2011 DC Window Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickM, Feb 27, 2012.
  1. Mar 26, 2015 at 7:41 PM
    #61
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've been having this problem since early ownership. I HATE it! if the sound was somewhere else in the cab I wouldn't care but it is literally right by my ear so it drives me nuts! Thanks for the tips in the potential problem areas. I will check later!
  2. May 13, 2015 at 4:29 PM
    #62
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    On my 2012 DC the noise is coming from the seal around the window not the door. I can press against the seal with the door closed and window up to replicate the noise. I've tried 3m double sided tape against the seal and on the frame but it still makes the noise. How hard is it to rip out the seal completely and re-install it with a fat line of weatherstrip glue to see if that helps?
  3. May 13, 2015 at 5:18 PM
    #63
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The solution to this problem is within this thread.
  4. May 13, 2015 at 8:44 PM
    #64
    TAJJI
    TAJJI Active Member
    Tanner
    N. Colorado
    2015 Tacoma DCSB TRD Offroad - White
    OME Lift with Dakar Leafs Bug Chucker Bedside decals
    I dont think these weatherstrips use DS tape or anything like that, as you usually pull it out to replace the window. Try straight silicon spray or a super light coat of lithium grease where you think its making noise - neither will harm the trim.
  5. May 14, 2015 at 3:41 AM
    #65
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The solution is here ^^^
    But use silicone spray instead of WD40.
    It's been months and I haven't heard another peep from that door.
  6. May 14, 2015 at 4:53 PM
    #66
    Backt
    Oregon
    The popping noise I'm hearing is coming from the seal that surrounds the window not the door. I've put half a can of silicone spray into all those holes and it hasn't seemed to help. I'm all ears if you have any sort of solution for me to try.
  7. Sep 23, 2015 at 9:15 PM
    #67
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    Subscribed.
    2200 blissful mils so far ... except the stupid driver door ear level squeak.
    Got some spray silicone tonight and loaded up the inside of the weather strip via the holes. No help. Will try it again tomorrow but I sure as hell hope this works.
  8. Sep 24, 2015 at 5:10 AM
    #68
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    KB, was your original problem temporarily remedied by very slightly lowering the window and "permanently" fixed by spraying the silicone into the door seal?
    I only ask because the squeaking/rubbing sound I hear on my driver's side goes away if it gently tap the button to lower the window about 1/8". That leads me to believe it's a different seal than the one you mention spraying, but please correct me if I'm wrong.
  9. Sep 24, 2015 at 5:20 AM
    #69
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    What I had was more of a "rattle" sound, not a squeaking or rubbing.
    I would "tap" on the window, with my elbow, as hard as humanly possible. That never worked.
  10. Sep 25, 2015 at 7:37 PM
    #70
    burnside
    burnside Member
    I'm having the same issue coming from the driver's window on my 15' DC. I do not think it's the door seal either - the seal doesn't even have holes in it to spray anything. If I press up against the back top corner of the window the noise does go away. Would love to hear of any solution since it is driving me nuts!
  11. Sep 25, 2015 at 9:38 PM
    #71
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Same here- I push on the top corner of window and I can make it stop. Rolling down the window about 1/16 to 1/8 inch sometimes makes it go away too, but it's gotta be just right. It might just lessen it a little. This leads me to believe it's the seal/plastic/rubber directly in contact with the window. Next experiment will involve placing a piece of thin paper over the top edge of the window and then rolling it up to see if that has an effect.
  12. Sep 26, 2015 at 1:01 PM
    #72
    burnside
    burnside Member
    Hey Harp, I did finally find those holes in the door seal, but I still think it is a window seal issue. Let me know if you find any solution. I'm going to start experimenting as well.
    NMTrailRider likes this.
  13. Sep 26, 2015 at 1:26 PM
    #73
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    Been nine months and still no noise after doing the above.
  14. Sep 26, 2015 at 11:36 PM
    #74
    burnside
    burnside Member
    I noticed today that there was no noise coming from the window. I did nothing to the window or door seals. Only reason I can come up with was that it was warmer today than earlier in the week. I'm betting the rattle comes back once it cools down again.
  15. Oct 13, 2015 at 8:10 AM
    #75
    Lomez
    Lomez
    AZ
    @burnside, @harpolith
    Did either of you achieve a resolution on this?
    My issue is almost certainly related to the top of the window seal/track, rather than the door gasket with the holes. I pumped a can of silicone spray in those holes, and that aint the issue. I can replicate and/or stop the sound by pressing on the corner of the window glass.
    As to heat/hot weather effecting it .... I live in southern Arizona and bought the truck in July. It has been "warmer" every day I have owned it so I am not sure that is related for me.
  16. Oct 13, 2015 at 8:22 AM
    #76
    burnside
    burnside Member
    I'm probably going to wait until my next service and have Toyota look at it... make them responsible for the issue and fixing it. If they give me the runaround I'll most likely fill the space with some silicone caulk to tighten the gap.
  17. Oct 13, 2015 at 9:09 AM
    #77
    NMTrailRider
    New Mexico
    No resolution here. Next up: rubber tape.
  18. Oct 13, 2015 at 9:12 AM
    #78
    Lomez
    Lomez
    AZ
    Thanks guys. I am a couple months away from my first service at the dealer, and will obviously let them take a crack at it.
  19. Oct 13, 2015 at 9:19 AM
    #79
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    subbed
  20. Oct 13, 2015 at 9:28 AM
    #80
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    I had the same problem - a noise from the upper rear corner of the driver's window that was intermittent. 3M friction tape on the top corner of the door fixed it for me. I swore the noise was from the window and its seal, but firming up the seal between the door itself and the cab eliminated my noise. Seems there's numerous fixes for the same general problem and you have to try them all to find the one that works for you. Good luck!
