2011 Taco Wiper Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rhody76, Oct 29, 2011.
  1. Oct 29, 2011 at 8:28 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    So we here in the northeast are getting hit with an October snowstorm and my old windshield wiper issues are resurfacing.
    When the windshield is covered with a small amount of snow, one or both wipers does not work and after you clear the snow they will operate but not with full force but all sloppy. I was told by the dealership that this is some kind of safety mechanism so that the wipers or motor dont break when they are frozen or weighed down with snow. You can remove the plastic covers at the base of the wiper arms and tighten down the nuts and the problem will be corrected but this does not stop it from happening again, Its very annoying when it happens in a snowstorm when the wipers are needed most.
    Has anyone else had this experience or know a solution to this problem?
    Thanks for any info
  2. Oct 29, 2011 at 8:49 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    No problems here but we don't get snow either.....I'd be raising cain with the dealer, sounds like BS to me.
  3. Oct 30, 2011 at 1:42 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Haven't had a problem with them. Mine were frozen to the windshield so I turned on the defroster & squirted the windshield with the washer & they cleared snow & ice off the windshield.
  4. Oct 30, 2011 at 4:47 AM
    Tacoma Mike
    Southern Maine
    Hey Chris
    Yea they have told you the right information.
    It is a safety deal. Saves a bunch of wiper problems. The reason was because of all people to lazy to clean off there windshields properly before starting.
    SOOOOOOOOOOOOOOO
    Here is the solution.
    The arm mount is made out of soft aluminum. Once you spin the arm you need to remove the arm.
    Clear the windshield completely.
    Get a small pic or scribe.
    The wiper pivot has vertical teeth and grooves. Like 30 of them. You need to remove the aluminum that is stuck between the teeth. ALL THE WAY AROUND. Make sure you clean the inside of the wiper arm for loose stuff too.
    Reinstall in the proper park position and tighten down firmly. You will feel the teeth bite into the arm.
    After you do this like 3 or 4 times you will need a new wiper arm because your reaming the pivot hole.
    So, keep your windshield clean before you start up and before heavy snow builds up and you will never have to do this.
    At one point in time it got spun and just tightening down will do nothing.
    Hope this helps you. We're getting hammered over here and i'm sure i'll see 4 or 5 of these in the shop tomorrow.
  5. Oct 30, 2011 at 12:16 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Hey Mike thanks for the info. I will do as you said. The thing is that there was only about a quarter inch of slush on the windshield and it wasnt frozen at all. It seems that the wipers should be able to clear that small amount without a problem. Seems like a design flaw to me.
  6. Oct 30, 2011 at 12:24 PM
    Tacoma Mike
    Southern Maine
    No not a design flaw really. I know what you mean and it should have handled that.
    Like i said it might have been spun before for what ever reason and or not tightened enough from the factory. A little slush as long as it's not frozen should not of caused that.
    just do what i suggested and i think you'll be good to go. Any more problems just get in touch............
  7. Nov 5, 2011 at 1:34 PM
    Tacoma Mike
    Southern Maine
    Chris, You get them babies fixed ????
  8. Nov 5, 2011 at 1:48 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    You can make it easier to remove snow and slush with a fat coating of rain-x to your windshield and using premium wipe blades and rain x winter formula for your washer fluid
  9. Nov 6, 2011 at 12:43 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Mike- Yeah I took care of it. Thanks for the advice
  10. Nov 6, 2011 at 12:44 PM
    Tacoma Mike
    Southern Maine
    :thumbsup:
  11. Nov 16, 2011 at 4:13 AM
    97-v
    97-v Member
    sinister silver 08 d-cab
    are wiper arms covered by the factory warranty ?????
