2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oildriller, Feb 11, 2013.
  1. Feb 11, 2013 at 11:45 AM
    oildriller
    oildriller [OP] Active Member
    Dean
    Shreveport, Louisiana
    Tacoma, TRD/Off-Road, 4X4
    Bilstein 5100 Series Struts & Shocks (Struts set 2.25", Stock Coil-overs). 1" Rear Leaf Spring Blocks. Throttle Body Spacer. K&N, High Flow-Air Filter. Toyota, OEM, TRD, Cat Back Exhaust (tail pipe cut off, behind muffler, installed 3"OD X 5"L X 45 deg, turn down, dumped prior to axle). Toyota, OEM, Running Boards. Bora, 1" hub-centric wheel spacers. Mud flaps & emblems removed. Satoshi grille (by Brian Roadruck).
    1) Need instructions, or, advise, where to find a video, on how to remove, the front & rear, plastic mud guards, on my 2011, Tacoma, TRD, 4X4.
    2) I am installing Bilstein 5100, Adjustable, Struts, on the front & 5100 rear shocks, on my 2011, Tacoma, TRD, 4X4. The strut adjustment, will be set on 2-1/2''. Do I need to raise the rear 1", to compensate for the front being raised, or, can the rear, remain the stock height?? No heavy loads will be carried.
    3) Does anyone recommend installing a throttle body, due to the poor gas mileage (16.5-17.3 mpg) & throttle response, to my 2011, TRD, 4X4.
    4) Any advantage to cutting the exhaust pipe off, 3", behind the rear of the stock muffler & installing a 4" long turn down, on my 2011, TRD, 4X4. I do not want to install a cat back system, as they are too loud.
    Thanks in advance, for the replies.
  2. Feb 11, 2013 at 11:49 AM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    no mods until the warranty is up!
    1. There are a few plastics tabs and some screws for the mud guards very easy to remove.
    2. You will be nose high with 2.5 up front you will need an aal in the back.
    3. Throttle body spacers are garbage on tacomas save your money
    4. No advantages nor disadvantage. I personally have mine chopped after the rear axle
    Ps you work on a land rig or offshore?
  3. Feb 11, 2013 at 11:57 AM
    oildriller
    Dean
    I am new to the site, on how to reply & post & the lingo used!!
    What is an aal??
    I work on land & offshore rigs, Stateside & International.
  4. Feb 11, 2013 at 11:59 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Amarillo, TX
    OME Lift
    aal= add a leaf
  5. Feb 11, 2013 at 12:00 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    aal= Add a leaf :D
    Read up on a lot of the lingo here:
    http://www.tacomaworld.com/forum/glossary.php
    :D
  6. Feb 11, 2013 at 12:00 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
  7. Feb 11, 2013 at 12:01 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    couldnt have been 30 seconds
  8. Feb 11, 2013 at 12:03 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    10mm on the bolts for mud flaps, just use a small flat head screwdriver to lift the plastic push pins out, be gentle but it will take a little force to pop them out. Might have to work them around the edges a little.
  9. Feb 11, 2013 at 12:06 PM
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    Lol! I win!!
    I like how you think!:rolleyes:
  10. Feb 11, 2013 at 12:10 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
  11. Feb 11, 2013 at 12:13 PM
    oildriller
    Dean
    Cook Inlet Energy, Alaska, Sr Drlg Consultant.
