2012 Baja "How big" can I go???
Discussion in 'Wheels & Tires' started by MWM BAJA 12, Jun 11, 2013.
  1. Jun 11, 2013 at 12:34 AM
    MWM BAJA 12
    MWM BAJA 12 [OP] Well-Known Member
    Micah
    Dallas
    2012 "Baja" Edition BLACK
    see my build page
    I have a 2012 Baja. I don't want to add any suspension mods yet while its still under warranty but I do want to get bigger tires. How big can I go 285/75 16???:confused:
  2. Jun 11, 2013 at 12:38 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Id recommend you get a feel for 265s first. 285 usually requires cutting even on some 3" lifts. If your dying to fit them and dont care about ride comfort then look into maybe Spacers both ways. Space vertically through suspension perch and then horizontally through your rotors in front. Wheel spacers at 1.25 usually gets your out enough to miss the normal stuff... Still might need to trim a tat bit for that tire.
  3. Jun 11, 2013 at 12:45 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Why buy a Baja and lift it? It already has good tires and suspension from toyota
  4. Jun 11, 2013 at 1:23 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    I have a new front bumper on order from Pelfreybilt so I hoping any rubbing issues up front should be resolved if I run 285s. Since the Baja is already "lifted". If I went with 285s would the rubbing issue be up front and how exactly do the 1.25" spacers work?
    I don't plan on lifting the Baja for a long while (paid off) so I don't void any warranties. And why spend all that extra for the Baja option if your gonna lift if as soon as you get it is pointless.
  5. Jun 11, 2013 at 1:36 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    The stock tires on it are 265/70 16 BF Goodrich All-Terrian. I think some 285/75s DuraTracs or Terra Grapplers would look wicked aggressive
  6. Jun 11, 2013 at 2:27 AM
    ToyComa92
    Jon
    Conifer, Colorado
    Im not super familiar with what they do to "lift" the baja editions but if its with billys then im going to say you should just need wheel spacers up front- They put space between your rotor and wheel so your turning radius is more widened... if that makes sense. So if you could only go 70 degrees without spacers, pulling the wheels out more will probably give you somewhere between 5 and 10 more extra degrees to clear anything like your trim or UCAs. Definitely wait and let someone who owns a Baja chime in but thats pretty much the gist of options people have without actually doing full lifts. My only concern running those tires would be rubbing your UCA or your front inner wheel trim.
  7. Jun 11, 2013 at 2:44 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    iirc its "special" billies and eibachs for about 1.5-2" front lift.
    screams "eibach/toytec" doesnt it?
    rear is 5160 iirc
  8. Jun 11, 2013 at 2:48 AM
    ToyComa92
    Jon
    Conifer, Colorado
    Its like the exact lift im running, Which ive decided ruined my ride quality so am saving up for King 2.5 COs in front with King Piggys loaded on Alcan 9s.
    Best lift without going SAS or LT is what im told.
    Anyways id just go to a big O or something and ask to have a set mounted to see. Sometimes they hook you up and sometimes they want to charge you.
  9. Jun 11, 2013 at 11:03 AM
    Bran88hi
    Bran88hi Member
    Brandon
    Greensboro, NC
    2013 Tacoma T|X Baja Edition
    I just bought the 2013 Baja Edition and am having the 3 inch Ready Lift leveling kit put on so I can fit 285/75 R16 BFG Mud Terrains. We'll see how it goes. I definitely do not want to mess around with the Bilstein shocks that came on it.
  10. Jun 11, 2013 at 11:14 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    please don't, just get a half inch top plate spacer from toytech
  11. Jun 11, 2013 at 11:25 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    I don't think youre supposed to do that. Especially without a uniball UCA. Half inch would be the most I would go.
  12. Jun 11, 2013 at 2:37 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Ur going backwards
  13. Jun 11, 2013 at 2:47 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    WHHY???? Adding those spacers IS MESSING with the Bilsteins that it came with!
  14. Jun 11, 2013 at 2:50 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    Pointless anyway...
  15. Jun 11, 2013 at 2:53 PM
    teneighty
    Check out my Build
    Ummm that is messing with it :der:
    OP and Bran88hi, why buy a baja and mess with the suspension??!! That's what you buy it for! Makes no sense and your just screwing it up
  16. Jun 11, 2013 at 5:06 PM
    Bran88hi
    Bran88hi Member
    Brandon
    Greensboro, NC
    The 265s just aren't big enough. I just traded in my access cab that I had done the Truxx level on and loved the height. I had the 285/75 R16s on it. It wasn't too much but just right.
  17. Jun 11, 2013 at 5:08 PM
    ToyComa92
    Jon
    Conifer, Colorado
    So why not save the cash you spent buying a Baja and bought a nice quality OME lift or even Icon or kings.
  18. Jun 11, 2013 at 5:10 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I agree, coulda had kings and dropped panties on demand.
  19. Jun 11, 2013 at 5:12 PM
    ToyComa92
    Jon
    Conifer, Colorado
    If tire size really makes that big of a difference to you and it doesnt seem like you're super into the quality of a lift... Why not go DB 6" lol
  20. Jun 11, 2013 at 5:14 PM
    Bran88hi
    Bran88hi Member
    Brandon
    Greensboro, NC
    I'm afraid if I put the 285s on they will catch on the flare and do some damage. I really don't know what to do at this point. I love the Baja but I just want the truck to sit a little higher.
