2011 Tacoma Access Cab Door Speakers
Discussion in 'Audio & Video' started by ArcaneEdge, Mar 26, 2012.
  1. Mar 26, 2012 at 12:39 PM
    ArcaneEdge
    ArcaneEdge [OP] Member
    Miami, FL
    2011 Tacoma Ext Cab
    Ok so I am looking into putting a full audio system in my brand new truck. I got my custom sub box on order (thanks Mr. Marv) but I only have front door speakers. I see where the back access door speakers would go cause there is a panel cut out I am assuming its for that. Since it didn't come with factory speakers, what do I need in order to install speakers in the cab door? Is there a kit out there or something? Appreciate any guidance. I attached a pic for referrence. Thanks.
  2. Mar 26, 2012 at 5:45 PM
    ArcaneEdge
    Miami, FL
    2011 Tacoma Ext Cab
    Really...37 views and no responses...please...
  3. Mar 26, 2012 at 6:26 PM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    You're welcome and I just replied to your PM regarding this thread!
  4. Mar 28, 2012 at 8:15 PM
    Tokeisch
    Tokeisch Active Member
    fLORIDA
    09 tACOMA pRERUNNER
    I have the same issue, many views not one reply.
    I also would like to do the same.
    Hello, hello... Is this thing on.....
  5. Mar 29, 2012 at 8:42 AM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    Sucks for us 2010+ that the rear "speakers" are nothing more than a couple of wired napkins in the headliner. This is quite possibly the cheapest way possible for Toy to claim a "6 speaker audio system". Just pure crap, wait till you put your hands on the front speakers. Cheap, cheap garbage.
    Anyway, looks like you want a complete system but just for reference I recently replaced my front speakers with JBL GTO938 6X9's, and the difference is tremendous. These speakers have a lot of low end power & clarity, something I found was missing in $50-60 range 6X9's. They were something like $85 from Amazon.
    After putting these in I have no need at all for rears. It was quick, simple, inexpensive and the results were excellent for me.
  6. Mar 29, 2012 at 9:14 AM
    Mr Marv
    Marv
    The rear speakers are now in the headliner of an Access cab as mentioned however the speaker holes are still in the rear door inner frame as in previous models. Installing rear speakers in the original door location requires an adapter, running wires into the door, cutting a hole in the door panel and attaching a grill cover.
    Also, I would agree that front speakers are most important in regards to SQ however rear speakers when implemented properly can be used to actually enhance the front stage. I prefer a nice soundstage up front so I use a left minus right/right minus left delayed signal from about 100hz-7khz on the rears (requires a specific processor or an amp such as a JL 500/5 that does left-right/right-left on the rear channels along with a head unit that has signal delay) however when processing is not available I use some simple tuning tricks without a tweeter in the rear to give a similar effect. On the other hand if you like more of a "club type" sound with music at the same level all around as opposed to the music focused up front then this type of tuning is not necessary so just put a set of speakers in the rear and crank it up if that is how you like to listen in your truck that you paid for! ;)
  7. Mar 29, 2012 at 9:32 AM
    bubbagumps
    bubbagumps Well-Known Member
    Youre running those without an AMP on the stock HU? It will probably cause the stock HU to eventually overheat and blow out. These speakers are rated at 300W. The stock unit on the Tacoma is not designed to deliver that much power. If you run the speakers at high volumes for long stretches you are going to fry the HU. The unit will get red hot.
  8. Mar 29, 2012 at 10:01 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Huh? Running aftermarket speakers won't fry the hu just because they are rated at 300w, which btw is probably a peak power and not rms, doesn't mean you have run them at that power. It'll be fine to run with stock hu.
  9. Mar 29, 2012 at 10:13 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Running more powerful speakers on a stock head unit just means that the speakers probably won't get full power as the head unit can only produce so much.
    In regards to getting speakers in the back doors of an 09+ Access cab you have a couple of options:
    If you want to use the existing door panels, run speaker wires from either the speakers in the headliner or from the head unit to the back doors. Then, either cut a hole and install a grill over the hole or if you are skilled with a dremel, cut slots or some sort of vent for the sound to get through.
