2011 4H won't engage anymore
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikesfarm, Dec 4, 2011.
  1. Dec 10, 2011 at 6:59 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Engage on the fly ?
    I wouldn't even attempt it with mine.
  2. Dec 10, 2011 at 7:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    We are talking 4H here right ? I lock it in all the time up to 60 kph
    Maybe that's why you are having so much trouble
  3. Dec 10, 2011 at 7:11 PM
    jflan
    Vancouver, WA
    Yeah, the on-the-fly comment was pertaining to 4H.
    But 4L is way more stubborn. ( at a stop, with the drivetrain unloaded of course)
  4. Dec 10, 2011 at 7:13 PM
    OZ-T
    Peter North
    British Columbia
    Have you tried going from 2H to 4H while moving ?
  5. Dec 10, 2011 at 7:14 PM
    jflan
    Vancouver, WA
    Yeah, but not very fast.
    Sub 5 MPH.
    Getting into 4H is not too bad, it's 4L that's a pain sometimes.
    Edit:
    And I'm always on dirt or snow.
    I can get it, I just have to shut the friggin engine off sometimes.
  6. Dec 10, 2011 at 7:25 PM
    OZ-T
    Peter North
    British Columbia
    Odd , that sucks
  7. Dec 10, 2011 at 7:29 PM
    jflan
    Vancouver, WA
    Yeah, it sucks, but I'm over it.
    I was programmed on WWII 4WD technology, so this is a minor inconvenience.
  8. Dec 10, 2011 at 9:32 PM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    Procedure:
    Stop
    Neutral
    Push clutch
    switch on 4x4 Low
    needs to be in that order or at least switch to low last or will not work
  9. Dec 10, 2011 at 9:40 PM
    OZ-T
    Peter North
    British Columbia
    Plus we were talking about 4H
  10. Dec 11, 2011 at 9:47 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    ^^^, me too... (but up to 100 kph). I have had 3 Tacomas now... all three with the ADD (Automatic Disconnecting Differential) which is how the Tacoma can shift on-the-fly into or out of H4, up to 60 mph. It is free wheeling in H2, so less wear and friction than your WWII Jeep in which all the front drive running gear rotated, even when you were in 2WD.
    Isn't this in every 4WD sun visor?:
  11. Dec 11, 2011 at 1:01 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    What about sharp turns with ATRAC engaged?
  12. Dec 11, 2011 at 1:51 PM
    OZ-T
    Peter North
    British Columbia
    OK , let's say you are right and binding up the front end has no detrimental effect on the vehicle , my question would be " why " ?
    Why are you driving with 4WD engaged on dry pavement , or wet pavement for that matter , unless you have some attraction to crappy fuel economy and not being able to make anything but very wide corners ?
  13. Dec 11, 2011 at 2:00 PM
    brp
    brp Well-Known Member
    I will tell you one reason you would be in 4H on dry roads. Essentially all winter here in Minnesota, you will be transitioning many times from snow-covered/icy roads to clear roads in one trip. There is one spot in my neighborhood where to get on to the main road I have to accelerate from a stop, on an icy uphill, on to a clean road, while turning. If I am in 2H, it is so slow to move that I couldn't safely merge.
    I do get the point, that what is the point of using 4H often/daily/etc. I am just saying that most people driving the truck would not even know one way or the other what position they are in, or maybe even what the t-case switch is for at all.
  14. Dec 11, 2011 at 2:04 PM
    OZ-T
    Peter North
    British Columbia
    Ice has give and your wheels can slip . I have similar conditions to deal with where I live , but I switch back to 2H when I am on the dry roads .
    You are correct about a lot of people not knowing the difference , they start all the " My truck won't turn !!!! " threads
  15. Dec 11, 2011 at 2:18 PM
    #35
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    My 2010 took 4 trips to the dealer to fix the difficult shifting into 4wd, sometimes it would take multiple tries, and 20 minutes. It was only un-cooperative in cold weather, maybe that is the case with the OP's truck.
  16. Dec 11, 2011 at 2:25 PM
    #36
    David K
    A-TRAC only become active when you are in Low Range 4WD, and have pressed the button... and then only if one or more tires loose traction (ie. spins). So, no dry pavement use at all... Off road, it is no more difficult to turn than low range 4WD already is with open differentials.
    Instead of just slowing down the spin (as is the case with TRAC or Limited Slip systems), it stops the spin to the same rotation as the traction tire... ie. it matches the rotation so torque (power) is equally balanced... just as it is with a locked differential. Because it releases as soon as traction is regained, there is no steering issues with A-TRAC.
  17. Dec 11, 2011 at 2:27 PM
    #37
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Take it back to stealership
  18. Dec 11, 2011 at 9:16 PM
    #38
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    So atrac is a locker?
  19. Dec 11, 2011 at 9:54 PM
    #39
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    You turned a serious question into a game.
    DavidK I guess I just need you to explain the whole atrac thing to me. I mean I watched the video but that didn't help. You seem to be knowledgable
  20. Dec 12, 2011 at 12:10 AM
    #40
    Manwithoutaplan
    ID
    it acts like a locker but is not.
