2011 DC Window Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickM, Feb 27, 2012.
  1. May 1, 2017 at 5:24 PM
    #101
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    FYI....silicone spray works best.
  2. May 1, 2017 at 6:58 PM
    #102
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    I'm wondering what putting a long, thin gasket material in behind the lower rubber seal would do, kind of like using the drip hose for the upper seal for the kazoo sound. Not sure what sort of material fits that description. I feel like that could stop the friction and permanently fix it.
  3. May 1, 2017 at 6:59 PM
    #103
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Pretty much a wide rubber band :notsure:
  4. May 3, 2017 at 5:13 AM
    #104
    Chaz84
    Chaz84 Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    You are right dang it. After two days of 85+ heat it seems the wd40 has already dried out. At least I know I just need a straw spray that doesn't affect the rubber. Have an idea though and will update accordingly.
    Edit: I investigated the ability to get actual grease into the problem areas and it appears that it is accessible for a pinky finger. My Toyota tech buddy (this guy could've been a rocket scientist and is the top tech) tells me to use dielectric grease bc it won't affect the rubber and doesn't dry out or cause sticking issues. I plan to try this today. Fingers crossed. At least you guys found where the issue is, now we just have to find the proper lubricant as I'm reading silicone spray also doesn't last.
  5. May 7, 2017 at 11:53 AM
    #105
    Chaz84
    Dr. Chase
    GA
    Packed all accessible areas with dielectric grease (pulled the plastic clip at the top of the door corner to access everything) and after confirming that wd-40 silicone lube is totally safe (I misunderstood earlier and it is silicone based adhesive that will shrink the rubber), I filled all the breather holes with spray.
    Well, I think we have it fellas. She's quiet as can be and has been for 4 days. Will update if it comes back.
    Note: there is still a slight wind noise above 65, but the same loudness as the rest of the wind noise in the truck.
  6. May 7, 2017 at 1:47 PM
    #106
    vtdog
    vtdog Well-Known Member
    NH
    I have the in-channel Weathertech vents. They lock the window in tight and no rattles.
  7. May 8, 2017 at 5:07 AM
    #107
    Chaz84
    Dr. Chase
    GA
    I had the in channel vent visors and they did the same for over a year, but the extra compression seems to have caused the rubber to start sticking together creating the crackling sound a few months back and why they are no longer on my yotota. Best of luck though.
  8. May 10, 2017 at 11:22 AM
    #108
    Chaz84
    Dr. Chase
    GA
    So far so good. Wind noise seems to have subsided as well. Thinking the dielectric grease has worked its way in and is allowing the rubber to expand as designed. WAAAAAAAAHOOOOOOO!!!!!! No crinkle in my ear hole... Such a relief.
  9. Jul 30, 2018 at 5:09 AM
    #109
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    This might be an old thread but still a Tacoma problem. To be safe, I put dielectric grease along the inside of the weatherstripping that runs inside the widow, and put a lot of silicon lubricant spray in the little holes in the weather stripping the get smashed between the door and the body. For me the key was to spray the silicon into the little breather holes and work the weather strip around to get the silicon to spread all around.
    I don’t realize how bad it had gotten until it was gone. It’s so peaceful now.
    Thanks @KB Voodoo for the fix. Permanent or not, it’s a f*ing miracle. I assume it’s happinging at all because my doors are not aligned perfectly or something. I will address that later.
  10. Feb 7, 2023 at 7:42 AM
    #110
    ChipsCashedIn
    ChipsCashedIn President of Tom T. Hall
    Sam
    Austin, TX
    2017 DCSB TRD OR 4x4
    OME 886, 90000's, 60091s, FO UCAs ChiCom Lo-Pro winch bumper and light bar Prinsu rack, RC ditch lights, 2020 LED hedlights Lots of sound interior noise dampening
    Dude. You're a mensch. Worked like a charm. I was about to switch to shooting left-handed make myself similarly deaf in said ear.
