2011 4H won't engage anymore
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikesfarm, Dec 4, 2011.
  1. Dec 4, 2011 at 12:27 PM
    mikesfarm
    mikesfarm [OP] Well-Known Member
    Florida
    2011 4wd Tacoma AC
    I have a 2011 white gauge 4x4 Taco.
    3K miles on it. Have had it since early summer.
    Had the usual problem of difficult to engage 4x4 for
    a little while, but it went away. I did the yellow wire mod
    and had no problems with 4x4. Did not engage 4h for a few months.
    Went out today and 4h would not engage or show dash symbol that
    it was in 4h. When I would try to go to 4L it would chirp and not engage.
    I understand it will not go into 4L without being in 4H first.
    Once in a while it would engage 4L and show 4x4 symbol and 4L symbol.
    When it would not go into 4L I would have to switch back to 2H to get chirp
    to stop or disengage 4L if it went in.
    Any suggestions ? I will probably remove yellow wire mod before taking back to the dealer to avoid the obvious crap from them.
    I have had 2 other 4wds so I understand shifting into and out of 4wd.
    Thanks
  2. Dec 5, 2011 at 10:21 PM
    squamish VFR
    squamish VFR Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs, FJ manual TC conversion, basket winch front and rear, hidden hitch in the front behind licence plate. Spyder headlights, tailgate seals.
    FJ Cruiser transfer case.
    Should be under warranty, known POShit Actuators and don't let them tell you any different
  3. Dec 6, 2011 at 8:00 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I had exactly the reverse problem when it was new it would not work properly the dealer played with it twice and said nothing was wrong I picked it up tried it in the parking lot a least a dozen times drove it home and it has worked fine ever since. I really think when they are new they need to be used a lot to free and oil up every thing.
  4. Dec 6, 2011 at 8:11 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Warranty
  5. Dec 6, 2011 at 8:35 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is under warranty, so take it to them... In the future, use it at least once a month for 10 miles (per the owner's manual).
  6. Dec 6, 2011 at 10:14 AM
    Waverly
    Waverly Well-Known Member
    West Virginia
    TRD Off Road
    Hood protector Running boards Tonnuea cover
    It does not hurt anything to run in 4H for the 10 mile, each month on the hard road?
    I thought I saw on here don't do it....
  7. Dec 6, 2011 at 10:17 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    just dont take turns
  8. Dec 6, 2011 at 10:21 AM
    ak.rideon
    ak.rideon Well-Known Member
    Scott
    Seward AK
    98 tacoma sr5 limited
    98 limited with air raid throttle body spacer, volt 4300k hids, vortec muffler, magnaflow spun cat, clear corner lights, led tail lights, alpine cda-117, alpine type r 10 in a sealed box and a alpine 500w mono amp.
    ya id say its your transfercase motor. i had a 97 f150 and the t case motor went bad. id disconnect the tcase motor and see if it engages in and out. hope this helps
  9. Dec 6, 2011 at 11:21 AM
    David K
    As the others said while I was away, driving straight hurts nothing on pavement... Turning on pavement is takes more effort in 4WD as the tires cannot slip as they can on dirt or ice. Pop back into H2 when you need to turn or park.
    Who says the OP isn't in an area with dirt roads, beaches, or open fields? You get a 4WD to go four wheeling... or it the roads are too difficult to drive in 2WD... like during snow snorms. I wish I had more dirt roads close to me... pavement is so... unnatural!:D
  10. Dec 8, 2011 at 6:16 PM
    TTKA Tacoma
    TTKA Tacoma New Member
    Tennessee
    08 TRD Sport XS-P Package 4x4
    Borla Cat-back exhaust, 18in Enkei wheels
    I have a 2008 Tacoma with a little less that 50,000 miles on it. The 4WD indicator light constantly flashes and the 4WD will not engage. Any ideas as to why?
  11. Dec 10, 2011 at 5:42 PM
    4X42HEL
    4X42HEL Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    Well, i have never had a problem switching into 4wd. I have a 2010. Is this a common problem?
    Also, I think people really overrate the whole "drive on pavement" thing.
    Unless you are in 4wd on a speed track going 100mph around corners, the t-case should be fine. I dont recall reading anything in the owners manual about this.
    Unless the taco has a unique problems with this. I have had several trucks and never even thought about not turning in 4wd.
    If I am missing something, please advise.
  12. Dec 10, 2011 at 5:45 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    You are. Its every 4x4 that will have that problem.
    In 4wd the front and rear tires have to move the same distance due to the lack of a central differential. Think about how much further the front tires move than the rear tires in a sharp turn.
  13. Dec 10, 2011 at 5:50 PM
    4X42HEL
    San Diego
    I get that, and its a valid point, but I think people over-emphasize this. I never had a bad experience (knock on wood).
    Granted its not something I do regularly, I would be pretty upset if my tcase tanked because I drove on 4hi on pavement. I would say thats unacceptable.
  14. Dec 10, 2011 at 5:52 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Turning on dry pavement is the problem .
  15. Dec 10, 2011 at 5:54 PM
    brp
    brp Well-Known Member
    It is kind of weird that Toyota does not make a bigger deal of the 4WD on pavement "problem." Do you think they get a bunch of ruined T-cases in because people leave it in 4H all winter, for example.
    I don't think it is unreasonable for the average consumer to think they will just put it in 4H and leave it there for winter. The dealer never said anything to me about it.
  16. Dec 10, 2011 at 5:56 PM
    OZ-T
    Peter North
    British Columbia
    Why would you engage 4x4 " for winter " if there was no snow on the ground ?
  17. Dec 10, 2011 at 6:01 PM
    4X42HEL
    San Diego
    This is sort of my thinking as well....
    I mean, if I was the manufacturer, and I lost a ton money (not saying Toyota does) replacing T-cases because of this issue, then I'd put some sort of sensor that somehow checks for binding and 'gives slippage'
    Outside of this forum, I have never heard of this issue. I am not saying it isn't possible, because it is by general physics But I duno that I would even think twice about this. Where I live, at least half the vehicles are trucks, and most are 4WD, and I never once heard anybody bitching about losing a T-case. At least, not anybody who didn't know that it was their hard-core wheelin on the weekend that caused it.
    This really has me intrigued because I am very familiar with 4WD setups and differentials and the whole concept of tires rotating different speed on the same axle.
    Anybody have first hand experience losing a t-case and directly related it to 4WD on pavement?
  18. Dec 10, 2011 at 6:42 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Mine has been weird since day one.
    I came from Jeeps with twin sticks so I thought that this was the nature of these nasty electric controls.
    I do everything, roll forward/back, neutral with clutch depressed, etc, etc.
    When it's being particularly stubborn I have to shut the rig down and then restart.
    That usually does it.
    I always, eventually win, but it's a PITA.
  19. Dec 10, 2011 at 6:50 PM
    4X42HEL
    San Diego
    Ok, this brings up another question I have. The front axle actuator, it is electric right? I have delt with heat actuators and they miserable.
  20. Dec 10, 2011 at 6:55 PM
    OZ-T
    Peter North
    British Columbia
    I only have an issue engaging 4wd if I am turning under power
