2011 Tahoe zerk fittings and grease question
Discussion in 'General Automotive' started by SpacemanSpiff, Nov 21, 2013.
  1. Nov 21, 2013 at 6:21 AM
    SpacemanSpiff
    SpacemanSpiff [OP] Well-Known Member
    James
    08 TRD Off-road
    I plan on doing the maintenance on my wife's Tahoe myself since a local shop screwed up the lug nuts on her daily driver Prius.
    Since my Tacoma does not have zerk fittings and I don't use it, what is the best type of grease to use for this? I have read some Tahoe forums and they say to be careful not to overfill the boot (??) as it may cause it to burst. I always thought that one was supposed to fill it until the old grease started coming out? Is this not how its done anymore?
    Also, does anyone have a Tahoe and have a map of the fittings? Thanks in advance!
  2. Nov 22, 2013 at 5:11 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Are you talking about ball joints? Just pump until you see the boot starts to inflate, then stop. Use NLGI grade 2 lithium- or urea-based synthetic grease (usually green).
    A map isn't necessary. There are only a limited number of possible suspension greasing points:
    - lower ball joint
    - upper ball joint
    - outer tie rod end
    - sway bar links
    It's more important to grease the driveshaft U-joints though. Just look over all the U-joint yokes for zerk fittings and pump grease into them. With U-joints, pump grease in until you see all the old grease expelled from the bearing caps.
    Not a Tahoe, but still a GM and similar technique:
    http://www.youtube.com/watch?v=bB2RiRKDQ9k
  3. Nov 22, 2013 at 6:51 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Also, your Tacoma has zerk fittings - your ujoints are greaseable. So grease your Taco while you have the grease gun!
  4. Nov 25, 2013 at 12:15 PM
    SpacemanSpiff
    James
    08 TRD Off-road
    Thanks for the info! My Tacoma doesn't have zerk fittings...
