2011 Tacoma SR5 Fog Light Installation.. Need some help Please.
Discussion in 'Lighting' started by barcapopo, Apr 7, 2013.
  1. Apr 7, 2013 at 9:55 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
  2. Apr 7, 2013 at 11:11 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Personally?
    Keep the part that connects to the lights and bin the rest.
    Buy the FJ switch and harness and build your own harness and you can have an illuminated switch WITH indicator light that fits the dash properly.
    The full FJ kit is about $75 with harness... that'll get you the connector for the back of the 6-pin switch.
    I've got a wiring diagram for that around somewhere... I'll find it tomorrow evening.
  3. Apr 7, 2013 at 11:17 PM
    barcapopo
    barcapopo [OP] Active Member
    Vancouver / Point Roberts
    SR5 Tacoma
    Where do I get the FJ kit? Ebay? Got a link?
  4. Apr 7, 2013 at 11:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  5. Apr 8, 2013 at 8:00 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Kenwood CD, MTX/Jensen amps, Rockford/Polk speakers.
    It just might work Rich. Not sure about his, but the one that came with my aftermarket did the job right and looks OEM enough in terms of fit.
  6. Apr 8, 2013 at 8:01 AM
    ABA180
    East Bridgewater MA
    I don't have daytime running lights on mine, so if you do it might be different.
    On mine I need the parking lights on to turn my fogs on. Doesn't matter if the low or high beams are on they never change.
  7. Apr 8, 2013 at 8:07 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    No, I tapped into the parking light wire which is the corner marker light on the headlights. It means your fog lights can be turned on whenever your parking lights are on, the first position on your light switch.
  8. Apr 8, 2013 at 6:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    His kit (and switch) look just like the one that I got.
    Doesn't fit the opening worth a crap... huge gap at the top/bottom.
    Looks bad, and doesn't hold tight.
  9. Apr 8, 2013 at 6:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ditto.
    Corner parking lights are on with the headlights/taillights.
    The DRL are only on when the headlights are OFF, or with the turn signals. You don't want to use the DRL unless you want to use the fogs in the daytime and as a redundant turn signal.
  10. Apr 8, 2013 at 6:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  11. Apr 13, 2013 at 8:30 PM
    Aeon
    Aeon FOX HOUND
    Puerto Rico
    PreRunner SR5 4x2
    Coming Soon!
