2011 seat belt chime mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nick, Feb 13, 2011.
  1. Feb 13, 2011 at 9:47 PM
    nick
    nick [OP] MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    EDITED; i recently tryed the mod for a 08 taco seat belt chime on my 2011 taco. i guess they decided it was time for change. it would"nt work on mine. i tryed a couple different things and finaly got it,
    -KEEP YOUR FOOT OFF THE BRAKES THROUGH ENTIRE PROCESS!!!!!!!!!!!!
    -get in truck and shut the door.
    -turn key on and get your insterment panel on ODO and turn key off.
    -turn key back on, as soon as u do that press reset knob.
    -hold reset knob for 12_15 seconds and fasten seat belt.
    -xxxx miles should turn to b_on.
    -release and press one time, it should say b_off.
    -wait for it to reset back to miles and turn key off.
    =seat belt chime should be turned off.
    EDITED; sorry i just edited this message. it was late when i wrote it up! try it now and let me kno if you have better results.
    good luck, if you have any problems let me kno
  2. Feb 13, 2011 at 10:09 PM
    ninjanate
    ninjanate Active Member
    Nate
    Brigham city UT.
    2011 TRD Sport 4X4 double cab long bed
    custom light bar w/extra reverse light. blacked out tail light mod. Satoshi grille mod. Goodyear Wrangler Dura Tracs 265-70R-17.
    Yeah I tried it like 10 times still not working. Let me know if anyone else has the same prob and how they fixed it if they did.
  3. Feb 13, 2011 at 10:16 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i did it on my 07 and my 09
  4. Feb 13, 2011 at 10:18 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    did it in my '10. i think there's supposed to be a step in there about not touching the brake when turning the key
  5. Feb 14, 2011 at 9:25 AM
    desmo2
    desmo2 Well-Known Member
    Dave
    Columbia, MO
    black '11 TRD Sport access cab
    Still no worky on my '11.
  6. Feb 14, 2011 at 4:08 PM
    ninjanate
    Nate
    Brigham city UT.
    I'll give it a go as soon as I get back in the truck thanks
  7. Feb 14, 2011 at 4:10 PM
    The_Hodge
    SC
    here are the steps i used that worked...slightly different than above....
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
  8. Feb 14, 2011 at 4:28 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    This is how I did it with my 2011 and it worked. Thanks.
  9. Feb 14, 2011 at 4:31 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Just do up the seatbelt and then put seat covers over top. You won't hardly notice the seatbelt underneath if you tuck it in!
    Cheers.
  10. Feb 14, 2011 at 4:34 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    I've tried a couple times, but no luck
  11. Feb 14, 2011 at 4:46 PM
    ninjanate
    Nate
    Brigham city UT.
    Worked now. Great write up and thanks again
  12. Feb 14, 2011 at 4:50 PM
    nick
    Green mountain ,nc
    - 2003 trd
    just edited the my message at top. got it a little mixed up sorry for the problems
  13. Feb 14, 2011 at 5:01 PM
    jtice
    jtice Well-Known Member
    West Virginia
    2011 TRD Off-Road
    Pioneer P4100DVD, 10" Pioneer Shallow Mount Sub
    I am pretty sure this will stop the beeping when a seatbelt is undone while you are driving, for example, your passenger taking the seatbelt off before you get parked.
    But, it STILL beeps if you get in the truck and start it before your seatbelt is on, at least that is what mine is doing.
    When I get time, I am taking the gauge cluster out, and ripping off the damn beeper from the back of it.
    ~John
  14. Feb 14, 2011 at 5:03 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    haha for a second i thought the op was trying to make people go outside and make feel stupid....
  15. Feb 14, 2011 at 5:09 PM
    desmo2
    Dave
    Columbia, MO
    Still no joy.
  16. Feb 14, 2011 at 5:09 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    My 2010 chimes for 15 seconds then shuts off by itself. with a passenger or not. Is that normal?
  17. Feb 14, 2011 at 5:12 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I'm going to have to try this... My truck just started randomly beeping about 2 weeks ago. I have a feeling it's an issue with the sensor in the passenger's seat, although the little "seatbelt light" on the dash never seems to light up when it's acting up...
  18. Feb 14, 2011 at 8:01 PM
    agbbks
    agbbks Member
    Keith
    Longmont, CO
    2011 Tacoma TRD Off Road
    De-badged, WeatherTech, ARE Z-series Topper, OEM bedmat, Slee sliders, Toytec Ultimate Lift
    No dice for me. 2011. Tried it several times using the first set of instructions, then the updated set, and even similar notes from previous threads. Guess I'll just go with the earplug mod. Frustrating.
  19. Feb 14, 2011 at 8:05 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Or you could just buckle up and not have to eat glass... :notsure:
  20. Feb 14, 2011 at 8:41 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    The silence is nice if you're in the middle of nowhere, driving 5-15mph stopping and starting to see things.
    Otherwise always have the seatbelt on.
