2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.
Discussion in 'Suspension' started by ryan4544, Jun 15, 2012.
  1. Jun 15, 2012 at 11:59 PM
    ryan4544
    ryan4544 [OP] New Member
    Haughton, LA
    2012 Prerunner 2.7 DC
    About a month ago I traded in my 07 FJ Cruiser for a Tacoma. I recently installed the Toytec Ultimate lift which includes bilstein adjustable coilovers and AAL's.
    I have seen many posts with this set up or similar setups so for anyone seeing this it will be nothing extraordinary.
    I enjoy this set up very much and I am satisfied with the resulting lift however I would like this post to give information to another person like me who wants to lift their tacoma and is concerned with possibly buying UCA's to correct alignment issues.
    I researched the forums to learn what I could about the lift causing alignment issues and saw numerous posts about people saying some trucks will need the UCA's and some wont.
    The kit I purchased included axle shims but I am not sure what degree they are or anything like that. They are just included in the Toytec ultimate lift kit.
    I did purchase the OME carrier bearing drop down kit just in case the axle shims did not straighten out the drive shaft enough.
    After all was said and done. I installed the axle shims but I did not install the carrier bearing drop down kit.
    I took the truck to get it aligned and they were not able to get the caster aligned properly.
    I do not have the alignment specs....
    I ordered some TC UCA's hoping to correct the alignment issues.
    I will attach pictures showing the following:
    Drive line angles,UCA angles, and the lift itself.
    Thanks! I had a lot of fun installing the lift!
