2012-2015 fog light bezel removal question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dofartshavelumps, Jan 5, 2019.
  1. Jan 5, 2019 at 11:35 AM
    dofartshavelumps
    dofartshavelumps [OP] Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    My OEM black LED fog lights arrived today, I ordered PT413-42191 that were mentioned in a thread a few days ago. How do I pop out the fog light assembly? I have fog lights so I am just replacing. I see blue clips, do I take these out and pull the bezel out from the front? How many of these clips are there and are there any other screws holding it in? I searched but didn't find anything other than someone mentioning blue clips. Can I get to everything without removing the wheel well liner? Thanks.
  2. Jan 5, 2019 at 12:45 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    You have to remove two screws from the bottom of the wheel well liner, remove one push pin type fastener up higher on the wheel arch opening, and them bend the wheel well liner back toward the wheel. The blue clips slide out toward the right and left respectively if I remember right. The bezel is removed from the outside. There are two tabs on the fog light bezel that engage the bumper cover on the sides opposite the blue clips.
    dofartshavelumps[OP] likes this.
  3. Jan 5, 2019 at 12:48 PM
    dofartshavelumps
    NH
    Thanks for the help! I'll give it a try tonight or tomorrow hopefully.
  4. Jan 5, 2019 at 1:03 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    If you go through my posts I just did a quick how to the other day in another thread. If you need help try and refer to that.
  5. Jan 5, 2019 at 2:07 PM
    dofartshavelumps
    NH
