2011 Devil Horns are finally here!
Discussion in 'Diaz Fabrication' started by Andres, Feb 15, 2011.
  1. Feb 15, 2011 at 12:00 AM
    Andres
    Andres [OP] Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    Ready to take your truck by the horns?
    After a long wait from you, I'm happy to inform that you can finally get your hands on your very own Devil Horns emblem. Devil Horns began as a simple request from a proud Tacoma owner and a good friend of mine. He gave me the idea, I took on the challenge and now I'm glad to share this small piece of work with many Toyota vehicle owners. This type of emblem has been approved for a small production under direct permission from Toyota Motor Company's Legal Department under certain conditions. Please follow the simple rules that will help me deliver this emblem to you listed at the bottom of this e-mail, if it weren't for them I wouldn't be able to bring this product to your hands.
    The design:
    The first step into making Devil Horns was the use ofComputer Aided Design/Drafting, also known as CAD. The Idea is to draw Devil Horns as a 3D model with the use of computer software, modifying every line and curvature until they all meet in a well balanced and functional design.
    The material:
    6061-T6 Aircraft Grade Aluminum was selected as the primary material used to make Devil Horns. Aluminum is remarkable for the metal's low density and its ability to resist corrosion. All tough other grades of aluminum are available (2024, 7075, etc.), 6061-T6 offers a well balanced solution in stress, strength and ease of working with, making it a perfect structural component for this emblem.
    Fabrication process:
    In order to provide the highest quality of fabrication, Devil Horns was made using CNC machines. Before the use of CNC technology parts were fabricated manually by a machinist, a person who uses machine equipment to make or modify parts, primarily metal parts. With the introduction of CNC equipment the fabrication process is now made using automated machines which can be programed to perform various operations to produce complex parts offering more options, control and repeatability. While other methods of fabrication exist to produce this emblem I wanted to share the same product with you as the first emblem I made years ago that takes time and care to perfect, all 100% American made.
    Shot penning option:
    In order to remove the marks left by the CNC machine, shot penning was the best available method. Shot penning is a process that uses round metallic particles with sufficient force to create surface deformation. The result is an increased stress layer that hardens the outer area of the material making it stronger and more durable. I have included this option as some people don't like the machining marks left by the CNC machine, this is only a matter of preference. This option comes to you at an extra cost.
    Anodizing option:
    The anodizing process starts with suspending the aluminum with wires and putting it in an acid bath. Electric current is run through it causing the surface of the aluminum to oxidize (essentially rust). The aluminum is then immersed in dye baths of various colors to achieve the color desired. The dye is trapped in the surface as well as making the surface even harder than the inside of the aluminum. The result is an elegant color and a more durable finish. You may choose from the available colors listed, this option come to you at an extra cost.
    Available Colors for anodizing:
    *Dark Grey (Shown with no shot penning)
    *Cherry Red
    (cherry red shown with shot penning)
    *Gun Metal Black
    (Gun metal black shown with shot penning)
    *Horns on Fire (Shown with shot penning)
    Last but not least, the new 2011 Polished Devil Horns!
    This is the first time a polished option is being offered. The polish option consists of hand-polish using a polish wheel to a mirror-finish over the natural aluminum. After the emblem has been polished a layer of lacquer is applied to bring out the most shine from the natural aluminum. Finally brite dip is applied and clear anodize to preserve the shine over time.
    Note:
    Shot penning and Anodizing are two different options with different results. Both options are mentioned above and CAN be combined. The above emblems in Grey, Red and Black have no shot penning and show the fabrication marks left by the machining process while the Horns on Fire does have the shot penning process giving a smoother finish and increasing the color of anodize. I suggest shot penning if an anodize color is chosen. If no options are mentioned, a natural aluminum finish (just like the first emblem shown) will be mailed. Options can have various results such as the examples below:
    *No options (natural finish)
    *Shot penning only
    *Any anodize color only
    *Any anodize color + shot penning
    *Polish only
    Installation requirements:
    5/32" Allen wrench also know as a hex key
    A pair of hands
    5 minutes of your time
    (note: Top embelm is for 1st generation Tacoma, Bottom is for second generation Tacoma)
    Installation Info:
    There's very little skills required for the installation of Devil Horns. I made it as easy as I could for you to place this bad boy on your grill using four 10-32 bolts and four split locking washers.