    The other option is to find a set of interior door panels from an 05-08 AC Tacoma and replace yours with them OR a company called Xtreme Kreations makes an AC door panel for Xrunners that will work with any other AC cab Tacoma and that allows you to mount a sub and speaker into the door.
    There are some choices out there but they can be pricy and/or time consuming to do. I chose to upgrade my speakers in the front doors and that made a huge difference. I'm planning on putting a better HU in next and with the factory TRD sub in the back I think I will have more than enough sound for my needs. However, it's your truck so you can do whatever you like
  10. Apr 3, 2012 at 10:50 AM
    Tokeisch
    fLORIDA
    09 tACOMA pRERUNNER
    Is there a "How to" remove the headliner and replace the speakers?
    Also, when you upgraded your stock speakers, (front door) are the tweaters still operational?
  11. Apr 4, 2012 at 11:29 AM
    Sheepshead45
    NC
    PreRunner SR5
    As others have mentioned I don't believe this is accurate. The stock unit definately does not have nearly the power these speakers can handle and an amp would give me much more volume. But, I don't listen to anything at high volumes, much less for long stretches, so this suits me just fine.
  12. Apr 5, 2012 at 10:13 PM
    babyboi2284
    babyboi2284 Well-Known Member
    Brian
    Lockport, Louisiana
    09 Barcelona Red X-Runner
    LS 6k projectors w/ white halos, 6k fogs, T-Rex Angry Lids, NST SSK, Coupe Shift Knob, BHLM, LFM, DLM, FLM, JL 500/1 amp, JL 10"w6v2, subX wanna be made by me, Magnaflow muffler, 5% tint, k&n drop in filter, Craven Speed Stubby, map light mod
    Too bad my panels only fit 05-08 access can models or these might be perfect for you. top fits a 6.5" speaker and bottom fits a 10" sub with .5cu.ft of air space and 6.5" depth.
    TRDSport10 likes this.
  13. Apr 5, 2012 at 10:24 PM
    SNJTacoma11
    SNJTacoma11 Well-Known Member
    Runnemede New Jersey
    2011 Tacoma Double Cab 4x4 Super White
    Rough Country 6" Lift 17" M/T Revolvers 35" Nitto Mud Terrain Cold Air Kit
    I hate that I have to get rid of my stuff but Mr. Marv is great and right on with his advice. Help me big time with my stuff...
  14. Apr 5, 2012 at 10:24 PM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Huntingdon Valley, PA
    2019 DCSB TRD Off Road 4x4
    OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat
    Those panels are sweet! Wished they made something like that for a '12.
  15. Apr 5, 2012 at 10:27 PM
    babyboi2284
    Brian
    Lockport, Louisiana
    My stock panels are the same as the OP. Once I get some sets of the 05-08 panels I make sold then I will start to make sets for 09+ access cabs.
  16. Apr 5, 2012 at 10:29 PM
    Warhorseforever
    Will
    Sand Lapper
    A speakers makes no power what so ever. You can run speakers that are rated 1000w rms on 20 rms all day long and it'll be just fine as long as the signal is not clipping or distorting. Just because a speaker is rated at 200rms doesn't mean you have to give it that power.
  17. May 25, 2012 at 5:35 AM
    barcodeguy
    barcodeguy Member
    Dave
    Virginia
    10 TRD 4x4
    I have a 2010 with the speakers in the headliner. I was told to just leave them alone and disconnect them. Then mount speakers in the rear access doors and connect those to the rear speaker wires. Do you have any instruction or advice on the best way to do that? Where to cut the holes in the panels, what covers to use, etc.?
    Thanks
  18. Apr 8, 2013 at 5:19 AM
    urguardian
    urguardian New Member
    Curacao
    06 X Runner Black
    Hi...where i can buy that panels??
  19. Apr 8, 2013 at 4:35 PM
    babyboi2284
    Brian
    Lockport, Louisiana
    I make them
  20. Apr 9, 2013 at 6:32 PM
    urguardian
    Curacao
    06 X Runner Black
    ok ok ...And how much for 1 pair if I buy from you?
