2011 seat belt chime mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nick, Feb 13, 2011.
  1. Jun 27, 2011 at 1:52 PM
    #161
    limeyx
    limeyx Active Member
    Nick
    Los Angeles, CA
    2010 Tacoma
    yes
  2. Jun 27, 2011 at 2:49 PM
    #162
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    depends (on the time frame of mfg)
    some yes
    some no
    (i'm a no):(
  3. Jun 27, 2011 at 2:55 PM
    #163
    dan0
    swamplands of sc
    there is an easy unplug a wire fix for this
    http://www.toyotanation.com/forum/showpost.php?p=2643003&postcount=27
    if you do this you can now lock your keys in the ignition ( a feature i use)
  4. Jun 27, 2011 at 3:12 PM
    #164
    NaYoung
    NaYoung Well-Known Member
    Florida
    2020 TRD ORDC
    Worked on my 2011 DC SR5. Tried the first set of instructions and it didn't work then saw this and figured I'd give it another shot. The only difference between the OP and this set is the cycling around to get to the ODO. I was already on ODO but cycled anyway which seemed to be the trick.
    I tried again without cycling and couldn't get back to the option to turn it back on. But when I cycled around back to the ODO it worked. Hope this helps for anyone having problems.
  5. Jun 28, 2011 at 8:48 AM
    #165
    hyperichie
    hyperichie Member
    WOW this is annoying!!
    I have owned 5 Tacoma's in 8 years lol and I was able to turn this damn beeping off in no time.
    I have tried 50 times and I can not get this to work. I have a new 2011 and I can not for the life of me make this work.....
    Why can some 2011's work and some dont??
  6. Jun 28, 2011 at 8:51 AM
    #166
    Flyfisher22
    Flyfisher22 Well-Known Member
    Cameron
    Indian Trail, NC
    2011 Off Road Package DC
    None
    It does not work on the newer 2011 with the white gauges.
  7. Jun 28, 2011 at 8:52 AM
    #167
    hyperichie
    hyperichie Member
    I do not have the white gauges.. What White Gauges>>? Mine has like a carbon look to it..
  8. Jun 28, 2011 at 9:45 AM
    #168
    NaYoung
    Florida
    2020 TRD ORDC
  9. Jun 28, 2011 at 12:12 PM
    #169
    hyperichie
    hyperichie Member
    lol ok yea I got the white gauges :) So no way to do it if you have the white gauges..??
  10. Jun 28, 2011 at 3:29 PM
    #170
    NaYoung
    Florida
    2020 TRD ORDC
    Thats what everyone seems to be saying. Guess no one has figured it out yet.
  11. Jun 29, 2011 at 2:33 AM
    #171
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    2011 trd sport white gauges. Does Not Work.:mad:
  12. Jun 29, 2011 at 2:29 PM
    #172
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Welcome to Tw!
    Maybe operator error. My first attempt I wasn't able to do it. I had to hold the odometer button down for 30 seconds, not the 20ish the instructions suggest.
  13. Jun 30, 2011 at 5:31 AM
    #173
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    what color gauge clusters do you have?
  14. Jun 30, 2011 at 2:12 PM
    #174
    TacoBS
    TacoBS Well-Known Member
    Billyson
    Central Coast, CA
    2011 Pyrite 4x4 DCLB
    2"/1" spacer/block (for now) Tailgate hoseclamp bedmat mod Marathon covers Weathertech mats
    No luck for me (white gauges) after multiple, multiple tries:(
  15. Jun 30, 2011 at 2:36 PM
    #175
    SeniorSpan
    SeniorSpan Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    G'day all,
    I have a 2011DC Auto TRD TX Pro, standard gauges. Enbeded in one of the seat belt chime threads on TW there's info on the white gauges process.
    The primary difference appears to be setting trip planner to "Trip A" for the white gauges vs setting the trip planner to "ODO" for the standard gauges.
    Having the older gauges, I used the "ODO" instructions and admittedly, had to try several times. First time with drivers door open, and held the trip button for a count of 15, did not work; second time drivers door closed and held trip button for a count of 22; it worked.
    Additionally, I believe the original instructions suggest as part of the last step, you hold the trip planner button for a count of 15 seconds. As mentioned above, I found it's more like 20 - 25 seconds.
    Hope this helps.
  16. Jul 1, 2011 at 12:26 AM
    #176
    Clay Pigeon
    Clay Pigeon Member
    Bay Area
    White SR5 w/JBL 4x4
    Tried the trip planner "A" for the white gauges and did not work. I even tried it with trip planner "B" and cycled thru for both before holding down the trip planner. It worked when I tried it on my buddies' 08 with a 12 sec count. I tried that and even up to 30 secs on mine. No worky....
  17. Jul 1, 2011 at 5:13 AM
    #177
    puckstopper55
    Long Island
    ugh .. just when you begin to think there is hope
  18. Jul 1, 2011 at 8:46 AM
    #178
    tacomik
    tacomik Well-Known Member
    E. kootenays,BC
    11 tacoma TRD
    ARB front bumper,AllPro rear bumper,OME lift,Warn,Lightforce,Weathertech,tint,DSP,piaa,oem roof-rack,canopy,CBI rockrails,Viair
    Me to, no luck, I tried it on all 3 ODO settings, holding the button for various times, tried with headlights on/off, seat belt on/off, nothing seems to work, I'm gonna find the box and remove/disable it.
  19. Jul 1, 2011 at 8:56 AM
    #179
    2010nctaco
    2010nctaco Well-Known Member
    Blake
    Concord NC
    2010 trd sport 4x4
    x2
  20. Jul 4, 2011 at 6:07 AM
    #180
    oskar
    oskar Member
    Lockport, NY
    11 Access Cab TRD OR; 21 Access Cab TRD Sport
    worked on my 2011 on the first try