    This would be the typical installation scenario:
    *Open the hood
    *With your fingers, gently remove the existing emblem by un clipping it from the grill
    *Slap that bad boy onto your grill, put back the split locking washers onto the bolts and finger-tighten all four bolts to the emblem
    *Snugly tighten all four bolts with a 5/32" Allen wrench also know as hex key
    *Take your truck for a spin to display your newly installed horns [​IMG]
    [​IMG]The damage :
    Due to my legal agreement I have with Toyota I am unable to show prices online.
    Feel free to contact me for price at: customdevilhorns@hotmail.com
    The following are the vehicles Devil Horns available for:
    Toyota Tundra 2nd Generation (2007-2009, Oval length: 6.70 Inches)
    Toyota Tacoma 2nd Generation (2010-Present, Oval length: 5.51 Inches)
    Toyota Tacoma 2nd Generation (2005-2009, Oval length: 5.51 Inches)
    Toyota Tacoma 1st Generation (2000-2004, Oval length: 4.45 Inches)
    Toyota Corolla 9th Generation (2003-2008, Oval Length: 4.31 Inches)
    Each emblem will include 4 bolts and 4 retaining washers for installation.
    Options:
    Natural raw aluminum
    Shot penning
    1 Color Anodize
    3 Color (horns on fire) Anodize
    Polish
    Payment:
    Please email me for pricing. Acceptable payment methods are PayPal, personal check, cashier's check or money order.
    When ordering please provide me with the following information:
    *Type of emblem (vehicle model)
    *Polish option (yes or no)
    *Shot penning option (yes or no)
    *Anodizing option (yes or no, if yes please include color)
    *If emblem will be shipped outside the US or Canada, please specify country.
    Closing:
    Why am I doing this?
    There is a saying that if you find something that you love doing and get paid for it you really never work a day in your life. I see my daily job as a hobby and for the most part I wake up encouraged to finishing my current job in the best possible way. I was first introduced to machining in high school and since then I have been obsessed with the idea of grabbing a piece of metal and shape it to perform a given task. I will try my best to keep these emblems available, but I fear someday I will have stop making them. For the time being, I'm having my kicks making them for Toyota vehicles and I hope to keep making them for some time. This emblem goes to anyone that has:
    used a wrench on their vehicle,
    taken hours to decide on the perfect part,
    taken it off the road
    and crawled the impossible,
    taken it out near the beach,
    battled through heavy snow,
    explored deep in the forest,
    cruised through the desert,
    to the ones who like to keep it clean,
    and the ones who don't mind getting dirty,
    anyone that polishes to a mirror finish,
    the ones who sand blast them,
    anyone who changed it's color,
    modified their grills to make it fit,
    hang it up on the wall,
    has them on their back (hopefully I don't see this again),
    the ones who wear it with pride,
    those trucks in Florida,
    the ones in Canada,
    the ones in Peru,
    anyone making it unique
    or just making it different,
    for those who are happy with what they drive,
    the ones who win a raffle,
    for those who simply hold back and look at their trucks.
    What ever you drive right now, you know that is your vehicle
    ...and it deserves some appreciation.
    It brings me joy reading about every one of you and receiving pictures of your cars/trucks. Please send me pictures if you can, I'll be happy to look at them. It is my pleasure to bring you a unique item not sold or made anywhere else. I hope you enjoy this small piece of work and why not,
    let that truck grow some horns! [​IMG]
    Sincerely,
    Andres Diaz
    Rules:
    1) RECIRCULATE
    There's a limited quantity that I'm allowed to make each time Toyota gives me the OK, unfortunately I may not have enough emblems for everyone. If for any reason you end up not using the emblem I will gladly give you a full refund no matter how long ago it was sold. The reason why I'm doing this is because I want everyone to have a better opportunity in getting one. Please don't sell them on eBay, I will explain why.
