2011 DC Window Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickM, Feb 27, 2012.
  1. Oct 13, 2015 at 9:34 AM
    #81
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I dealt with this problem for months with no solution and I tried everything. I went away this summer for 3 months and it was hot. When I returned the noise was worse. I sprayed a lot of silicone spray in the holes, on the seal, and on top of the seal in the crack. Noise is now gone.
  2. Oct 13, 2015 at 10:05 AM
    #82
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    By "a lot" of silicone spray do you mean "more than a can"?
  3. Oct 13, 2015 at 10:28 AM
    #83
    Backt
    Oregon
    No. Start at one side of the door and stick the straw in the hole and spray for 1.5 seconds while covering up the next hole. Repeat through all the holes on top and down the side. Wipe any excess with a Paper towel and then rub this into the front of the seal and the frame seal as well. A can should be enough to do it 10 times I would think.
  4. Oct 13, 2015 at 10:58 AM
    #84
    Lomez
    Lomez
    AZ
    As I said up-thread, I have emptied a can in mine with no help. That is not the issue.
  5. Oct 13, 2015 at 11:09 AM
    #85
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    Did you try friction tape on the door frame? Here's where I applied it to eliminate the noise when the silicone spray didn't work for me either.
  6. Oct 13, 2015 at 8:13 PM
    #86
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    mine are rattling now, ...when totally up, and when down 1/4 way...
  7. Oct 14, 2015 at 4:32 AM
    #87
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I sprayed for 1.5625 seconds.....FTWMF
  8. Dec 25, 2015 at 6:53 PM
    #88
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    My driver front window is killing me with rattles... I have to try some of these fixes
  9. Dec 25, 2015 at 11:21 PM
    #89
    Backt
    Oregon
    Don't waste your time. You cannot make this noise go away especially during the colder months. In the summer it would improve with certain fixes posted here but none of them solved the problem.
    What I've tried
    1. Silicone spray in the holes
    2. Tried tightening the door bolts
    3. Removed door panel looking for the culprit
    4. Friction tape along every edge.
    5. 303 cleaner and protectant
    6. Double sided tape followed by friction tape to try to make it tighter
    7. Pieces of paper slid up between the 2 seals when I closed the door.
  10. Sep 6, 2016 at 2:02 PM
    #90
    DAL350B
    DAL350B New Member
    Adam
    2013 White Tacoma Off Road
    Voodoo, I bought a 2013 Tacoma 2 months ago and I already can't stand the noise! So I just found your fix and I'm going to give it a shot. Just wanted to ask if you still think Silicone spray is the way to go? Or if you have gone back to WD-40?
    1.5625 seconds right?
    Tunngavik likes this.
  11. Sep 6, 2016 at 2:33 PM
    #91
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    In my case it is not the inside of the stripping making noise so spraying anything in the holes is pointless. I lightly coat all of the weather stripping on the doors and door openings in WD-40 with Silicone. I usually have to do this about every 10k miles.
  12. Sep 6, 2016 at 3:29 PM
    #92
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Silicone was the way to go for me. Get it all up inside that seal.
  13. Dec 22, 2016 at 6:11 PM
    #93
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Any chance silicone spray will make after market tint peal?
  14. Jan 14, 2017 at 5:26 PM
    #94
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Asked the dealership to lube it up yesterday and either they didn't do it and said they did, or whatever they used was 0% effective. It's just as annoying as ever today :mad:
  15. Jan 14, 2017 at 5:37 PM
    #95
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That's because dealerships are 0% effective
  16. Apr 13, 2017 at 6:27 PM
    #96
    takoashihaisen
    takoashihaisen Well-Known Member
    island, WA
    2015 AC 4X4 4cyl M/T SR MGM
    successfully installed 3 windshield cracks
    @KB Voodoo
    Thank you. Silicone spray worked like a charm:bowdown:
    KB Voodoo likes this.
  17. Apr 13, 2017 at 10:02 PM
    #97
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Silicone spray (actually lithium grease) fixes mine for about a week if I stick to pavement, and for about 24 hours if I hit gravel :(
  18. Apr 17, 2017 at 7:30 PM
    #98
    Houston
    Houston Well-Known Member
    Texas
    2015 MGM DCSB TRD Off-Road
    Had a similar problem with the seals (I think) making some noise as soon as I bought my truck. Complained to the dealer a couple of times and they finally replaced the seals under warrenty, worked great for about a year, now its back with a vengence. I wonder if its something on the seals when they're installed, like a oil or coating of some kind that is wearing off? I'm thinking of trying silicone lube on it.
    Here's another thread we had on this a while back:
    https://www.tacomaworld.com/threads/possible-fix-door-seal-noise.397362/
  19. May 1, 2017 at 4:54 PM
    #99
    Chaz84
    Chaz84 Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    Sincere thanks from saving me $125 for a not needed door channel. Totally soaking in wd40 seems to have corrected the problem. Note: you definitely have to soak the entire "body" of the outer weather stripping to ensure complete release of the sticking. I even had a solid whistle coming from my driver's door (right by my freaking ear! UGH! Was losing my mind), and through this thread I figured out that the strip sticks together and creates a poor seal, i.e. The stripping sticks together creating crackles and by sticking creates a gap through which air whistles. One crackle right after initial application and none since. Thanks to all involved. This was one hell of a crackle to kill (with extreme prejudice).
    Note: I hope the wd40 doesn't create a sticky problem, but the best option I think after confirming with my Toyota tech friends that silicone strinks that particular "rubber."
  20. May 1, 2017 at 5:19 PM
    #100
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Sorry to break it to you.. but it comes back haha.
