2012 Climate Control in 2011 and under Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dibble9012, Jan 23, 2013.
  1. Sep 18, 2016 at 11:25 AM
    #41
    Aznsniper
    Aznsniper Well-Known Member
    NC
    Is there anyone with extra eastern beaver connectors for this mod that wouldnt mind selling me a set? :)
  2. Sep 18, 2016 at 11:53 AM
    #42
    motozack
    motozack Well-Known Member
    zack
    Humboldt Ca.
    '07 2015 TRD pro clone MAGNUSON supercharged
    Magnuson S/C 2.85 stealth pulley Afe stage 2 sealed pro dry 255 URD fuel pump TRD Quickshifter & knob Method double standards 265/70/17 KO2's B.A.M.F. Sliders W/kickouts powder coated 2.5" kings W/resi's Camburg UCA's TRD catback exhaust 2015 TRD pro clone 2015 interior Pioneer Nav
    https://www.arrow.com/
    Got all my stuff here
    Easy & fast
  3. Sep 18, 2016 at 2:40 PM
    #43
    mrbedgood
    mrbedgood Isaiah 6:8
    North Carolina
    '11 MGM DCSB TRD Off Road 4x4
    Total Chaos +2" Long Travel Kit; King/TC 2.5 LT C/O w/ 16"x600; TC/CVJ Extended Axles; TC Spindle Gussets; King 2.5 RR shocks; All-Pro Expendition Leaf Pack; Pelfreybilt Sliders; Anti-Dark LED Hood Light mod; LED map and dome light mod; Bed lights; TRD Cold Air Intake; KB Voodoo Tailgate cap system; HomerTaco Thin Lip "Raptor" grille; sPod SE System w/ LCD Touchscreen; Baja Design OnX6 40"; Baja Design S2; Rigid Industries LED Rock Lights; Front Runner Slimline II Roof Rack; A.R.E. Z Series Camper Shell Projector BHLM Headlights (with custom wiring); Method Racing NVs 17"x 8.5; and Nitto Terra Grappers 265/60/17
    The one that goes in the back? I'm messing with my a/c control now. Let me see if I have one left over
  4. Sep 18, 2016 at 9:13 PM
    #44
    mrbedgood
    North Carolina
    Do you remember the part numbers that you ordered?
  5. Sep 19, 2016 at 11:10 AM
    #45
    Aznsniper
    NC
    Yea the connectors on the back so I can re-wire a 2012 A/C control unit to work on my 2010.
  6. Sep 19, 2016 at 1:10 PM
    #46
    mrbedgood
    North Carolina
    The small one? do you have the control as well?
  7. Sep 19, 2016 at 1:13 PM
    #47
    Aznsniper
    NC
    I have the controls but I dont have the two connectors that are listed under the PDF in post 41. Which is what I am trying to get. And wanted to see if there was an easier way than eastern beaver
  8. Sep 19, 2016 at 1:21 PM
    #48
    mrbedgood
    North Carolina
    I have the little piece and an A/C control. I decided to keep with the 2011 and probably just paint it black. so both the control and A16 piece I believe it is, will be going on the for sale thread. do you need the A16?
  9. Sep 21, 2016 at 9:10 AM
    #49
    Aznsniper
    NC
    I think all I reall need is A33, which I believe is the female connector that plugs into the back of the 2012 A/C unit.
  10. Oct 5, 2016 at 11:29 PM
    #50
    TacoPretzel89
    TacoPretzel89 Well-Known Member
    '07 Tacoma
    Looking for the 16P025 nh female adapter, anyone have one? Wanting to do this mod but not wanting to spend 20 on top of the 80 for the controls. Might just end up sanding it down and painting it if it comes to it
  11. Oct 18, 2016 at 2:16 PM
    #51
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Anyone have a copy of the write up? The latest one posted is not working for me.
  12. Feb 10, 2017 at 11:14 AM
    #52
    tranandya
    tranandya Well-Known Member
    Andy
    Orange County
    07 DCLB TRD SPORT
    5100 885x LR UCA 1.5AAL FIRESTONE RIDE-RITE w/DAYSTAR CRADLEs
    Bump i orders a few extra Connectors to make your own adapter(No splicing original wires). PM me if your looking for a set.
  13. May 15, 2017 at 7:34 PM
    #53
    gentrysd
    gentrysd Member
    Shannon
    Charlotte, NC
    2011 Toyota Tacoma 4x4 Double Cab Short Bed
    Bump. All the diagrams for this write up are not longer working. Anyone have one they could share please?
  14. Dec 1, 2018 at 11:10 AM
    #54
    bikingtacoma
    bikingtacoma Member
    Patrick
    2009 Tacoma Access Cab 4x4
    Lifted, smoked lights.
    Can you just change some of the LED’s to change the color of the text and not the ones behind the red and blue temp adjust? Does anyone have a pic of the newer temp control taken apart? Location of all the LED’s?
  15. Dec 1, 2018 at 6:58 PM
    #55
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    No since it uses the same Leds as a full background
    Changing any will change the text color too
  16. May 18, 2020 at 11:07 PM
    #56
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Anyone have an issue with the LEDs that illuminate the rings not lighting up? Everything else is working perfect after the swap. The AC and air circulation lights are working fine. Any insight would be appreciated.
  17. Jun 19, 2020 at 12:52 PM
    #57
    NHens@ilstu
    NHens@ilstu Member
    Nick
    Darien, Illinois
    2010 Grey Tacoma TRD Off-Road
    I have the same problem, anyone find a fix for it? I have a 2010.
  18. Nov 7, 2020 at 4:29 PM
    #58
    taco_jacko
    taco_jacko Active Member
    Jackson
    BC
    2022 TRD Sport DCLB
    Bilstein 6112 & 1/2” Spacer Bilstein 5160, 2 1/2” AAL & 1/2” block KMC Impact (17x9, -12mm) Toyo Open Country 285/75/17 JBA HC UCA
    Anyone have any 16P025 connectors they’d be willing to ship to Canada?