    2) TWICE A YEAR BASIS
    I had my kicks making these bad boys for all of you and I plan on continuing to do so. I cannot afford to "bother" Toyota's legal department every time someone wants one, therefore I hope to get permission from Toyota to make them twice a year. My time is very limited as I am a college student and a full time employee, therefore dedicating time to make these emblem is very limited on my part.
    3) LIST
    I have made up a list of people that would like an emblem. If you are interested in one, please drop me an e-mail and request I add you to the list. I will have them available in the order in which I get a request, no exceptions.
    4) KEEP THINGS SIMPLE
    Please don't make a huge fuss about these emblems! The more they are advertised, viewed, etc, the more likely Toyota won't want them on the market. I ask of you not to put them on eBay, craigslist, internet site, etc.
    5) DO NOT SELL THEM ON EBAY!!!
    Toyota contacted eBay shortly after I put my first 2 emblems for sale and ebay put a hold on my account. Copyright infringement is a serious offense and eBay is notorious for tracking illegal, and unlawful content, copyright infringements, etc. Please never put this emblem on ebay, it also makes me look bad with Toyota and I may never get another change in making them again.
    6)LIMITED QUANTITY
    There are a number of people that have been waiting for an emblem for a few months. I'd like to have orders of only ONE emblem per person so that we have enough for everybody, that way is fair for the others. If you absolutely need more than one please let me know the reason and I will try my best to fit your needs.
    ChadsPride likes this.
  2. Feb 15, 2011 at 12:11 AM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    Email on the way :cool:
  3. Feb 15, 2011 at 12:21 AM
    OZ-T
    OZ-T You chose ... wisely
    Peter North
    British Columbia
    Email sent
  4. Feb 15, 2011 at 12:38 AM
    TacoHI11
    TacoHI11 Member
    Oahu
    11 double cab sport
    Email sent
    Hope I am not to late!
  5. Feb 15, 2011 at 2:55 AM
    Foxer
    Foxer Well-Known Member
    U.S.A.
    Access Cab PreRunner
    Neat.
    Sent an email.
  6. Feb 15, 2011 at 3:20 AM
    Tombs
    Tombs Member
    Alabama
    2010 Double cab 4x4 Pyrite Mica
    Icon coilovers,2inch AAL,Undercover,Wet Okole,Weathertech
    Email sent
  7. Feb 15, 2011 at 3:28 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Trade-in time for the 05-10s! Now my 2011 grill will be set for shenanigans.............Email & PM sent.
  8. Feb 15, 2011 at 4:12 AM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Email sent and the workmanship on these is incredible.
  9. Feb 15, 2011 at 4:43 AM
    Firetech
    Firetech Well-Known Member
    Ralph
    Maryland
    2010 SR5 Off Road
    Email sent Devil Horns on fire look great!
  10. Feb 15, 2011 at 4:53 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Props to Andres, you do great work !
  11. Feb 15, 2011 at 4:54 AM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    pm sent
  12. Feb 15, 2011 at 4:59 AM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
  13. Feb 15, 2011 at 5:37 AM
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    email sent!!!
  14. Feb 15, 2011 at 5:53 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Sending email
  15. Feb 15, 2011 at 6:52 AM
    RMCO
    RMCO Active Member
    Email sent :D
  16. Feb 15, 2011 at 7:10 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    hopefully i can jump in on this when i get back from my cruise :D
  17. Feb 15, 2011 at 7:11 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    emails sent before?
  18. Feb 15, 2011 at 7:56 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Email sent!!
  19. Feb 15, 2011 at 8:01 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    email sent
  20. Feb 15, 2011 at 8:58 AM
    Qman619
    Qman619 Member
    Quyen
    San Diego
    09 PreRunner Magnetic Gray Metallic
    Stereo Kenwood DDX993, Weather Tech floor mats, Wet Okele seat covers.
    Email sent.
