2012 DCSB V6 diff fluids
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocker23, Mar 29, 2015.
  1. Mar 29, 2015 at 11:44 PM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Hey guys Been doing some research but can't find definitive answer. I have a 2012 dcsb with the V6 sport. I am going to try to do my front and rear diffs fluid change and save some cash instead of dealer. I never tow so far and now that winter is over prob wont be using the 4x4 anymore.
    Is it 75w-90 for both front and rear? Do I need to add any addditives? Also how many quarts to go in each? I used redline back in my old car (tuned 06 Mazdaspeed 6) but thinking may switch to Mobil 1 as it is easier to get more locally. Any preferences?
    I am not near the truck right now so cant check manual Thanks in advanc
  2. Mar 30, 2015 at 1:34 AM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Yes, 75w90 is good for both and no additive is needed. Rear about 4 qrts and front about 2 qrts. Use whatever ever oil you feel comfortable with. I've used mobil and amsoil, both with good results.
  3. Mar 30, 2015 at 1:45 AM
    Glocker23
    CT
    2012 DCSB Sport
    What is the additive? And how much? In both?
  4. Mar 30, 2015 at 2:34 AM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    NO additive is needed. You have an open differential. I beleive an additive is used only in 1st gens. But other will chime in to verify this.
  5. Mar 30, 2015 at 5:51 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    The additive is only for LSD rear ends. It is for 05-08 or 09 2nd gens only. You just need to drain and refill. May as well do your transfer case while you are under there. It is super easy and takes the same fluid.
  6. Mar 30, 2015 at 5:55 AM
    Glocker23
    CT
    2012 DCSB Sport
    Ok so rear end is 4, front is 2. How much for transfer? Also is there any gaskets or seals that may be needed replacement? Also is there a level that I can look for to make sure there is proper amount.
    Sorry for all questions. I have never done this before on the truck so just want to triple check stuff
  7. Mar 30, 2015 at 7:52 AM
    Sold My Subaru
    Sold My Subaru 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    It's 75w-85 that is called for in the front & rear diffs. Verify this in your owners manual. If you'd like to replace the washers I have all the part numbers listed in the first post of this thread:
    http://www.tacomaworld.com/forum/2n...anual-transmission-30k-service-checklist.html
