2012 DC Interior head liner removal write up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Molon Labe, Nov 3, 2012.
  1. Jan 19, 2016 at 4:50 AM
    #41
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    LOL! ;)
  2. Oct 17, 2016 at 4:42 AM
    #42
    Molon Labe
    Molon Labe [OP] Never LBS
    Jeff
    Snellville
    2012 Spruce Mica DC TRD 4x4 Auto V6
    see my build
    Guys I check back here from time to time and I am very glad to see this thread has help so many people. I love the insulation/ sound dampening stuff and the pics are great. I also like the idea of the NMO mount where the XM antenna was. I did this write-up because i was requested after I had pulled my liner down to run wiring for all the lights on roof rack. Anyway, thanks for the compliments, comments and interest.
    GHOST SHIP, Biscuits and BenMara like this.
  3. Jan 5, 2017 at 12:03 PM
    #43
    zackdippolito
    zackdippolito Well-Known Member
    zack
    2012 SR5/2014 TRD Sport/2017 TRD Sport 6M
    Is the headline cardboard. ? I'm afraid it might get bent or ruined pulling it out to sound deadened
  4. Jan 7, 2017 at 12:45 PM
    #44
    Molon Labe
    Jeff
    Snellville
    see my build
    I think its a fabric backed by a semi rigid polymer. Its not card board so you can bend it but I would not bend it so much that is creates a crease. I have seen a writeup here on TW where someone almost folded it in half to get it our of the truck and it was fine but i do not know what thread that was. I think that if you careful you should be ok. I would fold the seats flat and lower the liner onto the seats then sort of roll it from one side and slide it out the rear door.
  5. Feb 26, 2017 at 5:38 PM
    #45
    HeyHoLet'sGo
    HeyHoLet'sGo Well-Known Member
    Kentucky
    2015 Black TRD Sport DCSB
    Is it possible to just drop the rear part of the headliner easily without creasing it? I hit my XM antenna on my garage door and want to look underneath it to make sure it's still sealed or possibly replace it.
  6. Feb 26, 2017 at 10:12 PM
    #46
    Molon Labe
    Jeff
    Snellville
    see my build
    HeyHo, I think you will need to drop the who thing to be able to access the mounting bolts for the XM antenna; however you may be able to get away with just dropping the rear by starting at the back and you may need to free everything up to the dome light. If you do not want to mess with the head liner I would just fill any cracks in the antenna fin with a paintable silicone and paint it black. Which ever you decide, good luck.
  7. Feb 26, 2017 at 11:49 PM
    #47
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Sub'd for future use. Great write up
  8. Feb 28, 2017 at 8:41 AM
    #48
    HeyHoLet'sGo
    Kentucky
    The antenna isn't cracked. It just scraped the bottom of my garage door while backing out and popped up a little from the back side. Now there's a tiny gap between the back of the antenna and the roof but no other damage. The Toyota dealer's paint guy said he thinks it's fine but I just wanted to look to make sure myself so water doesn't come in through the gap. (don't trust the dealer)
  9. Feb 28, 2017 at 8:51 AM
    #49
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Subbed AF for this, for when I decided to add RAAMmat to my roof.
    Thought it was harder than this to remove the headliner. Making me feel better about tackling it by myself now.
    Nice job sir!
  10. Mar 26, 2017 at 8:42 AM
    #50
    Justanotherhemi
    Rick James
  11. Apr 19, 2017 at 8:30 PM
    #51
    Molon Labe
    Jeff
    Snellville
    see my build
    Sorry it took me so long to get back to you. You will need to fix the gap. There is a hole in the roof under the antenna that the wire goes through. If I recall, the whole was like 1.5 inches and the wire is only a 1/4 inch so there is a lot of room for water to come in and soak the liner. Let me know if your hole is different but mine was a large hole. I may have a picture of the whole on my build page from when I ran all the roof rack lights.
  12. Apr 20, 2017 at 9:12 PM
    #52
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Id take the Sat antenna off and find an oring to fit under it to seal it off around the hole....
  13. May 6, 2017 at 6:32 PM
    #53
    Justanotherhemi
    Rick James
    Next up in my to do list.
  14. May 7, 2017 at 8:32 AM
    #54
    Justanotherhemi
    Rick James
    Old headliner out. If you look closely you can see all the cracks, creases and it was just plain filthy.
  15. Jun 22, 2017 at 6:04 PM
    #55
    MtnRoad
    MtnRoad chillin'
    Pete
    NB, Canada
    2012 2.7L SR5 MT AC
    great writeup. the dent repair guy needed to access the inside of the roof so this made it easy for me to have it ready for him to do his job. Thanks.
  16. Sep 1, 2017 at 11:27 PM
    #56
    wheresjames
    wheresjames Member
    Did roof racks happen to cause your dents? I have some above the doors on my DCSB from my Thule racks and I'm thinking of having the dents repaired.
    OP. Once the headliner is removed do you recall if the space above the doors is reserved for wiring and curtain airbags? (I think I saw it was pretty busy in that area in someone's sound deadening post) Trying to get an idea of how dent removal would access the dents. Thanks for your efforts.
  17. Sep 4, 2017 at 4:29 PM
    #57
    MtnRoad
    MtnRoad chillin'
    Pete
    NB, Canada
    2012 2.7L SR5 MT AC
    lack of roof racks caused my dents :) I was using a couple of cushions between the roof and the canoe and the roof wouldn't hold it.
    once the visor, handle, side airbag thingy and inside window side corner trim is off the headliner pulls right down for easy access for your dent guy.
    wheresjames likes this.
  18. Oct 10, 2017 at 12:36 PM
    #58
    Jaybashant
    Jaybashant Well-Known Member
    Thank you for posting this! HUGE help. I had to pull the interior out of a 2013 to cut out the cab for a camper walk through and you saved me hours!
  19. Oct 10, 2017 at 4:11 PM
    #59
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Thank you also, for this write-up. It's just as applicable to the Access Cabs, and i had my roofliner out of the truck within an hour - I was running up against sun-down for timing.
  20. Jan 2, 2018 at 10:20 AM
    #60
    DMT187
    DMT187 Well-Known Member
    2016 Tacoma SR5
