2011 tacoma steering wheel shaking in high speeds with spacers normal? Or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alltimegamer247, Jun 7, 2015.
  1. Jun 7, 2015 at 5:21 PM
    Alltimegamer247
    Alltimegamer247 [OP] Member
    2011 tacoma prerunner 2.7L 4cyl
    I installed 2" wheel spacers on all 4 tires with a torque wrench at 100ft pounds 6 lugs and star pattern installed it. The truck steering wheel does not vibrate at all from 0 to 65mph but once it hits 65+ ish mph the steering wheel starts to shake. Is this normal? Do to the fact that the tires are 2" out instead of inisde the truck or not?. Unsafe? Or normal? Should I take the spacers off?.
  2. Jun 7, 2015 at 5:44 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Yes, spacers can cause vibrations. But without knowing which spacers you used the answer is maybe. Cast vs billet? Hub centric vs lug centric? Overall quality?
    Google is your friend but try to avoid relying on information posted by teenagers and 20 somethings. I know, they are the only posters that act like experts and are the primary spacer fas. Its hard to filter. But there is a lot of good realistic info out there about vibration, premature front end component wear, and lug failure.
  3. Jun 7, 2015 at 7:32 PM
    Alltimegamer247
    • Bolt Pattern: 6x5.5 (6x139.7). Hub Bore: 108. Spacer Thickness: 50mm (2.0 inch). Stud/Nut Thread Pitch: 12x1.5
    • CNC Machined using High Quality Aerospace Aluminum
  4. Jun 7, 2015 at 7:35 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Who makes it and part number? Lug or hub centric?
  5. Jun 7, 2015 at 7:37 PM
    Alltimegamer247
    Thank you and true. I'm just trying to figure out if somebody knows anything about it because I've never had a truck with wheel spacers the only thing I've seen online is that it might not be put on correctly I'm not sure what they mean by that if everything was put on correctly. Just trying to see if its safe. Ill use google thanks
  6. Jun 7, 2015 at 7:39 PM
    Alltimegamer247
  7. Jun 7, 2015 at 7:40 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    If its lug centric you will probably get vibrations. That's why I asked. A manu and part number would let us answer the question too. If the manufacturer isn't proud enough to put their name on it, it may be made too poor tolerances. Vibes again and another reason I asked.
    Edit - see you replied while I was typing...
  8. Jun 7, 2015 at 7:44 PM
    Alltimegamer247
    Im thinking of just taking those off then the truck looks better but doing 65+mph fells pretty dangerous.
  9. Jun 7, 2015 at 7:50 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    That says the bore is 108mm and I think our 2011s have a 106mm hub. That two millimeter difference could ddefinately cause vibrations or worse. On hub centrics like ours the bore has to tight to the hub. Will need to let a spacer expert weigh in at this point. I don't dont and wont own a set of the things.
  10. Jun 7, 2015 at 7:52 PM
    Alltimegamer247
    Thank, you for the info about the bore size and the help i will definitely take them all off.
  11. Jun 7, 2015 at 7:59 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
  12. Jun 7, 2015 at 8:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The hub size is for sure part of the problem. Maybe the wheels also.
    I agree with steelhd on this. I don't like spacers I've seen too many come loose at speed and it isn't pretty.
  13. Jun 7, 2015 at 8:22 PM
    Alltimegamer247
    Ome wheels n a/t tires thread but more for road use . Seems like wheel spacers are not a good idea at all.
  14. Jun 7, 2015 at 9:16 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Maybe there is a ring you can install to make them work. I dunno though.
  15. Jun 8, 2015 at 9:47 AM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Bump for the OP. Don't want to turn him off his spacers without somebody who actually uses them weighing in.
