybe, and it goes down into the low 30's at night,it will make some type of backfire at the exact time it fires up that morning. It never does it a second time either. I alway's blamed it on some part of the cold start enricher trying to compensate for the 50 degree temp. change from when I parked it till when I started it again. Also we just put new Denso's in it, and I don't remember it ever doing this with the original plugs,but my memory ain't all that good either.
  16. Apr 5, 2016 at 7:16 PM
    #36
    n2xaos
    n2xaos New Member
    2009 Tacoma; 4cyl; 4X4; Access cab; SR5
    My Tacoma 4cyl does this, too. Like a lot of others here it hasn't set a code or caused any real issues, just pisses me off because it isn't supposed to happen. I have tried to pay attention to when/where it happens and it is always after sitting for a period, usually overnight. The only connection I have made is that when it happens the fuel is sitting at less than half so not sure if there is a connection there.
  17. Apr 5, 2016 at 10:05 PM
    #37
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Well I mentioned this issue in post 21 in 2011. I still get it during cold morning starts sometimes, but after 5 years there have been no ill effects that I am aware of.
    It's not ideal, but it doesn't bother me anymore.
    ecoterragaia likes this.
  18. Apr 6, 2016 at 9:43 PM
    #38
    Dean2016
    Dean2016 Active Member
    Dean
    2016 tacoma SR 4x4 5sp
    Same here, 2016 tacoma, on occasion, 1600 miles so far
  19. Apr 8, 2016 at 12:10 PM
    #39
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My 2012 pops on cold start. Can't actually hurt anything as it's just unburned fuel leaving the engine while it's cranking. Then it's ignited through an open exhaust valve by the burning gases exiting the engine because the AIS is mixing air into exhaust header.
    Greg
  20. Apr 12, 2016 at 5:54 AM
    #40
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Both my 05 & 08 4 cly trucks have done this. Usually it occurs after startup when rolling in first gear right when you let off to shift to 2nd. Doesn't usually do it leaving from house in early a.m., just leaving from work in afternoon.
