2011 DC Window Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickM, Feb 27, 2012.
  1. Jul 7, 2014 at 5:13 PM
    zengineer
    zengineer Member
    Jerott
    Utah
    13 Doublecab 4X4 Limited
    none of these piss ant applications fix this...303, wax, tape, etc..ive done em all. Zero fix..its a joke my truck does this too. Drives me nuts!
  2. Jul 7, 2014 at 5:31 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    I see it on some of the heavy trucks I work on and usually pulling the striker in a tiny bit fixes most door noise from seals.Rattling I have found is usually the rubber in the window track inside the door or loose track itself also inside the door.
  3. Jul 7, 2014 at 5:35 PM
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    I have the same problem on my 14 double cab. I just put some wd 40 on the seal. I will let ya'll know if this has any affect on the noise.
  4. Jul 7, 2014 at 5:46 PM
    TreyTRD
    TreyTRD Well-Known Member
    Trey
    Tennessee
    16 T4R TEP and 13 FJ
    I'm a tech at a dealer, not saying names, but I've come across this a couple times on customers trucks as well as my last 2011 double cab. Mine was coming from the seal between the door and the body. My fix was to get some spray silicon or a tube of dielectric grease, put it on a rag and wipe down the seal very good with it. Rub it in as much as you can and then wipe off the excess so it doesn't attract dirt.
  5. Jul 8, 2014 at 2:13 PM
    jbcanes
    Justin
    Tampa, FL
    update on WD 40 on the seal. It had a minimal affect. I was able to get a better result by putting the window down just a fraction where it is not open but not completely up. This combined with the WD 40 seemed to eliminate the noise for now.
  6. Nov 24, 2014 at 2:14 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Sub'd
  7. Nov 24, 2014 at 5:25 PM
    ZenkaiTaco
    ZenkaiTaco Well-Known Member
    Utah
    11 DCSB TRD OR
    Cant you just put some in channel rain guards in there to make it tighter?
  8. Nov 24, 2014 at 6:21 PM
    TXAggieTRD
    TXAggieTRD Well-Known Member
    Andrew
    TX
    '11 Pre-Runner V6 TX TRD Package
  9. Nov 25, 2014 at 3:46 PM
    jbcanes
    Justin
    Tampa, FL
    I tried the in channel rain guards they did not help.
  10. Dec 1, 2014 at 5:30 PM
    NickM
    NickM [OP] Well-Known Member
    Nick
    DE
    SR5 V6 4X4
    Yakima Roof Racks
    Been A while since I made this thread. I never did find a fix. I just deal with it. Worse in winter. I don't even 303 anymore. To much of a mess and not a lot of return.
  11. Dec 15, 2014 at 7:16 AM
    zengineer
    zengineer Member
    Jerott
    Utah
    I agree with you. There is no fix. I'm convinced the window glass is simply not as thick as the window seal is wide...creates a gap that makes the noise. And I agree it's worse in winter...colder temps things shrink, and makes the rubber even less pliable...more noise and more vibration. I noticed when the temp was 100 in summer, the problem was noticeable a whole lot less than in winter. Winter sucks.
  12. Dec 15, 2014 at 7:22 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    I use this on all door rubber seals twice a year - fixed the problem right away.
    Only needs to be put on all seas between the door and body (front and back)
  13. Dec 30, 2014 at 4:12 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    PERMANENT FIX!!!
    As suggested earlier, the enraging sound you hear is the tubular seal sticking and unsticking.
    But here's the kicker: It's sticking on the inside.
    The Solution
    The weather strip that the red tube is pointing to is the culprit (little bastard).
    Take your trusty can of WD-40, and stick the red tube into the hole provided by Toyota, and spray that shit like a crazy person.
    Get it everywhere.
    Get some under the seal too, just for good measure, and for the fine scent of WD-40.
    If it isn't dripping out of the seal, you didn't spray enough.
    Go for a ride, and collect your sanity.
    ChipsCashedIn, DrFunker and EDDO like this.
  14. Jan 9, 2015 at 8:29 AM
    DrTron
    DrTron New Member
    Salt Lake City, UT
    2013 Access Cab TRD Offroad
    Bilstein 5100's set @.85, Firestone Air Springs
    Has anyone else done this? How long has it been since you hit all those seals with WD40 inside?
  15. Jan 9, 2015 at 4:13 PM
    #35
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I did it on 12/30 and they haven't made sound yet. This is a permanent fix.
  16. Jan 9, 2015 at 6:47 PM
    #36
    pittsnogled
    pittsnogled I like turtles
    kirk
    South Carolina
    2014TRDsport
    5100's all around with OME 884 at 0. Weathertechs, Carhartt seat covers. BFG KO2's 265/70/17. T4R SEMA wheels. 18% tint on front windows. General Springs HD 4 leaf pack, Leer 100 XR shell.
    how many of those holes in the seal did you spray it in?
  17. Jan 9, 2015 at 6:58 PM
    #37
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Just the ones around the top corner. That's where the sound comes from.
  18. Jan 14, 2015 at 9:34 AM
    #38
    DrTron
    DrTron New Member
    Salt Lake City, UT
    I can confirm that this is a fix. I could press on the seal and you could hear it sticking and releasing when you take pressure off. The problem is on the inside of the seal. I loaded my driver's side door and the access cab door behind it with WD40 and after checking and adding a few times, it is gone! Nice and quiet with my sanity back intact.
    Thank you!
  19. Jan 15, 2015 at 6:38 PM
    #39
    TXAggieTRD
    Andrew
    TX
    Does anyone think the wd40 would mess up window tint if it came in contact?
  20. Jan 15, 2015 at 7:01 PM
    #40
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Possibly.
    I switched to silicone spray because I'm afraid WD-40 might "gum up" the rubber and make it stick again.
    If that noise comes back I will swerve this thing into a bridge abutment.
