2011 access cab overhaul
Discussion in '2nd Gen. Builds (2005-2015)' started by Pdugan6, Aug 11, 2013.
  1. Mar 2, 2015 at 12:04 PM
    #361
    clupi
    clupi Well-Known Member
    Sacramento Ca
    07 taco 4x4
    5" chevy (63" )lift springs? How high is your lift? I think you have a lot of weight with a flatbed.. or is that not your truck? WOW.. and this is why I dont want to start my swap even though I have all the parts. I like my stance at 2" lift and and im worried that ill put on the chevy spings with the overload since i need the load campacity and will end up being 5-6" of lift :eek:
  2. Mar 2, 2015 at 12:22 PM
    #362
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Yes, I used the 5" lift springs due to the weight of the bed and toolbox.
    With the factory 63's you won't get as much lift.
  3. Mar 2, 2015 at 3:12 PM
    #363
    clupi
    Sacramento Ca
    07 taco 4x4
    Before you did your 5" lift springs did you try stock 63" springs to see lift size? I'm almost tempted to use my stock Toyota springs and do the shackle reversal which should give me a few inches more liftand maybe even more flex. What do you think?
  4. Mar 2, 2015 at 4:18 PM
    #364
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    That's certainly an easier and more reversible option.
    With the Chevy springs you can sort of pick your lift height with the shallow length and angle... It's just a 1 time thing unless you don't mind grinding and welding a few times ;)
  5. Mar 2, 2015 at 7:54 PM
    #365
    Pdugan6
    Pdugan6 [OP] Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    Yep it also depends on what size shackles you want to run with the 63 swap. If you're concerned of too much rear lift you can always go with a 2.5-3" shackle. Whatever the game plan is, remember that a Chevy swap is putting you down the path of heavy modifications If you use your stock springs and shackle flip kit it is definitely less permanent.
  6. Mar 2, 2015 at 8:01 PM
    #366
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Wow thanks man :thumbsup: I was just gonna make my own but depending on price I may just pay and be lazy :D
    I'm actually concerned I won't have enough lift.... I have my 33" and my heavy ass rear bumper... Especially with camping gear and a 35/37 mounted back there. Think a 5" standard shackle and a 4wd chevy spring (4-leaf) would be good? I think softer would be better but not if I'm riding on bump stops lol.
    Also what are you guys doing for a trac bar? Just making one or buying one?
  7. Mar 2, 2015 at 8:09 PM
    #367
    SMKYTXN
    Nathan
    Houston
    DCFB
    I was running the ATO trac bar that bolted to the rear diff, but took it off. It ended up shearing a stud out of the diff. It's also not long enough to get the proper shackle angle.
    I'm about to build my own trac bar. Both brackets are weld on. If you're already cutting and welding to the frame, why not weld some more? :D
  8. Mar 2, 2015 at 8:15 PM
    #368
    dakotasyota
    Dakota
    Ellensburg, WA
    That was my concern... hmmm
    Haha my thoughts exactly... You're cutouts look nicer though... I don't have a plasma cutter so pretty cuts are hard :/ see my CMC for instance hahaha :laugh:
  9. Mar 2, 2015 at 8:57 PM
    #369
    clupi
    Sacramento Ca
    07 taco 4x4
    How can you tell between year or type of Chevy springs? I got mine off craigslist amd the guy said they were off 99 if I remember. They are 3 leaf total including the overload, what looks funny to me is that the overload is super strait compared to the arched two leaf pack and looks like it would hang on stuff
  10. Mar 2, 2015 at 9:13 PM
    #370
    SMKYTXN
    Nathan
    Houston
    DCFB
    The CNC plasma cutter sure does make things easier.
    The overload is typically flat. Just make sure you measure eye to eye to verify the length.
  11. Mar 2, 2015 at 9:46 PM
    #371
    clupi
    Sacramento Ca
    07 taco 4x4
    Exactly 63" right??? I dont recall, ive had mine sitting for about a year now
  12. Mar 2, 2015 at 9:50 PM
    #372
    SMKYTXN
    Nathan
    Houston
    DCFB
    Just making sure you didn't accidentally buy 53" springs. :D
  13. Mar 3, 2015 at 4:35 PM
    #373
    clupi
    Sacramento Ca
    07 taco 4x4
    Is there such a thing? (53")??? I remember measuring them when I got them but it was a long time ago! It was right when I opened my TW accoumt and had no idea you can put anything bigger than a 33" on my taco.ive gotten myself in a lot of trouble since then ( a lot of projects) after seeing all the cool builds out there. Biggest one was clearing my firewall and body mount relocation which were both cheap but great upgrades . Is there a huge differemce between yhe 3 &4 pack springs? Any preference on ride or flex if you still want a truck you can tow normal with or load the bed here and there and not be worried of damaging your springs? I see most aftermarket Tacoma springs and not intended for heavy loads unles you get something like expedition type
  14. Mar 3, 2015 at 4:38 PM
    #374
    clupi
    Sacramento Ca
    07 taco 4x4
    I think im asking so many questions about 63" spring swap is cuz after a year or so of having them im trying to talk myself in finally doing it :D
  15. Mar 3, 2015 at 5:06 PM
    #375
    clupi
    Sacramento Ca
    07 taco 4x4
    Thanks Patrick, I knew this was in here somewhere... :D what is your measurement from the front bolt to the frameside bolt that holds the shackle? Do you have it? Thanks
  16. Mar 3, 2015 at 5:11 PM
    #376
    SMKYTXN
    Nathan
    Houston
    DCFB
    That measurement is going to vary for every install. It's a bit of trial and error.
  17. Mar 3, 2015 at 6:38 PM
    #377
    clupi
    Sacramento Ca
    07 taco 4x4
    Which vary? Both mounting location or just the rear depending on spring and desired shackle angle?
    Edit: im almost tempted not running my 3 leaf and looking for a pair of 4leaf to do the swap with
  18. Mar 3, 2015 at 6:42 PM
    #378
    dakotasyota
    Dakota
    Ellensburg, WA
    I'm currently unsure of going with 3 or 4 leaf as well...
  19. Mar 3, 2015 at 6:44 PM
    #379
    CCPTacoma
    CCPTacoma Well-Known Member
    Noah
    Boise, ID.
    09 Trd Sport DCLB
    you could just pick up a 4 leaf then test it out then remove leafs as you see fit
  20. Mar 3, 2015 at 7:01 PM
    #380
    clupi
    Sacramento Ca
    07 taco 4x4
    Yes, I wish I thought of that before I got excided bying these 3 leaf
